Our Community is 705,000 Strong. Join Us.
View Full Version : Sonoma | S-15
Pages : [1] 2 3
  1. 2004 Sonoma 2wd changing fuel pump
  2. Hinge Pins 99 Sonoma. Welded in?
  3. Front wheel growl
  4. 1985 S-15 woes any takers?
  5. 4.3 engine interchangeability
  6. 2000 sonoma ABS light on Tranny wont shift
  7. 2000 TieRod question
  8. 97 light assembly switch for 2000 light assembly, possible?
  9. sonoma motor mounts
  10. What type ac compressor do I have on my truck
  11. 99 sonoma hard start
  12. 95 2.2 falls flat when hit gas pedal
  13. no break pedal
  14. Help needed with electrical/security problem
  15. Rear Differential Information
  16. Oil Types
  17. Encoder Motor Removal
  18. shifter ??
  19. 98 Sonoma Leaf Springs
  20. loss of power at 3000 rpms
  21. 2003 Sonoma ABS dreaded C0265 code
  22. Headlight Aiming
  23. S-15 clutch master,slave, bleeding issue???
  24. 94 Sonoma 4.3 z Knock sensor.
  25. 95 Jimmy encoder motor problem
  26. 2002 GMC Sonoma Remote Control
  27. 95 Sonoma 4X4 rough idle
  28. Electrical Issue?
  29. 98 Sonoma Jerk and Cluster Light Flash on
  30. gmc s-15
  31. 95 sonoma tail light problems
  32. CODE 81 Brake Switch Fail.
  33. '92 Sonoma won't start
  34. Pitman arm/Idler arm replacement "98 sonoma
  35. 2000 Sonoma- P0452
  36. replacing right front cv shaft
  37. Gutting Cat
  38. Can 95 s-10 body parts interchange with 95 sonoma
  39. 1998 gmc sonoma vacuum problem
  40. rear end issue
  41. bad miss
  42. 2000 4.3 idles rough and codes.
  43. New problem, 88 S15 fuel gauge not working
  44. Brake fluid leaking...
  45. Temp and gas guage not working
  46. Changing Power steering fluid
  47. Goofy Shifting or ???
  48. 1992 GMC Sonoma Stalls during acceleration
  49. 92 Sonoma dash light problems
  50. 98 gmc sonoma-climate control problem
  51. 2000 Sonoma DRL go off when turn signal is on
  52. Engine swap for 88 4 wheel drive
  53. Sonoma-How to change #3 spark plug the easy way
  54. 2003 sonoma 4.3 ltr runs rough
  55. 95 Sonoma L4-V6. Replace engine mounts?
  56. 98 sonoma will not start
  57. 2002 sonoma 0751 and 1860 codes
  58. Hazard Warning Switch 95 Sonoma
  59. need help identifying a part im stumped
  60. buying a 98 sonoma 2wd 4.3 auto
  61. brake ligths always on
  62. transmission oil cooler lines
  63. Just bought a 2000 Sonoma!!
  64. Transmission Problems
  65. heater core
  66. antifreeze over front part of engine
  67. is there a way to bybass the heater core
  68. air bag light on
  69. Play in steering problem..
  70. Intake Manifold Gasket 1994 Sonoma CPI Engine
  71. help diagnos fuel gauge '99 sonoma
  72. '96 sonoma bed on a '93 body
  73. 4.3 vibration
  74. 2001 Sonoma Defrost problem
  75. can put gas in the tank
  76. 2000 Sonoma Gas Pedal on floor but no acceleration
  77. 98 sonoma spark plug torque specs?
  78. Park brake shoes
  79. 91 jimmys not running right
  80. How do i set distributor on time?
  81. Front end Humming (Alignment?)
  82. Sonoma running rough
  83. Belt Squealing
  84. 1994 GMC Sonoma Idle/starting issue
  85. Tail Light troubles
  86. 98 s10 brand new starter installed-clicking
  87. 98 GMC 2.2 Valve bearings
  88. 95 4.3 jimmy
  89. For better results...
  90. keyless entry FOB module
  91. 97 gmc sonoma 4.3 problem
  92. 86 GMC pick-up
  93. what do i need to install a quarter window
  94. 98 s10 check enjine light remains on regardless. help me!
  95. Sonoma high idle while driving
  96. NEED SERIOUS HELP NOW!!!! please!
  97. Taking the bed off of 1996 Sonoma
  98. 2001 Sonoma
  99. audio amp install
  100. Gas Smell in Radiator?..........
  101. Crank Fuse blowing
  102. 98 Sonoma Hard To Start
  103. 4L60E 2.2 4x2
  104. Sonoma stuck in 4low
  105. 2000 Sonoma Engine surging
  106. need help identifying a part
  107. 95 Gmc Sonoma Missing Badly
  108. 91 Sonoma engines races when changing gears
  109. clutch problem !
  110. Battery Draining when Excellerating
  111. door hinges on cab1992 sonoma
  112. 2001 sonoma Zr2 4X4
  113. '97 Sonoma Starter location....
