Our Community is 662,000 Strong. Join Us.
View Full Version : S-10
Pages : [1] 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24
  1. 1997 chevy s10 4.3 x vortex
  2. 1999 S10, Gas leak just under/behind passanger door
  3. 4.3 Vortec to 4.3 with a fuel injected thottle body
  4. 95 S 10 ZR2 engine dies while driving....
  5. Service engine light. GRRRRR
  6. 99 S10 has a delay....
  7. 98 2.2l wont start
  8. 94 blazer ac blower fan control
  9. 96 S-10 Fuel Sender Issue
  10. 98 S-10 electrical problem
  11. 94 S-10 Starter Problems?
  12. Chevy S-10 code P0449
  13. 94 S-10 Front End Shaking/Brakes locked up?
  14. ABS Sensor
  15. ok now we have a problem its throwing code#po302??
  16. getting tough to start??
  17. 4.3 x motor (throttle body) wont run?
  18. Hard start hot or cold!?!
  19. 97 Chevy S10
  20. Code PO 138
  21. 97 s-10 p0301
  22. af news video: 2
  23. code 23 mat below spec
  24. 01 v6 S10 Stalls at traffic light
  25. Universal wiring harness recommendation ??
  26. 2002 4.3 chevy start up problem
  27. 2000 2.2 low volts to Ignition Control Module
  28. 97 4.3 4wd 5spd light issues
  29. !991 S10 2.5L Issues
  30. high idle speed on cold engine startup
  31. 1991 S-10 backup light connection
  32. 03 zr-2 p0303 & p0101
  33. Air box (?) gasket
  34. 2000 Chevy S10 2.2l pickup
  35. 00 S10 2.2 won't start
  36. s-10 door latch
  37. 99 chevy s-10 vacuum hose
  38. 98 s-10 2.2 liter miss
  39. 84 S-10 Extended Cab Instrument cluster Issues
  40. 98 S-10 starting
  41. Help needed with electrical/security problem
  42. 98 s-10 2.2 liter miss
  43. carb vs efi
  44. 00 S10 2.2 fuel press check??
  45. Have a question for the 4.3L swappers
  46. Wreck knocks hole in oil pan!?
  47. 1994 Chevrolet S10 Starting and running issues
  48. 2002 s-10 no heat to floor
  49. 89 blazer s10 fuse problem
  50. 2000 2.2 4L60E clicks in 1st and reverse
  51. 98 Chevy S-10 ABS 4wal brakes
  52. Unhooked battery while running
  53. 99 S10 Blazer just blows air out of dash vents and defrost.
  54. 1996 s10 2.2l hesitates
  55. 89 S 10 fuel pump?
  56. 2003 S10 Chevrolet pickup vortec v-6 wont start
  57. Trans won't go back to park, cable slack
  58. 92 S-10 4.3L runs good at first and then starts to missfire...
  59. 2000 2.2 A/T unknown bracket "HELP" w/picture
  60. Won't Start - Not A Sound
  61. 4L60E valve body filters location
  62. 2000 2.2 auto torque convtr won't go in
  63. Shipping a new S10 to America?
  64. 97 s10 2.2 5 speed, need more hp
  65. 97 s10 2.2 timing chain
  66. 97 s10 2.2 noise
  67. s-10 spark plugs
  68. 2000 2.2 head questions
  69. 02 S10 starting problem
  70. 92-95 4.3L CPI will stall after 50km/hr
  71. 2000 Sonoma flooding
  72. 95 S10 Blazer no Start and then no charge.
  73. 1996 s10 2.2l trouble driving
  74. engine swap
  75. 4.3 vortec
  76. Pulling driveshaft down ? Play in wheel to wheel movement
  77. trans am motor swap
  78. Truck Sitting Outside
  79. need help
  80. 1999 Chevy s-10 Please help
  81. Exhaust value no sealing 4.3 Vortex <HELP>
  82. Old Master "GMpartsdirect"
  83. Doing front shocks is that much harder
  84. Help 2003 wont start
  85. 1997 s10 headlights
  86. New fuel pump, but stuck with wiring issue, Need a fast response please :)
  87. no power up hill
  88. 1994 4.3l TBI S-10 no fuel delivery at injectors.
  89. Fuel Pump problem again, done some testing need some directions
  90. '95 S-10 Pickup Rear Springs
  91. Fuel pump ...........
  92. Changed fuel filter, now it's buzzing........
  93. Okay, now what?
  94. 4l60 overdrive problems
  95. 1990 s10 cold idle problems
  96. 99 S10 2wd Bent pass. side axle...need gear ratio and "ring size"
  97. 88 door pannel removal troubles
  98. 2003 s10 zr2 4x4
  99. 1988 Chevy trans. conversion
  100. 94 s10ss when started floods it's self, ant sugestions?
  101. 2000 s10 blazer 4.3 starting problems
  102. Service Engine Soon light on
  103. 2002 s10 blazer cyls 1 and 3 misfire
  104. Power loss & won't go over 20mph
  105. 91 Chevy s10 p/u with a high idle. need help!
  106. trans cable adjustment
  107. add a leaf question
  108. 1997 s10 brake light low voltage
  109. 2000 S-10 not cranking
  110. Miss fire when climing hill
  111. intermittent starting issues
  112. Ignition switch/passloc
  113. 1994 S10 Blazer 4x4 4.3L "W" Auto 162k miles
  114. evap system diagram
  115. HELP please!
  116. 1995 s-10
  117. S-10 Door Wont Open
  118. Quick question about fuel injector
  119. 94-S10 - Dies while driving and other misc. wacky problems
  120. waterlogged 4.3 vortec
  121. A/C Question
  122. Lower Radiator Hose Removal, with Transmission Cooler lines
  123. 2002 s-10 clutch switch
  124. erratic idle, cold start
  125. 95-95 S10 Blazer question
  126. brake line replacement
  127. Timing Chain replacement?
  128. Please Help
  129. Bad acceleration at first then clears up
  130. have 89 s10 that has the brake light on solid on the instrument cluster.
