Reprogramming Keyless Entry for a Montana SV6 2005
Nigel18
03-10-2008, 12:21 PM
Ok, I just reprogrammed the keyless entry for my 2005 Montanta SV6 and I wanted to share the procedure with everyone.
I initially found the procedure steps on this forum but they were for Montanas from 1999-2004. But what I did worked
and I wanted to document what how it worked. Below are the original instructions I got off this board.
Keep the windows open as a safety measure, then,
Remove the ignition key from the ignition lock cylinder.
Remove the BCM PRGRM fuse from the fuse panel. Refer to Fuse Block in Wiring Systems.
Close all of the doors.
Close the liftgate.
Turn the ignition lock cylinder to ACC.
Turn the ignition lock cylinder to OFF, and then back to ACC within 1 second.
Open and close any vehicle door. A chime will be heard when the system enters the BCM programming/diagnostic mode.
Important
After 7 seconds, a chime may be heard confirming successful synchronization. It is necessary to wait approximately
14 seconds for a second chime that will confirm successful programming.
Press and hold the transmitter LOCK and UNLOCK buttons simultaneously for 14 seconds.
Repeat the previous step on each additional transmitter to be programmed.
Install the BCM PRGRM fuse back into the fuse panel. Refer to Fuse Block in Wiring Systems.
The confusion in this procedure when working with a Montana SV6 is that there is no fuse called the BCM PRGRM fuse. In the SV6, it is actually the door lock fuse, or #1 fuse in the instrument panel fusebox. This fusebox can be found on the passenger side when you open up the door. Where the door and the dash meet, there is a panel that comes off and underneath is the fuse box. So pull that #1 fuse out. Then I did the ACC steps after closing all doors, but I never heard a chime signaling the start of the reprogramming step. Since I didnt hear a chime, I just held down the two lock buttons on the remote keychain for at least 14 seconds, and when that was done, I could push the lock buttons and see that the parking lights would flash. So then I held down the two lock keys on my other keychain and programmed
that one too. That's it! Turn the car off put the fuse back in, and roll up the windows. All this because the keychain batteries died. The dealer quoted me a price of over $100. They said they would have to reorder new keychains and program it themselves. What a rip off! The batteries cost me $4 on ebay and that was for 6 of them. How dissapointing. Ok, so there is the procedure I used and everything works great! Hope it helps someone.
rockwood84
03-11-2008, 12:18 PM
have to watch them dealers as they have to keep the lights on somehow.
JabbaTHutt
03-13-2008, 01:49 AM
I don't understand what the remote batteries dieing have to do with it.
The remotes should not change codes when the battery dies.
If you take on out now and put it back in there is no reason the the van to stop knowing what it is as the info is stored in the BCM. Keep us informed if you have a BCM problem in the future.
Nigel18
03-14-2008, 05:37 PM
well, I dont know why the batteries dying would have anything to do with it, but all I know is that when I put new batteries in them, they didnt work. They were never broken, just dead. So I had to reprogram the car to recognize the remotes as if they were new.
JabbaTHutt
03-14-2008, 08:29 PM
I saw you have a BCM problem, unless the newer remotes are drasticly differant, but then again a fried was here in november or there about and he had bought a 2006 SV6 and it came with 2 remotes and one didn't work any more. I took it apart have the battery out many times, seems the pads are wore out already, I found a way to fix them, and when he came back I just pushed the buttons to try it and every thing was fine with it. Thing is the codes for the remote are hard coded in the remote. To change them you would have to changed that one big black chip in it or hook it to a programmer and changed it.
Even today I took the battery out of the remote for my 2003 today and sitting here for 5 minutes and put it back in and pushed the lock button twice and the horn honked.
rockwood84
03-14-2008, 11:12 PM
if it was a couple of days or more then yeah the bcm will forget the remote.but it doesn't take long for it to remember once you re-program it. same if the main battery is unhooked from the van for a couple of days the thing has to be re-programed as it forgets everything.
JabbaTHutt
03-15-2008, 01:21 AM
No way the BCM is going to forget the remote if you don't use the it for a couple of days let alone a week or a month.
These things come with the van, they could sit for weeks at the manufactuer's lot before they get put on a train or transport truck to get hauled away to a dealer, and no way are they going to forget all the remotes or even the keys.
My daughter drives our van and has a key and a remote and sometimes its a week or two between her using her key or remote on the van and it has never forgotten it.
