Our Community is 662,000 Strong. Join Us.
View Full Version : Discovery | LR3 | LR4
  1. 97 Discovery SD brake bleeding
  2. Mechanic in need!! won't start after lower intake mistake!
  3. Rebuilt Disco Engine Tips
  4. 00' Disco 2 no spark
  5. Land Rover Discovery 4 with Armor Plated
  6. ABS,TC &Hill light intermitent
  7. 2006 Lr3 HSE Belt Diagram
  8. Back Latch - Help!
  9. Changing Brakes
  10. Cam upgrades and fault codes
  11. Might buy a disco need help..
  12. Help with my 04 land rover Disco
  13. Land rover classic look
  14. Advice/recommendations please
  15. 2000 Discovery II w/Leaking Intake Gasket?
  16. 00 disco leaking timing cover
  17. Discovery High Idle Problem
  18. Disco II Air conditioning
  19. Need help with unlocking radio
  20. recode or reprogram ecu
  21. Land Rover drivers are mechanically not gifted
  22. Changing the transmission fluid
  23. How to check codes
  24. Vacuum Line Diagram '94 Disco V8i
  25. Seeking owners with LR3 suspension failure for legal action
  26. Fuel Filter in 2001 Disco V8
  27. 97 Discovery missing/stalling
  28. Wind Shield Wipers have failed.
  29. Service Engine Soon LED Bulb
  30. Question Leaking gasket?
  31. NEED HELP, P0150 code AGAIN
  32. remote starter
  33. 95 Disco has water in oil
  34. 95 Disco has water in oil
  35. 95 Disco has water in oil
  36. 95 Disc Water in oil
  37. Cannot move 95 Discovery out of 'Park'
  38. 2004 Discovery with 31k for 19k?
  39. Front Axle - Vacuum Line Open
  40. Thinking of buying
  41. Discovery Sluggish When Cold
  42. 94 Disco Headlight Won't Turn Off !!!
  43. 97 discovery power seat
  44. Key Problem Discovery 3 TDV6SE
  45. 2000 Disco2 front brakes
  46. 4.0 engine out of wrecked Discovery
  47. Antilock, Traction control, and Hill decent lights on?
  48. HELP!!!! 94 Disco Stalling in Drive
  49. ODD vibration? grinding?
  50. Thinking Of Getting a 97 Disco
  51. Lucas alarm DiscoI
  52. Audio Problems
  53. 4.0 v8i engine
  54. lpg
  55. Power Window
  56. Two Questions
  57. 1996 land rover radio
  58. SAFETY RECALL News
  59. replacing starter
  60. Ignition Locked
  61. What to look for on used Discovery
  62. 95 disco headlight conversion
  63. 4x4 Photo Competition - win CASH prizes for photos of CB Equipment in your Disco !
  64. any known problems
  65. discovery questions
  66. Wheel Lugs
  67. help know nodda
  68. Rover discovery
  69. 95-99 The El-cheapos?
  70. 97 disco trans oil cooler repair
  71. 97 disco Trans Cooler leak
  72. ok there wasnt a LR3 form so this is as closest thing I could pick
  73. alternator-electrical problem-please help!
  74. Sweat switch problem
  75. lift kits
  76. 1998/1999/00 Disco...should I buy?
  77. removing squab and cushion knobs on seat switch cover
  78. Programming Keyless Remote
  79. Land Rover Discovery II Parts NEEDED!!!
  80. windshield wipers
  81. Help Please
  82. Fault Codes !?!?
  83. Swashing Water Sound in my Dash
  84. Washed engine, now runs rough
  85. 1999 Disco II
  86. studdering car and speedo probs
  87. whats the duribility after 100,000 miles???
  88. Check Engine amber problam/question
  89. Anyone from VT??
  90. tire air pressure question on disco II
  91. Sidebars?
  92. Weird Problem
  93. Rims/Tire question 1997 Disco?
  94. ignition hard to start
  95. Problem with running the discover
  96. Disc II: CD Change Problem
  97. starting problems
  98. difference between series 1 & 2
  99. Antenna
  100. 95 discovery window
  101. Discovery 1996 interior lights
  102. Transfer Noise
  103. Range Rover/Defender/Dicovery question (no Nonspecific Forum)
  104. Washer fluid leaking head light Washer
  105. Electric Question 1998 Disco
  106. Discovery Brake Pads
  107. Disco Bras?
  108. 95 disco problems
  109. 1996 land rover discovery
  110. costs to maintain
  111. condensation?
  112. 99-00 Discovery II Series
  113. Land Rover Electrical
  114. Disco Series II Brakes
  115. Tire Question.
  116. Clock Swap
  117. Any "Easy" Fixes for an exhaust leak?
  118. Low Brake
  119. 94 Disco "knocking" noise
  120. Remote Programming
  121. rangerover vogue se auto is it any good?
  122. Any way to get more power?? ('96 Disco)
  123. Squeeking From Drivers Side
  124. 96 Discovery...To buy or not to buy?
  125. 2000 Disco-What Do You Think?
  126. interior lights not working????
  127. Transmission Problem on Discovery I
  128. What have I done?
  129. The new Discovery 3
  130. Discos in New Mexico
  131. Anti lock light on!
  132. Help! Its this or a minivan (jump seats)
  133. shifting into 4 wheel Low??
  134. AM I Making A Mistake?
  135. Should We Buy!?!?!
  136. Head Lights
  137. alarm question -- need help please!!
  138. How do I fix these codes?
  139. CD Changer (aftermarket)
  140. Ignition Problems w/95 Land Rover...HELP!
  141. turning a car into offroad material?
  142. Boze Alloys
  143. Got Diesel??
  144. Some type of valvetrain problem
  145. Land Rovers 2003 NAIAS Stand
  146. Too many lights?
  147. Disco oppinion
  148. 96 Disc SE 7
  149. odd problem
  150. 2001 Discovery Towing Question
  151. Air Intake
  152. Gas
  153. workshop manuals and parts catalogue CD rom
  154. programing keyless entry on disco
  155. reset password for Land Rover
  156. strength & beauty
  157. 97 Discovery For Sale
  158. Whats better? Discovery or Grand Cherokee
