Nissan Maxima Keyless Remote Instructions
lgkinney
01-18-2002, 12:41 AM
I recently purchased a Nissan Maxima without a warranty and no keyless remotes. Much to my chagrin I had to pay a small fortune for the keyless remotes and then another $75.00 to have it programmed.
In my opinion the instructions should be available in the owners manual -but they are not -
Well I found them and for anyone needing them - these instructions should work for the 1997, 1998, 1999, 2000, 2001, and 2002 Maxima.
There is a good chance they will work for the Altima as well.
Instructions:
1) New ID code has to be manually entered whenever replacing remote control or LCU 05, or adding additional remote control(s). To enter ID code, perform
steps 2) and 3).
2)Close and lock all doors. Erase original ID code(s) by inserting and removing key from ignition switch more than 6 times within 10 seconds. Hazard warning lights should flash twice.
3) Turn ignition switch to ACC position. Push lock button on new remote control once. Hazard warning lights should flash twice, indicating ID code for new remote control has been entered.
4) To enter additional remote control ID code(s), unlock driver's door and then lock it using door lock knob. Press lock button on new remote control once to enter ID code.
5) A maximum of 4 remote control ID codes can be entered. If same ID code is entered more than once, the entry is ignored even through hazard warning light will still flash. To exit progrmming (ID entry) mode, open driver's door.
Good Luck! :flipa:
Instructions:
steps 2) and 3).
Good Luck! :flipa:
Mr Nismo
01-18-2002, 08:21 PM
Thank you for the info!!
patz75
01-17-2003, 08:28 PM
Hi-
could you tell me where you found the information? or do you know if it works for the 1995 maxima too??
THanks~
THanks~
bk2kmax
01-17-2003, 08:31 PM
Thanks my man that is some awesome helpful info.