  131. Crank Shaft Censor
  132. s10 won't start without gas
  133. Shaky Brakes
  134. Problem when idling
  135. s10 tires
  136. AC Recharge
  137. 1997 Chevy S10 2.2 Starts Then Dies
  138. 93 S10 Blazer brake pedal goes to floor slowly
  139. starter problems
  140. 96 S10 AC Issues
  141. no power to coil wire
  142. Moment and lifters
  143. o2 sensor
  144. oil burning addiatives?
  145. oil loss
  146. Brake problems 1999 s10 zr2
  147. 94 S10 CPI problems, Assistance needed
  148. 4.3 Vortec Dead Skip or Miss at Idle
  149. Parking brake adjustment nut - needed!
  150. Wont go into 4-wheel drive
  151. Please Help with starting issues.
  152. Transmission shift cable bracket
  153. Fuel pump part
  154. Need help removing third door panel (2000 Chevy s10)
  155. 85 S10 no start 2.5 iron duke
  156. getting gas in my oil?
  157. My chevy S-10 wont start
  158. injector poppett sequence
  159. s-10 rear end balancer?
  160. 1990 S-10 Tahoe Pick-up(2.8 engine)
  161. Flywheel turns but serpentine belt doesn't
  162. Engine bogs down at 39mph
  163. 97 4.3 v6 idles fine but chugs at 20 mph
  164. S10 350 Headers
  165. herrow, new here, with project
  166. s-10 fuel gauge pegs on full when key turned on
  167. 95 s10 power loss
  168. S-10 coolant leak
  169. 1991 s10 help
  170. please help me
  171. What is the spark advance supposed to be in idle for s-10 blazer?
  172. p0331 rough idel
  173. engine swap
  174. check engine soon light
  175. 99 s10 Ignition Coil Testing
  176. Dorman door hinge
  177. 1984 s10 keeps shutting off on me
  178. 4.3 TBI Fuel Pressure Test Questions
  179. 2000 s-10
  180. New Thread, Mar. 21, 10
  181. 2001 s-10 4.3 miss and p0300
  182. Keyless entry relay
  183. 1994 Chevy S-10 Idling extremely high...
  184. O2 simulator,
  185. Keyless entry Stopped working
  186. six month problem
  187. Exhaust Help Please!!
  188. 03 s-10 steering
  189. 1990 S-10 4.3L V6 Spark Plug Gap
  190. 4 cylinder vs exhaust
  191. 1990 S-10 floods itself
  192. 98 s10 idling trouble
  193. catalytic conrverter
  194. need more power
  195. VACuUM HOSES
  196. 92 s10 blazer no brakes
  197. (91 S10 Blazer 2wd) Using a offset/repair bearing on rear axle
  198. Which way is up? (head gasket, that is)
  199. 2002 Chevy S-10 4X4 encoder motor
  200. 88 4x4 front diff trouble
  201. 83 s-10 w/ 350 having fuel problems..
  202. Expansion/freeze plugs
  203. 1994 2.2 S-10. Doing rear main seal, questions on supplies I need.
  204. 1995-ish S10 Horn Fuse Number and Location... Need Help ASAP
  205. 1995 Chevy Blazer starting issue
  206. Door Handles
  207. engine swap 85 engine into 88 truck
  208. 4.3 idles way to high
  209. 1991 s10 timing
  210. 1992 S-10 2.8L V6 Idle Craziness
  211. Tach fluctuates 200 RPM at highway speed
  212. Steering Play
  213. s-10 wont start now
  214. Hello All
  215. 4.3 vortec power loss & won't go over 20mph
  216. computer fuse?
  217. frankenstein firing order
  218. Alternator stops working around 2800 rpm?? Replaced alt and still occurs! HELP!
  219. 2001 s10 wcode 4.3 misfire on 3 cyl..spider or reg?
  220. 1989 S-10 Blazer Wiring Diagram
  221. What size torx to remove tailgate "brackets"?
  222. blazer body on a truck frame?
  223. no power
  224. no power
  225. Trans prob on a 89 s10 tahoe
  226. 98 S10 4cyl. EGR Valve problem.
  227. '94 S10 4L60E no 1st or 4th gear, just rebuilt
  228. 2001 s-10 abs light and pulsating
  229. 94 s10 5sp 4X4 front axle
  230. ECM Fuse problems
  231. 85 4x4 transfercase vacuume probs
  232. 99 S10 Blower motor
  233. Stalling
  234. Lights on with ignition
  235. 1997 Chevrolet s-10 pickup
  236. Smoking out of oil filler tube
  237. 1995 s-10 wont start
  238. S-10 no start
  239. 1987 2.5L, 4speed manual, considering engine swap, trying to figure out best route.
  240. 1987 S10 Needs help!! Engine? Possible Trans issues
  241. wiring problems
  242. exhaust ?s
  243. Cap Swap
  244. 96 s10 no reverse
  245. 4WD will not turn on
  246. 95 s10 v8 shifter linkage and various ?'s
  247. Caliper replacement - Leaking
  248. 2000 S10 Blazer 4.3 burns up coils
  249. 91 Blazer Blows Smoke
  250. S10 oil pressure unit?????
