Our Community is 662,000 Strong. Join Us.
View Full Version : Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail
Pages : [1] 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19
  1. 97 Infinity QX4
  2. IAC valve
  3. Blinking Air Bag Warning Light
  4. nissan KA24DE 2.4 liter engine oil leak (this motor from a 2004 xterra in a 2000 frontier xe ext. cab), front crank seal?
  5. Wierd Electrical issues 2001 Nissan
  6. Pathfinder Electrical Issues
  7. 2001 Pathfinder SE 4 x 2
  8. 2006 Xterra SE fuel cap/gauge
  9. Find bolts for roof air deflector
  10. 2005 Pathfinder SE Offroad ECM
  11. Does my alarm work?
  12. passage door will not open
  13. 2001 pathy tran
  14. '96 Pathfinder Front Bumper?
  15. stonehenge
  16. Nissan exterra 2000
  17. 97 Pathfinder "Jack Rod"
  18. Wiring diagram for 2002 Nissan Patrol
  19. 97 Pathfinder Fuel relay removal
  20. A/t oil temp gauge
  21. 2001 xterra electrical/gauge problems
  22. 05 Pathfinder AC Compressor location?
  23. 1995 Nissan Pathfinder Issues...Please HELP!
  24. TD27 diesel fuel flow sensor
  25. Florida Nissan Association
  26. Florida Nissan Association.
  27. Backup Light Switch Replacement
  28. 01`x front suspension
  29. FS: Transfer Case and Differentail Drain/Fill Plugs
  30. FS: NAPA Belt Tension Gauge
  31. 2006 Xterra, Elec. issue??
  32. Heating/Cooling System Output problems..
  33. Considering Purchase - 1st Gen. Pathy....
  34. not enough heat in cab 04 xterra
  35. Xterra runs then dies after about 10min
  36. wheel studs
  37. Belts
  38. oil pan
  39. 2004 Pathfinder, lights turned dim
  40. Punctured tyre.
  41. 2007 nissan xterra tail lights not working?
  42. new transponder (NATS) key programming
  43. Nissan Xterry Shrockworks winch bumper
  44. Replacing Front Brake Pads and Rotors
  45. power / performance programmers
  46. Tachometer Problem - Pegged At 8K
  47. Who Wide is an Armada?
  48. 2001 pathfinder P1140 code
  49. Oil leak!!! Help!!!
  50. 98' Pathfinder Control Arm Bushings
  51. 94 pathfinder missing factory amp.
  52. Stalls after driven for 30 minutes
  53. 1987 Nissan Hub issues
  54. Apex DVD Error
  55. Cruise control
  56. 1999 pathfinder IPDM
  57. 2002 Pathfinder alarm issues
  58. 97 Pathfinder 4wd starting/dying incident
  59. Purchase 2001 Xterra
  60. 93 pathfinder emissions help
  61. Shrockworks Rock Sliders
  62. 95 Pathfinder doors will lock or unlock by themselves.
  63. 05' Pathfinder throws p0430
  64. Transmission issue?
  65. Where is the a/c low pressure port on 2002 Xterra
  66. Drive belts
  67. '93 pathfinder Shuts off while driving!!!
  68. Windshield Washer Pump
  69. SES Light on; code P0455
  70. 2001 pathfinder code 1320 again:(
  71. 96 Nissan Pathfinder Valve Cover Gaskets
  72. sterring sheming at low speed
  73. nissan subs
  74. Overdrive button not working
  75. Need advice on timing belt tensioner pulley
  76. 2001 Xterra body damage question
  77. 2003 Pathfinder Windows keep going down!
  78. FS: Remote Keyless Entry Keyfob
  79. FS: 2001 Nissan Factory Service Manaul
  80. steering problem
  81. How much labor to replace both Xenon HID low beam headlamp bulbs in my 2001 Qx4?
  82. 95 Pathfinder LE Headlight Issue
  83. ? about power steering and 4 wheel drive
  84. Weird Oil Leak
  85. mp3 direct connection w/ 2002 Xterra stock radio?
  86. 06 Pathfinder Electrical Problem
  87. 1991 pathfinder sputters
  88. 99.5 Pathfinder SE Auto Keyless Entry disengaged
  89. stock bumper, side rails. steel 15x8 custom wheels
  90. engine swap
  91. problem with A/C
  92. Xterra 2005 reverse problem
  93. 1990 trasmission shifting issue + smells burnt
  94. 2001 Pathfinder LE Transmission Issues
  95. 96 pathfinderl ift kits ect
  96. Manual vs auto
  97. Check engine soon light????
  98. Iacv?
  99. Glass Lens for Foglights
  100. Are the heads bad or not
  101. 2005 Pathfinder
  102. 96 pathy
  103. 2002 QX4:Error Code P1320
  104. Transmission Issues
  105. Fuel pump set up
  106. xterra burning oil
  107. Engine Ticking Sound
  108. Front Wheel Bearing Bad
  109. Fuel injector wire bitten through...
  110. Heat Shields above the pipe attached to body
  111. NATS removal?
  112. QX4 Trans Replacment
  113. infinity problem, please help
  114. '98 Nissan Pathfinder - Weird Noise from Left front wheel.
  115. 95 pathfinder windows not working
  116. 94 pathy Fan Clutch? No Spin? And other things that are fixed!
  117. '95 Pathfinder Tachometer problems
  118. 97 Nissan Pathy dies... HELP!
  119. True or Catback Dual Exhaust System
  120. Bad vibrations
  121. 2005 Pathfinder ac blower problem
  122. Move to Senegal ruined exhaust system
  123. 1995 pathfinder xe needs engine
  124. OD switch
  125. 4WD Rotor Locknut
  126. 98 Pathy Keyless Entry Horn?
