93 tsi lifter noise and miss
jwokmuba2
12-20-2010, 05:05 PM
okay, so this is my brothers car and i have tried to get him to fix this thing, it runs good now but im worried its going to blow up if he doesnt fix it. no power loss when floored btw.
the car has had a miss since he got it, he running ngk bprses, not sure on the gap, but i think he at .042. the miss is really intermittent, and it only misses in park or neutral, also it idles around 1100 rpm in park and neutral and 850 rpm in drive.
the lifters have started to make some noise just in the last two weeks, and there intermittent also, it will click for a few minutes and then nothing for a few more minutes, over and over.
any help is greatly appreciated
ned032002
12-20-2010, 08:27 PM
1st thing, regap those plugs. They should be gapped at .028 or so. That would explain the miss. lifter noise is normal, when was the last oil change and what oil does he use? What boost is he running and I'm assuming you meant BPR7ES plugs?
david-b
12-21-2010, 08:34 AM
Agreed. Gap is way too big for that car.
Lifter tick is pretty common as the car gets older. It's not really anything bad, but just keep on eye on it. Some people get annoyed and replace them with new OEMs or upgrade to the 3G lifters, which are known for not ticking ever.
ned032002
12-21-2010, 09:10 AM
Also, do a Boost leak test.
jwokmuba2
12-21-2010, 05:22 PM
yes sorry, BPER7ES plugs, and i checked the gap there at .032, still to high?
not sure on oil, probably castrol gtx
is it expensive to upgrade the cams and lifters?
and i dont know how to do a boost leak test, any suggestions?
ned032002
12-21-2010, 08:06 PM
1st stop
http://vfaq.com/
2nd stop if 1st stop wasn't good enough
http://www.google.com/search?q=how+to+do+a+boost+leak+test&ie=utf-8&oe=utf-8&aq=t&rls=org.mozilla:en-US:official&client=firefox-a
check the wires or replace them, that may cause the misfire. I had good luck with .028 and never had misfire. That may not be a fix but it's a start.
1st stop
http://vfaq.com/
LandoAWD
12-22-2010, 07:57 AM
I'd go 6es on a mostly stock car. .028
jwokmuba2
12-25-2010, 12:28 AM
okay, so i gapped plugs to .028, and i misses more, i also changed thermostat, no change in idle but it warms u faster, i think my BISS screw is leaking, there is black rtv all around it like someone tried to adjust it
LandoAWD
12-29-2010, 08:43 AM
Boost leak test.
