Our Community is 662,000 Strong. Join Us.
Please
Register
or
Login
to access:
DriverSide Home
Service & Repair
Car Prices
Parts & Accessories
Reviews & Advice
My Garage
Mitsubishi
Eclipse/Talon/Laser
> Engine, Transmission and Drivetrain
View Full Version :
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
13
Turbo Timer needed
mitsubishi 97 to 91
FMU question
96 Eclipse RS-T 420a Clutch Problem
Clutch fluid leak
NEW BOV in 420a but still have turkey gobble!!!
Turbo Tranny
The big 420a Mystery! Please Help!!!
Evo 8 swap
Garrett or 16g turbo
95 gst does not idle right
98 eclipse spider 2.4 non turbo whirring
Fuel injectors
air intake reccommendations?
Turbo upgrade
Reman crank
intermittant spark on cyl. 2 and 3
Good site to buy a Stage 3 Clutch for a 420a
hooking up tcu
Rke?
Radiator fan/Fuse
Eagle talon 93 with 92 transmission
2nd Gen Eagle Talon Turbo Replacement, Ideal Turbo?
duel exhaust
95 GST trans vs 90 gst trans, can they swap?
Trans Slipping
96 tsi awd swap in a 97 spyder gs HELP!!!
Installing the upper-left motor mount?
Help on removing the lower timing belt cover?
96 Eclipse RS 2.0 non turbo Timing
Wont stay in 5th gear
Broken balance shaft belt
93 tsi lifter noise and miss
Want to turbo a 96 Eclipse 2.0 non turbo
95 talon Backflush?
98 eclipse nonturbo- just turns off. Need help
high boost Q&A
95 talon tsi pcd chip
2.0 oil leak need help
P1494 LDP failure
Head Gasket Replacement?
Rough idle after installing head 94 Talon ES
2g head on a non turbo 1g block?
What year engine do I have?...
Speedometer not working
1998 Rough Running for 2 Minutes & 23 Seconds.
Warning 'lmi turbos'
Thermal Wrap help
1997 mitubishi eclipse
2g eclipse tiptronic transmission??
Need to remove clutch on a 4g64 motor
Help! my talon!
Oil Feed line.
Transmission shaking during takeoff
Will a 420a ECU from a '96 work in '95 Shell?
What Turbo is best for 98 gsx eclipse
92 laser no spark help
1992 tsi turbo 2.0 will not start
Beggining Mechanic who just needs help
Valve replacement - head
2g MAFT question ... PLEASE HELP !!
which spark plugs?
problems with idle
Engine Change
clutch problems
AC removal questions
Transmission Interchange 5 Speed
Turbo mods
Intake manifold vaccum line question
have a problem with my 91 talon
Need help with huge build up!!!
please help
Clutch help?
Burning Oil
Code P1390
help needed
Engine dies once warm
Rear pumpkin seal leaking?
Turbo ecu
eclipse to evo drivetrain swap
18in rims vs speed
95 Eagle Talon Engine Swap ?!?
New clutch, cant remove tranny
94 Eclipse 2.0L N/T ... timing belt jump?
97 eclipse gs non-turbo battery issue
apexi vetic air fuel (vaf) contorller on gsx
Got the motor back!
95 Eagle Talon MAP sensor
Auto to Manual - Reverse lights don't work!
Auto to 5-Spd swap, Speedometer no longer works? HELP!
shift knob
fuel pump not working...
can I use my same rings ?
Super-AFC II in 97 GSX
High Idle
Radiator hoses
turbo to non turbo
engine removal question
running hot
Rattling sound from drivetrain
it got a wobble!?! Help.
Timing belt walk HELP!
supercharger on gsx
420a Clutch how many splines? 17 or 20?
dsm problems
2g 5spd shift cable
1995 eclipse 420a turbo AEM F/IC
Spun bearing
Few questions - mainly references
1998 Eclipse 4cyl. Non-Turbo...Going Limp...Please Help! :(
Rebuild parts list?