These remotes and keys have the info in them hardcoded and the fact the battery in the remote dies is not going to cause it to loose its programming.
My dad has an 03 dodge GC, mom has a key and remote for it, mom has her own car, mom does not drive on snow or ice or slush covered roads, so it could be months before she uses either remote for the van or her car. And so far neither has forgotten the remote.
If you are loosing programming on the remotes I say it is a BCM problem, from the sounds of it you have been having lots of dead batteries in your remotes to come up with this, which again leads me to believe its a BCM problem. These remotes can run for years without changing the battery.
I am sure if we asked people on here if they could tell use on a 4 or 5 year old van when the last time they changed the battery in the remote was and chances are they have never changed it.
rockwood84
03-15-2008, 08:20 PM
tell you what take the battery out of your dads gc and leave it out for two days .put it back in and see what you got.the door locks, remotes, you'll be lucky if the pass-key doesn't shut the motor off.as for the remotes take the batteries out for two days and after two days put the batteries back in and use them most of the time the doors will not unlock or lock.i didn't say the remotes would quit working or that the van will forget them laying around with the batteries in them for months or years........don't believe it try it....the info might be hardcoded in but the bcm will forget.if the battery in the remote dies and you put one in pretty quick then the memory is still there.
JabbaTHutt
03-15-2008, 10:45 PM
So what you are telling me is that my remotes are all sitting here talking to my van all the time and the van is talking to my remote?
I am sorry but GM isn't that bright yet.
As I said before there are many days where my daughter never uses her remote, it never talks to the van for days on end so the BCM should have forgotten her remote buy now.
rockwood84
03-17-2008, 11:19 PM
jabba, did you take them batteries out and wait two or three days and then put them back in and see if it works or not.. cause i ain't got time or patience to argue over it....how is the bcm gonna talk to the remote or the remote gonna talk to the bcm if no ones pushing the buttons on the remote?
jwulf1092
04-21-2016, 12:34 AM
I KNOW this is a very old thread.... but it is tops on my google results and I have a similar problem....
I follow the steps, removing fuse#1 as my 2005 Montanan SV6 does not have a BCM fuse...
Closing the passenger door (has to be open to remove the fuse)
Getting in on drivers side and closing the door, key in, turn to acc position, then off, then back to acc within 1 second.
Open and close drivers door....
But I can not get the beeps to tell me it has entered programming mode. So I hold the lock and unlock buttons on my new remote together for approx 14 seconds. But no joy, my brand new remotes will not program up. No lights blinking, nor doors locking/unlocking, after putting the fuse back in.
Any help here would be greatly appreciated!!!
Sincerely Mr. Wulf
Tech II
04-21-2016, 03:44 PM
Several things......
Normally, if the remote dies because of a battery, just install a new battery......sometimes, you may have to hold the lock and unlock buttons at the same time for more than 10 seconds, and the horn will chirp, and everything is ok....
Changing remotes is a whole different ball game.......if the procedure is not followed to the letter, it will not program.....
Another thing is, are you sure you have the correct remotes......remotes look alike, but if you do not have the correct P/N on the back of the remote, it's the wrong one.....are you sure the remotes even work?
Another thing, on some vehicles, you can only program so many remotes to one vehicle....if someone else had the vehicle before you, maybe the slots were used up as remotes were lost/replaced.....
Your last resort, it to go to a dealership....they should only charge you 0.5 hours of labor(at their rate), to program remotes.....they need to check that the remotes send out a signal(they have a special tool to test this), then they use a Tech II scan tool, clear slots if needed, and program the remotes.....
PGFolks
12-31-2017, 12:08 PM
I have a 2005 Pontiac Montana SV6 and purchased two new key fobs from Ebay. After trying the procedure posted here to no avail, I had a lock smith who specializes in keyless entry look at it and he used a scan tool, but was unsuccessful as well. He determined that the key fobs were functional, but had an FCC code that is not compatible with my vehicle. Could you help me determine the correct FCC code so I can try to purchase a key fob that will work?
Tech II
12-31-2017, 02:06 PM
I am not sure what procedure you used, but I think for your vehicle, you need a Tech II scan tool to program the fobs.....
Since your locksmith has determined that your remotes are functional, you must have the wrong fobs.....
