Disco Series II Brakes
Brettboi
08-06-2004, 12:16 PM
Does anyone know if aftermarket brakes will cause it to constantly squeel? My service guys suggest that I replace my brakes with only LR autorized to the tune of $800 for pads and rotors,
Cbass94
08-06-2004, 02:08 PM
If you look around a little bit, you can find LR oem pads and rotors for less than that. My favorite place is <a href=http://www.rovercity.com>here</a>, the site isn't completed yet, but give him a call, the guy's name is Mohammed and he is almost always much cheaper than anywhere else.
Also, why are you replacing the rotors too?? Are they already worn out, or are they warped and messed up?
If you were to find a pair of aftermarket ones, I think you would be OK putting them on as long as they were just as good or better than the LR ones. Otherwise, I definately would not recommend it. Besides, any aftermarket ones that are as good as the LR ones will be just about as expensive as what Mohammed charges anyway, so you might as well go with oem
If you are looking for aftermarket, check out some places like Rovers North and British Pacific, I know they do some aftermarket brake conversion kits.
-Brad (Cbass94)
-Brad (Cbass94)
Cbass94
08-06-2004, 02:11 PM
Sorry, that link is here >>> www.rovercity.com
Brettboi
08-06-2004, 05:29 PM
Thanks for the tip I will look into them and check, yeah the truck has 60k and it just needs new brakes and rotors, it was a corp lease return so its in fantastic shape but just setting off the abs, traction, and hill descent light, they thought it was the shutter valve which was a $3000 fix but it was just the brakes
BlackSpyder1998
08-07-2004, 02:39 AM
hey guys lets see if you could help me out i have a 95 disco 1 and a recently did a complete tranny rebuilt everything came out perfect but now my brakes started failing more than before the rebuilt so i know is not because of that. so this is what happens when you stop in a red light the four brakes lock and the car cant move you have to accelarate alot to make it move then it jumps and it starts working fine also i have no power on my brakes this my first disco so i dont know it the no power for braking is normal so if any body has had this problem please help me out im thinking it is the abs unit
Cbass94
08-09-2004, 09:33 AM
Yeah, I have never seen this exact thing before, but my best bet would be the ABS control module or some wiring somewhere else.
Also might even try a brake system flush with fresh fluid and make sure it's all bled out just right. Air in the lines will make the brakes lose a lot of power!
