2001 pathfinder LE Help
grunyon
08-16-2004, 12:12 PM
Has anu of you updgraded the Bose stereo and speakers if so what products??? I'm looking for mid to high level replacement of the Deck and frnt and rear stock bose speakers. I am thinking about diamond Audio any pics or suggestion on what has worked for you would be appreciated I ma planning on changing every thing I can Lights/grill/ and a body kit which I can't find anywhere!!!! please help... I already have 20's DIP and woking on a 15" TV in front and 6.5 in the head rest....... Also have a 200IX punch amp and one 15 power punch to install. Please help and anything I find I will share as well.......
grunyon
08-18-2004, 10:16 AM
Testing
jarhead1
08-24-2004, 09:56 PM
Hello. there are some about 4 easy install double din radio/cd units at crutchfield , I happen to like the jvc kw-777, I will be removing the bose speakers/amps and replacing with jbl/cerwin vega.
as for the radio you can do this yourself, wrap a piece of cloth around a small to medium screwdriver and "pop" out the vent/clock piece above the radio
that will expose some screws , once you remove the screws you can gently pop out the faceplate that houses the a/c and radio units...
