high idle
mcdonneptdi1
03-21-2005, 10:07 AM
My 1989 S-15 2.5 liter pickup idles too high.On some occasions it will high idle, even when warm, then stumble when shifted into gear and then quit. It seems to smell gassy after it quits, and acts as if it may be flooded. What could this?
Thanks
Thanks
dtl379
04-25-2005, 10:13 AM
check the idle air valve, or the throttle position sensor.
kirbster269
07-30-2005, 05:29 PM
Thanks
If the throttle body sounds like a huge pump sucking in air it is your IAC Idle Air Control expense part but the problem most likely if you have that being an 89 or it is a vacuum leak could be warn out hoses start with that first, cheaper!!
Thanks