What you can do is call any local GM dealership parts department, and ask them what the P/N(part number) should be on the back of the fob....if you look at the back of your keyless entry fob, you will see P/N followed by a number......the number the parts guy gives you should match the fob.....if it doesn't it's the wrong one.....
PGFolks
12-31-2017, 09:26 PM
Thank you TechII for taking some of your valuable time on New Year's Eve, no less. Yes, the lock smith used a scan tool and was convinced these fobs were the wrong ones, but since they don't have any part number identification (cheap knock offs purchased at Bay) we have no way to confirm it. I can maybe get a correct GM P/N from a dealer and seek one from the internet. Thank you for your suggestion.
Tech II
01-01-2018, 12:19 PM
Just one thing.......I was looking up a key fob for you......and found generic fobs that fit a 2005 Montana on Amazon......but the info says, it will NOT WORK with a SV6 model......so I guess that fob is year/model specific....
PGFolks
01-01-2018, 03:37 PM
The SV6 model of the 2005 Montana has a unique Driver Information Center module that apparently required a unique keyless entry code. The key fobs that I purchased were supposed to be specific for the 2005 Montana SV6, but obviously were not so they weren't programable even with the scan tool that the lock smith used. I haven't had any luck searching for the key fob part number yet, but haven't exhausted all resources. The lock smith thought if I knew the FCC code, I might be able to locate an after market key fob that would work, but so few of the supplier's have any knowledge of that info on their electronic products that may not be all that useful.
PGFolks
01-01-2018, 03:51 PM
I found this report on a website that I thought might be worth sharing. Apparently the FCC code does not assure success in key fob programming! The GM Part number appears to be the only useful identifier. I'm starting to learn more about this subject than I ever wanted to know:
Key Fob News – The Automotive Remote Experts’ Blog
Searching for a Replacement Remote Control by FCC ID Number
Posted on November 22, 2013 by admin
I saw something on an ebay product listing that was so wrong I just have to write an entry here to refute it. A certain ebay seller has a product information “guide” showing as part of the listing for a remote key fob. That guide says that as long as you match the FCC ID on your original remote with the one you are buying, you will get a remote that works for your vehicle. This is not true. The FCC ID of a part relates only to aspects of a remote transmitter related to radio transmission characteristics that are important to the FCC for purposes of regulating and licensing. An FCC ID is not specific to the information being transmitted.
There are numerous examples of remote transmitters with the same FCC ID that will not work in place of each other. Here are just a few examples:
Perhaps the best example is GM remotes with FCC ID KOBGT04A. Remotes Unlimited sells 13 unique remote SKUs of GM parts with this FCC ID number. There are more than 13 GM part numbers for these 13 remotes, but from a functionality standpoint, there are 13 unique key fobs. These 13 parts break down into 4 separate “families” of remotes that are not cross-compatible. Take two of the most widely used of these parts: GM remotes 15252034 and 22733523. Not only do these two 4-button key fobs have the same FCC ID, they are visually identical (except for the GM part number). To make the situation more complicated, they were both used on some of the same model applications, such as the 2006 Buick Lacrosse. They are not interchangeable! If you try to use remote 22733523 on a vehicle that originally used remote 15252034, it will not work!
Another example, from the aftermarket alarm system world, is FCC ID H5LAL777A. This FCC ID appears on numerous aftermarket alarm system remotes. To distinguish among the various key fobs, one has to know the printed circuit board number.
There is a tendency to believe what you read if someone states something in an authoritative way. Well, this particular ebay seller is just one example of a person selling remote key fobs without knowing what they are talking about. There are many others.
Tech II
01-01-2018, 09:08 PM
Found these numbers:
https://www.gmpartsdirect.com/auto-parts/2005/pontiac/montana/sv6-trim/3-5l-v6-gas-engine/electrical-cat/keyless-entry-components-scat
15224376 costs $93.98 MONTANA SV6; W/ POWER SLIDING DOOR; W/ REMOTE START
found on Amazon for $10.95
https://www.amazon.com/s/ref=nb_sb_noss_2?url=search-alias%3Daps&field-keywords=15114376%09
So look up the correct number on gmpartsdirect and look up the number on Amazon
PGFolks
01-02-2018, 07:37 AM
Once again thank you Tech II for your useful information. It looks like my 2005 Montana SV6 w/o remote start or sliding door takes GM p/n 15100811. I found several suppliers at Amazon and Ebay that sell that p/n for a reasonable price so thank you very much.