Mitsubishi Eclipse 10 point bolt
Rebuild for mula
Eagle talon a/c adjustment bracket
1997 eclipse gs engine swap
Wrong diameter exhaust spacer
1g head gasket set
1991 eclipse in limp mode
can I run my tsi without a waste gate?
engine knocking, rebuild?
oil filter relocation
1990 gsx awd componets to a 1998 gst
vc gasket...felpro
1998 mitsubishi eclipse rs flywheel question
Engine burning oil
TRANSMISSION PROBS(contd)
420a arp Head stud torque
stock valve springs/retainers - 420a
starter grinding
Direct port nos injection
exhaust manifold studs
stuck in 2nd gear
replaced the alternator and battery still wont stay on
Turbo question.
Need help with 93 LSD
DIS BOX help
Hooking up tack in 95 rs.
looking to buy 95 GST ??? help
Ignition tune question
Is this the wrong clutch?
ready to pull the tranny
Please help me!
And another thing...
Kinda random...
driveaxles removial?
ordering parts in 2 days... need gear lube
boost problem
Lights flashing at idel and over 3000rpms
Clutch pedal issues and fuel question
5 speed transmission issue
question about replacing transmission
Oversized valves discussion
TDO5H Turbo
Engine swap 2.0 l DOHC
need help
Idle Surge on cold start
sparkplugs cover in oil
Parts Stores keep giving me wrong parts
???I have transmission issues on a 98 Mitsubishi Eclipse Spyder GS 2.4 non-turbo auto
Transmission Dilemma!!
1997 Tsi Clutch Problem!!
Quick water line question.. need it quick
car runs hot
99 gst turbo BOV
'97 eclipse sypder water pump
Clutch Master Cylinder Question
1998 Mitsubishi Eclipse GS-T Questions
RPMs ticking then car dies??
90 eclipse engine
clutch problem..i think
Valve cover gasket Replace
95 talon wont start - no fuel pressure
someone sell me! ...tax return = clutch time...
Car wont start, with clicking noise.
< 10k on new evoIII16g = Fail???
My car won't start -_-
any other known cause??
Clutch for gsx
pizza delivery guy in need of light to light speed.
Squeaky Belt
check enigine light after new intake
AWD to FWD
95 eclispe gsx: will a exedy FWD clutch work with AWD?
have spark but wont start
Self Proclaimed newbie: Quick question...
headwork
Main Bearings for my motor
non-turbo to turbo
Stevie K is addicted to meth...and doesn't need a intervention
Does the 1st gen DMS 4g63t line up with a 95 Mirage
question about engine swaps
starting problem
What Blow Off Valve is this
Engine Swap
1G and 2G knock sensor question???
Questions about where to buy 6bolt...
is there anyway to get better gas mileage?
Clutch and Flywheel... time to buy!
2.5L Avenger Engine into a 1990 Eclipse?
97 GSX Differential Problem
high hp
Wrist Pin Question
Please Help, '99 AT Mitsu Eclipse won't shift into 3rd
2g mas idling
Trans only works in first gear and Speedo dosnt Work
Battery
1996 OBD location
Transmission buzzing. help!
Block Replacement Pdf's? 1999 Eclipse
low cylinder pressure cause failed emissions?
First start question.
stroker question.
Blown timing belt..., what to fix and estimate of how much?
do i need a new engine?
1995 Eagle Talon ESI Automatic Trans problem
Grounds?
question about the stock bov on a 90 ecipse
radiator hoses...
Leaking HG
intake mani and TB?
transmission!!
AWD or FWD with 4G63T
EVO motor in 93 Eclipse
500+ HorsePower
R these cars xspensive to maintain?
Cylinder 4 missfire along with burnt oil smoke
High Idle...still happening
2.0 non turbo timing belt question
4g63 engionge to different trans?
Time to re-introduce, and entertain ideas on this problem
low end (torque)
Maybe a stupid 2G maf to 1G car question??
Ground locations
2 step with DSMlink
Rods
Stock GSX
oil pan problems
ne1 have dyno sheet for gst/gsx with 16g
top speed
94 talon bad idle!!!
got a 92 eclipse and need some pointers
I need help
How to heat car up quicker
Disconnecting EVAP and EGR
help finding backup light switch wiring
450cc fuel injectors
Cast manifolds vs exhaust studs
best synthetic oil for the winter
Transmission problems pls help
Problem with 1991 Eagle
Automotive Network, Inc., Copyright ©2012
