Seats & Harnesses Installed (LOTSA PICS)
ci5ic
04-11-2003, 11:28 AM
Okay... got my Corbeau TRS seats installed, and the 3-point harnesses too... The seats are comfy as hell, and the retractable harnesses kick bunches of ass. Installation was pretty easy, but there are a few things that came up... I ended up mounting the harnesses to the rear-seatbelt mounting points, but I want to mount them on the C-pillar, but can't find a decent way to do it.
Here's pics:
http://files.automotiveforums.com/uploads/225159smCorbeau01.jpg
http://files.automotiveforums.com/uploads/665818smCorbeau02.jpg
http://files.automotiveforums.com/uploads/658693smCorbeau03.jpg
Harness Mounts... Like I said, I plan on moving them back to the c-pillar at some point, somehow... But it's weird because the retractors have to be at a certain angle to function properly... That angle is adjustable, but not fully 3-axis adjustable, and I can't figure out a way to mount the retractors in a way that the angle can be adjusted to the proper direction...
http://files.automotiveforums.com/uploads/978981smRearMounts.jpg
The front mounts were (for the most part) the easiest part. I was totally stoked to find out that there are mounting locations already in the car, and the eye-bolts that came with the harnesses fit perfectly! I don't know what they are for, possibly floor-mounted seat belts or something, but normally, there is plastic bolts in them, kinda holding the carpet in place, but they are in the PERFECT spot to mount the lap-straps on the belts. The only problem was that there was only one of them on the driver's side, so I had to drill a hole in the exhaust tunnel and bolt it in from under the car
http://files.automotiveforums.com/uploads/397166smFrontMounts01.jpg
Look Ma! No Belts! Well, I took out the entire door-mounted seat belt assembly, which were actually pretty heavy, so hopefully, it saved a little bit of weight. Only problem is that now my seat-belt buzzer won't shut off, so I'm going to have to figure out how to deal with that problem.
http://files.automotiveforums.com/uploads/523950smNoBelts01.jpg
And haven't figured out what to do about this hole yet...
http://files.automotiveforums.com/uploads/624424smNoBelts02.jpg
Someone PLEASE tell me what in tarnation is this doodad? I have two of them, they came with the Corbeau harnesses, and I have no idea what they are for, or where they bolt up at. The harnesses didn't have any kind of installation instructions or anything, so I have no idea...
http://files.automotiveforums.com/uploads/618054smThingy01.jpg
Here's pics of my Si seats which I will be selling, so PM me with an offer if you're interested... The only damage is the upper side-bolster on the driver's seat, which is just worn from getting in and out, but the foam inside is kinda deteriorating, and little teeny tiny bits of it fall out the bottom, so it could probably stand to be replaced with new foam. Other than that, the only other thing is that the plastic side covers are painted bright yellow, but I imagine it would be easy to find replacements or remove the paint.
http://files.automotiveforums.com/uploads/653500smSiSeats01.jpg
Here's a pic of the bolster I was talking about:
http://files.automotiveforums.com/uploads/929620smSiSeatsDam01.jpg
Well, that's it... :sun:
Here's pics:
marked001
04-11-2003, 11:32 AM
damn..they're badass...the color of the harnesses is perfect too :) congrats.
mightytexn
04-11-2003, 11:42 AM
That looks so damn cool....and will the Si seats bolt into a sedan or do they need modification....I know CRX seats dont fit in hatches, but hopefully hatch seats fit in sedans.
ci5ic
04-11-2003, 11:44 AM
Thanks!
I don't know if the Si seats will bolt into a sedan directly, but I bet that if you used the sedan brackets and bolted them to the Si seats it would probably work... ??
Thanks!
mightytexn
04-11-2003, 11:46 AM
Originally posted by ci5ic
Thanks!
I dunno....I heard that CRX seats dont fit right in hatches even with after swapping brackets....if you still have the seats after I get out of school for the summer I would probly be willing to buy them, since I can never find any Si's around here with good interiors.
Thanks!
Santas90Si
04-11-2003, 11:51 AM
I was told that the easiest way to install harnesses is to put a roll bar or some type of bar thats welded/bolted in so that you can mount them right.
They look killer by the way
1PhatCX
04-11-2003, 12:16 PM
looks tight man!
i love em and i hate u ;) hehe
BTW every1. school SUX!!!! :(
Civic Rush
04-11-2003, 12:21 PM
Looks good man. I like it. And as for the SI seats. Hit me up
CHONGO69
04-11-2003, 12:50 PM
All you have to do is unplug this sensor behind the center benzol. There should be a black box behind the radio but near the floor. take the black box cover off and theres a plug that you can pull which will make the sound go away. turn the key so you can hear the beep and you just can hear which plug it is when you start pulling them. I hope this helps cause its hard to explain things by typeing it.
fiercecivic
04-11-2003, 01:25 PM
those r so sweet dude congrats.:cool:
Matt_SC
04-11-2003, 01:31 PM
With the shoulder harnesses, the mounting points should be very slightly the level of your shoulders. I don't know any way to do that in a hatch short of a roll cage, or maybe off a heavy duty rear strut brace. When the mounting points are lower, in an accident, the straps can compress your spine, and cause lots of serious problems. I would look up the SCCA rules for mounting of harnesses, and the Corbeau guidelines as well.
Here's a good link, with a summary of various rules on it. It's not for Hondas specifically, but it good info: Harness Info (http://www.timskelton.com/lightning/race_prep/safety/safety.htm)
GTA
04-11-2003, 05:38 PM
Sweet seats :D
wish my cam wasnt broken so i could take some pic of my new seats...
crxlvr
04-11-2003, 05:49 PM
they look real nice man, i wish i had a pair.
toontowncivic
04-11-2003, 06:30 PM
PPPUUUUURRRRDDDYYY!;)
