fuel pump????
Google
Web AF
zips51
07-29-2005, 11:09 PM
O.k. I know you guys have probably heard this question a hundred times. I thought I would just start from scratch. I have a 1998 S-10 ZR-2. Last weekend it showed the same symptoms everyone else has described. It was running fine. Shut it off went back to start it and it would turn over but not fire. After waiting awhile and turning it over a few more times it ran fine until a couple of days ago when the same thing happened. I took it to the shop to have them check out the fuel pump and they said that was fine. (which was good due to the price) Then on the way home it cut out on me a couple of times, but started right back up. Anyone have clues or where to start
Thanks
dmbrisket 51
07-29-2005, 11:22 PM
vapor lock, open the gas cap when it does it... also keep it over half a tank full
zips51
07-30-2005, 07:30 AM
first time it happened it was a full tank
zips51
08-02-2005, 05:54 PM
I changed the oil pressur sensor and the fuel pump i will see if that does the trick. Hopefully. I really don't want to spend the $500 on a fuel pump.
movin2stereo
08-02-2005, 09:25 PM
If you need a pump try ebay.I got a brand new AC Delco with warranty for $180.00 off there.$500.00 was the same quote I got from the dealer,NUTS,NUTS,NUTS!!!!!!!!!!!
movin2stereo
08-02-2005, 09:27 PM
BTW it might be the ignition module.Scan it or get it scanned.
zips51
09-05-2005, 12:08 PM
i bit the bullet and put a new fuel pump on. if has been running fine since
Google
Web AF