  114. Transmission Questions on a 1998 GMC Sonoma
  115. drain plug on rad
  116. Dex-cool or the cheap stuff?
  117. 1995 Sonoma
  118. OIL coming out the top
  119. ECM Battery # 9 20amp fuse blows
  120. 2000 sonomaP0452 agine
  121. 2002 Sonoma start problems
  122. fuel mileage
  123. engine hard to start when warm
  124. ABS problem on my sonoma
  125. GMC sonoma clicking
  126. Cause of Transfer Case Failure
  127. 95 Sonoma Starter Dragging
  128. 1999 GMC Sonoma 2.2L Oil Pan Removal
  129. windshield vent
  130. A/c
  131. Dtc (co225)
  132. Pulling My Sonoma
  133. 1986s15 conversion from 2.8 to 4.3 non vortec
  134. 2WD popin in the front of truck
  135. 02 Sonoma problem
  136. how to loosen coolant draincock
  137. head bolt torqe specs
  138. No Spark
  139. 5 speed fluid/oil advice needed
  140. 2002 sonoma dies in reverse
  141. torsion key lift
  142. '91 Sonoma Temp Gauge flucuations?
  143. 1993 4.3L Timing - Need a quicky! :)
  144. 95 sonoma steering
  145. 95 Sonoma Electrical / Starting Issue
  146. 92 sonoma K&n cold air intake hlep
  147. 97 sonoma gas gauge
  148. My 2000 Sonoma hood release cable broke
  149. 2000 GMC Sonoma Front Dif Noise
  150. Just got a 2002 Sonoma ZR5 4x4
  151. 2003 GMC Sonoma Radio Rattle
  152. Removing 02 Sonoma Stock Stereo
  153. Haed Starting And Rough Idle
  154. Bed Extender for Sportside S10/Sonoma
  155. 2001 Sonoma 2.2 Flex Fuel P0178, P0141, P0140
  156. 95 sonoma running rough
  157. Blower motor problem
  158. 97 Sonoma Clutch Replacement
  159. Installing a Tach
  160. No Power To 1996 Fuel Pump 4.3
  161. 98 Sonoma start up problem
  162. Racket in reverse
  163. 2003 4.3L Fuel Pump not getting Power
  164. 2000 sonoma automatic trans
  165. Dash lamp color change.
  166. 98 Sonoma Hvac
  167. 95 sonoma wiring prob
  168. 98 Sonoma 4 cyl. Sluggish
  169. 1995 Sonoma Dies!!! Ignition Switch?
  170. GMC S15 pickup -- crew cab -- need replacement rear door handle
  171. 93 gmc sonoma
  172. 91 Sonoma Wiring Problem
  173. could use some advise
  174. 98 Sonoma Multiple cylinder misfire
  175. '86 Auto 4cyl.-Won't go into park
  176. 91 sonoma starts and sputters out, see if you can figure this one out!!
  177. i cant find the clutch bleed valve
  178. vin decipher
  179. 94 gmc sonoma fuel pump relay...Where is it?
  180. Enamel or Undercoating
  181. Sway Bar Brackets
  182. Working with tubing (fuel + tranny)
  183. Standard or Metric?
  184. Clutch resorvior
  185. 1998 Sonoma sliding window
  186. Don't know what to call this part....
  187. truck has no spark
  188. Could use some Sonoma advice.
  189. 1999 Sonoma Road Hum
  190. Can rear end collision cause driveshaft damage?
  191. clutch hose bleeding problem
  192. HELP!!!!!!!! Sonoma falling flat on face after driving for a few min
  193. Headlight Conversion?
  194. heated mirrors
  195. Plugged Cadillac Converter....
  196. 2002 sl sonoma changing fuel pump
  197. throttle body
  198. Intermittant ABS Light
  199. Theftlock feature
  200. Stupid Rookie Mistake - Please Help!
  201. 3rd Shock?
  202. I think Clutch might be bad
  203. Project in mind!!!am i crazy
  204. please help ASAP
  205. Coolant on floor
  206. P0410 Error Code
  207. Universal Joint
  208. how to...
  209. 1996 sonoma hazzard light problem
  210. Forum Rules! READ ME BEFORE POSTING!
  211. o2 Sensor location on 97 GMC Sonoma
  212. dim headlight after head on?
  213. Transmission Question
  214. 4.3L Sonoma 99 AC/Heater Blend Air Door
  215. How much oil for a 2003 4.3 L
  216. Sonoma ST
  217. Fuel Sending Unit or Ground or some other electrical issue
  218. 92' Sonoma Bogs down after hot start
  219. looking to buy 1991 sonoma need answers
  220. Runs way too hot!
  221. Check Gauges Light
  222. Sonoma power
  223. Sonoma power
  224. Sonoma power
  225. 98 Sonoma Front brake caliper hex bolt size
  226. 94 sonoma MT problems
  227. 2002 Sonoma Parking Brake
  228. 96 GMC Sonoma Shift Knob Removal
  229. Brake issue
  230. Sporadic ABS & Brake Lights problem
  231. Electrical Problem
  232. 1993 Senoma pickup A/C Switch!!!!!!
  233. 1995 Sonoma 2.2l
  234. 94 sonoma rough idle /'exhaust leak?
  235. Should the ABS light come on at start-up?
  236. 1994 sonoma digital dash asap ?
  237. How to program keyless remote?
  238. digital dash sonoma or s 10 89-93
  239. A/c Help Please!!!!
  240. best site for parts?
  241. 1994 sonoma seat problem
  242. Wet floor after rain
  243. sonoma water pump
  244. Radiator Flushing
  245. Interior Lights Stuck On
  246. 95 sonoma truck
  247. axel bearings
  248. '98 2.2L SFI - Oil in Airbox
  249. Sonoma water leak
  250. How do I remove the Window crank handle?
