Our Community is 662,000 Strong. Join Us.
Please
Register
or
Login
to access:
DriverSide Home
Service & Repair
Car Prices
Parts & Accessories
Reviews & Advice
My Garage
Cadillac
> Catera
View Full Version :
Catera
unanswered posts
no power fuse 24 bcm/gauges/mag pickup
help
heater water control valve
Power Loss
Water in the engine oil fill question and others
speedo and tach dont work
Need Advice on the Catera
Steering wheel locks while driving?
99 Catera, Coolant Leak
98 catera control arm questions?need help
01 Catera coil on plug boots
2001 catera
Disable drivers side airbag?
Drivers Side Heat Blow Cold!?!?! Help
99 Catera Iddling rough at idle
1999 Catera dies after warming up
Bose AMP
Catera Problems
00 Cat
Name that thing
1997 Catera stays in Snow Mode
I have a problem with my catera
Trouble getting shift lever to move
01 Catera Bose Stereo Power Goes Out
98 catera engine problems
Coolant level please help
1998 problem with coolant temp gauge
2000 Catera Bose Radio
catera nightmare!
Lug nuts 98 Catara
Radiator cooling fan
Catera dome light
Bose Radio problems 2000 Catera
'98 Catera Battery Drain
Strange Headlight Problem on 97 Catera
Do the 97-01 Cateras have different keyless remotes?
p1700a p1700
NOT charging, new alt & batt.
Airbag light doesnt go away
97 Cat stutter
Computer problems
No heat -- drivers side 2000 Catera
2000 catera drivers side turn signal stays on
Power to injectors is killed after 2 seconds
1997 Catera need remote.
I need help! (97 Catera)
may purchase a 2001 catera,question??
catera brake light problems
Parting Out 97-98-99 Catera All Excellent Condition!!
02 sensors
Need Advice Buying 2001 Catera Sport
Just Bought 1997 What should I be Aware of?
98 Catara Rattle In The Front End
97 catera heat cold on one side, help?
My Sick Catera
Urgent need for tie rod ends
Drive belt removal
LOTS of oil in the spark plug !!!!!!! HELP
brake lights on and off problem
Catera Problems
code 411
okay i wanna own a caddy.
radio trouble
Wheel lug nut covers
Climate COntrol read out....
Spark plugs
Error Codes..where are you
Catera Factory Service Manual
keyless remote
tempture
97 Catera, Several Problems, Please help!
theromstat location
overheating
healdlights wont turn off! HELP!
Catera shuts off while driving
Engine Coolant Sensor and Gauge
Communication with the MOTRONIC ECM
Third Brake light does'nt work with Right/Left brake tail-light.
headlights
Replace MAF Sensor?
Head Gasket
98 Catera ash tray wont shut
98 Catera Ash Tray
excessive inside front tire wear
Catera Passenger heat always cold
lights under the bumper...
Headlights
Rear running lights
fuel pump
how do you check the tranny fluid??
light problem --- cooling light
where is ECM located
caterra wont stay running
Catera Good Car?
initial start engine idle
98 catera trunk release/fuel door buttons won't work??
changing fuel filter
catera v6 vs. base rsx?
Radio problem
V8 Catera
xFriday Looking for Business and Marketing Associates
Raffle Tickets! Win a Cadillac or Pioneer Plasma TV Raffle Tickets $20
Catera problems
20" rims for sale for caddy's FWD brand new PICS
o2 sensor location
4 sale check it out cheap
caddy tire/ignition problems
V8
Almost bought one
OEM disc changer
Catera Help?
Tail Light Problems
remote keyless entry cadillac cattera
98 Catera: stabilizer bar linkages
Catrrea Information needed
It had potential . . .
Automotive Network, Inc., Copyright ©2012