  127. 2001 exhaust leak/ticking noise
  128. my 93 pathfinder ecu got wet!
  129. Asking for Opinion and Recommendations - Possible Used Car purchase
  130. My 2002 Xterra...a few simple questions
  131. New Stereo Install on 2000 Xterra - ???
  132. 2001-2004 Xterra 3" body lift kit
  133. Fuel Pump Relay
  134. Coolant Leak at the Thermo Wax Valve???
  135. 1993 Pathfinder - Worth Buying??
  136. 99 QX4 Timing Belt Replacement.
  137. changing 2003 xterra speakers?
  138. Headlight low beam problem, 1995 Pathfinder
  139. 98 pathy fuel gauge problem
  140. Pathfinder trans compatability
  141. 1994 terrano 4wd problem
  142. 2000 Pathfinder water pump
  143. 97 pathfinder transmission
  144. knock sensor location
  145. Need info on your Pathfinder from 86.5-09? Try NPORA.
  146. X in the snow
  147. P0420 Code on Xterra
  148. Need Advice for Van Rentals (San Diego).
  149. 90 pathfinder transmission problem
  150. what instruments cluster will fit 91 pathfinder
  151. Xterra Won't Start
  152. Hydraulic Clutch failure
  153. T BAR help
  154. 2009 Xterra Stereo Upgrade?
  155. 4x4 chains
  156. 1995 Nissan Pathfinder Wheels
  157. 95 Pathfinder Transmission problem
  158. HELP!the power to my radio and dash won't shut down without tripping the back window
  159. Cargo Light
  160. 2001 Xterra 2WD --> 4X4
  161. xterra vibration/shutter during shift between 45-50mph
  162. Pathfinder intermittent problem
  163. o2 sensor Bank 1/ Bank 2
  164. Locking Steering Column 1996 Sentra
  165. Alarm going off randomly after installing aftermarket radio.
  166. TPMS Question....2005 Xterra
  167. rear defrost wire departed from window??
  168. 05 Xterra headlights/mirrors/bumper and grill
  169. CB/ HAM Radio Mounting Options!
  170. Why you shouldn't buy an Xtrail
  171. Thinking of purchasing a 00-02 Xterra
  172. Lights out on heat/ac assembly
  173. lifters not fast enought for start up ??!!
  174. X Trail Rim Substitution
  175. Gassing up with the car running...
  176. 1995 P/F Reverse prob
  177. 2006 xterra rear shocks really squeeky
  178. air to fuel gauge installation?
  179. 2005 Pathfinder noise
  180. Reverse lights
  181. fog lights 05 xterra
  182. High Pitched Noise Upon Acceleration
  183. 97 Pathfinder intermittent no start
  184. 2001 Pathfinder LE - Rear Power Window Switch Removal?
  185. Power windows problem
  186. pathfinder
  187. VDC off/SLIP light in the 08 xterra off road
  188. Front Right squeals in reverse
  189. 1997 Pathfinder LE won't start
  190. Oil in the radiator and in the radiator fluid reserve tank
  191. 2001 Xterra Washer Fluid Sprayer Problems
  192. Squeaky noise
  193. What happend to fuse? Check out Pics!
  194. Need used or really cheap fender
  195. seat, column, both, or something else...
  196. 91 Pathy electric lock issue
  197. screeching noise when starting
  198. clutch pedal sensor?
  199. Err Message
  200. alive anyone?
  201. For sale Nissan factory service manual for 91 truck/pathfinder
  202. got any repair manuals
  203. OBD problems
  204. 92 Pathfinder dies sporadically. Help!
  205. windshield
  206. Clunking in rear
  207. Are my hubs the problem???
  208. A/C Compressor pulley bearing noisy
  209. Trouble Removing Slider Pin Bolt from Brakes
  210. caliper pins
  211. 98 Pathy - Can't open rear side door
  212. 97-98 Terrano fault codes
  213. 4 cyl performance for cheap
  214. GPAX Meet and Greet - PA NJ NY DE MD
  215. Xterra Nerf bar question?
  216. Wipers will not stop on a 95 Pathfinder
  217. Leaf Spring Problem...please help
  218. Wiring harness issues-'91 Pathfinder
  219. Fuel Sending Unit- PO463
  220. heater issues 95 pathfinder
  221. 94 pathfinder
  222. 96 pathfinder won't start
  223. 02 Angel Eye Conversion HELP
  224. FS: Nismo wheels (00-04 X)
  225. I need info re:2005+ xterras! what falls apart first?
  226. p1140 H02S code
  227. how can I programming my X-Trail Keyless Remote
  228. Kenesaw Mountain Accessories rear bumper
  229. axle flip
  230. smoking 2001 pathfinder
  231. '91Pathfinder fusible link
  232. 1995 Pathfinder transmission problem
  233. Rewiring fog lights on '04
  234. 02 non-RF to 07 RF 6-disc
  235. free manuel or scans - 99 pathfinder
  236. Need to recharge 01 pathfinder A/C freon
  237. Strange Problem
  238. Noise inside Pasenger area Dashboard
  239. New (out of box) windshield cowling
  240. Factory running boards 2000 Xterra
  241. Headlight problems!
  242. Propeller shaft - too much grease?
  243. lube question
  244. 1998 Nissan Pathfinder Won't Start after replacing the battery
  245. Xterra/frontier S/c 3.3 Injectors?
  246. Cheap steel rims 2008
  247. Lower gas mileage
  248. 94 pathy.. rattle sound?
  249. 2005 Xterra Noise & Shifting Probs...
  250. Suspension Upgrade Question
