motor swap
4thgensvk
03-09-2003, 07:00 AM
I am swapping a B16A in my 91 hatch at the beginning of the summer and i was going to buy the complete motor off of hmotorsonline.com for like 1200 and the hasport mounts and linkage for 400. What else do i need for the swap.
95civicman
03-09-2003, 07:40 AM
it's hard to say because some things come to you broken and not there, so plan on spending like 200 bucks on spare parts just to be safe, and for engine and trans. oil. other than that you just need lots of time.
crxlvr
03-09-2003, 07:43 AM
i got mine from them too, very smooth.
although i already put another grand at least into the motor, and its not even off the palette it came on yet.
91civicDXdude
03-09-2003, 11:02 AM
you gotta figure about another 300 for shipping, plus timing belt, water pump, maybe some sensors, you might have to replace the axles they send you, plus some other maintenance items.
mellowboy
03-09-2003, 11:04 AM
You'll need 90-93 integra axles and u also need the 90-93 intermediate shaft of an integra also. You will need 90-93 rear bracket mount if yours didnt' come with one. Thats pretty much it. For more info go here...www.hasport.com
crxlvr
03-09-2003, 07:14 PM
hmotors gave me the correct SIR axles for the swap you dont need to buy the new ones for a teg.
sciamop
03-10-2003, 12:30 PM
This is a really common question here. This is my personal breakdown:
engine/trans/mounts/linkage $1800 (includes 300 for shipping)
94 Del Sol VTEC timing belt tensioner $48.53
94 Del Sol VTEC thermostat assembly $11.13
94 Del Sol VTEC spark plugs $50.44
94 Del Sol VTEC timing belt $48.1
94 Del Sol VTEC H20 pump $82.55
90-91 Integra ignition wires $45.33
90-91 Integra cap/rotor kit $21.07
90-91 Integra Clutchmasters Level 0 Clutch kit: $212
90-91 Integra Rear engine bracket: $50
94 Del Sol VTEC oil filter: $4
94 Del Sol VTEC Thermostat: $13
90-91 Integra upper/lower rad hoses (trim to fit): $20
90-91 Civic SI front hubs: ??? (junkyard, start looking today!)
Ball Joint/tie rod Separator tool (autozone loan-a-tool)
40FT of 18 gauge wire: $2-3
Solder/Soldering Gun: $20
Good set of tools (10mm-19mm sockets/wrenches, screwdrivers, vicegrips, hammer, 12 point 10mm socket, breaker bar etc): $75-$100 (watch for Sears/Craftsman sales).
Engine Hoist: $?? (rental)
12 quarts of oil (you'll only use ~4 quarts): $15
Antifreeze/Coolant: $6
Tub of MP grease: $4
Lots of Patience: $???? (get some friends to help!)
Is everything else up to spec on the car? Tires? Suspension? Brakes? Cooling?
Use acuraautomotiveparts.net and hondaautomotiveparts.com for all dealer items. Discounted but still expensive.
If you are on a tight budget, you might want to start buying some of the items on the above list now and finish up with the motor purchase (remember LSDs are on back-order). That way everything is sitting in your garage waiting for your attention when the 'big package' arrives.
Todd
91 SI/B16A (50% installed)
