keyless entry programming?
theatrebrat
01-12-2004, 06:29 PM
hey i just got a 96 saturn sl1, and i would like to know if anybody has ANY info on programming the remotes to the car for the keyless entry? it has all the receivers the remotes just need to be programmed. i would totally appreciate any info anyone might have
VS1400
01-17-2004, 08:46 PM
With the ignition turned on, you must jump the #4 and #8 terminal, counting from the left, on the top of diagnostic connector, under the left side of the dash. A paper clip works well.
Immediately after jumping the terminals, hold the lock and unlock buttons on the first remote until the cars locks cycle and horn beeps. Immediately hold the lock and unlock buttons on your second remote until the locks cycle and horn beeps again.
Remove the jumper.
This process needs to be done rather quickly and make take a couple of trys if you haven't done it before.
If you're not confident in jumping the terminals, I'd suggest taking it to Saturn. They may even do it for free.
Remove the jumper.
