95' clear headlights??
Sanchi
02-24-2003, 10:41 PM
:wave: hey everyone, well does anyone know who makes the clear headlights for the 95' 96' s14 240sx. mine are kinda turning yellow :bloated: :bloated:
and im not talking about the shark eyes, not the s15 headlights the boxy oval one but clear... any help would be appreciated!!!!
NISSANSPDR
02-25-2003, 10:11 AM
Umm if your headlights are turning yellow...why not clean them? Use a product called Astroshield on them...it will make them look like new...can be found at your local Discount Autoparts or try Pep Boys.
Now if you really wanna get cool...buy the glass Euro headlights for the 240SX (called the 200SX over there)...they are around $800 bux so beware
Sanchi
02-25-2003, 05:19 PM
thankx NISSANSPDR, i kinda want my car to have newer looking headlights... i want to see the bulbs i guess thats what im saying. i was searching for some and i came across something call the 200SX and i though it was refering the to car. guess ill check it out again thankx.!!
J SPEC SilEighty
02-25-2003, 05:27 PM
:drool:
Sanchi
02-25-2003, 07:02 PM
:eek: :eek: HEY HEY THOSE ARE THE ONES THAT I WANT!!!! J SPEC HELP ME!!!!!
hehe :D :D well that is exactly what im looking for anyone have any ideal who makes em im drooling over here:bloated: :bloated:
:bloated: :bloated: :sun: :flash:
J SPEC SilEighty
02-25-2003, 07:21 PM
hehe those are the glass headlights that came on the european 200sx that NISSANSPDR was talking about. they are pretty hard to find over here and when you do find them, they are going to cost you a pretty penny
Sanchi
02-26-2003, 02:47 AM
wait so the european 200sx the 200sx that we have in the states. the european's get cool looking headlights on the 200sx and they just happond to fit on our 240sx s14 in the US??? is this what your telling me?!?!?!?! man that blows how we dont have that over here. would there happond to be an alternative to those glass lamps but kinda the same thing???? i like the clear look. ?!?!?!?!!?
:confused: :confused: :sun: :flash:
J SPEC SilEighty
02-26-2003, 07:17 AM
the european 200sx is the same as our 240sx. they just call it the 200sx. so those lights come on the european s14 200sx, same as our s14 240sx
NISSANSPDR
02-26-2003, 09:09 AM
The reason they call it the 200SX is because of the motor...2.0 Liters Turbo...so it's a 200SX...it's identical to the Silvia in all respects...
If you have the money to shell out...get those headlights
:devil:
Sanchi
02-26-2003, 05:35 PM
ohh thakx for the clear up i was gona say the 200sx over here gots the same headlights as the 240sx thats strange :confused: :confused: :rolleyes: but ya all clear now. getting the money for those glass euro lamps is gona cost alot less then getting a conversion for my s14 i supose. and everyone and their mama is getting a dam conversion even on their lil civics. i think the headlights now look good just need to look newer.
:( :( bad news is ive had zero luck finding anywhere that has them :cry:
:cry: :cry: :( :mad:
Sanchi
03-03-2003, 09:57 PM
okay guys anyone know how to take the headlamps out im haveing a real hard time disconnecting the side lights from the center lamps. this thing is super child proof. have too clean the insides of the headlamps, its yellow and kinda sick!!! wish it was air tight like the sides though... so any help would be appreciated thankx again guys!!!
TatII
03-03-2003, 10:46 PM
or you can simpily take your headlights apart and spray paint them to look like this guys.
Sanchi
03-03-2003, 10:59 PM
but thats the problem... i cant seem to take them out the way its designed it feels like something is gona break. and every angle i pull there is something blocking it... just got fustrating i guess.. anyone got any advice on how to take it out or am i just a pussy and should just yank the sucker out.... :( :(
TatII
03-04-2003, 05:02 AM
well its the typical headlight trick. you have to put it in the oven, and bake it for sheesh i forgot how long. can't do it for too long or else you'll melt the whole sucker. but after you get the glue to melt for long enough, you can pry the sucker open. then you have to mask the reflective material, after your done painting, you have to get like glue and glue it back together. ask jspec he'll know what to do.
J SPEC SilEighty
03-04-2003, 08:01 AM
yes it does feel like its going to break when you try to take the corner lamp off the main headlight. When I took my corner lamp off a couple of weeks ago to change the bulb in it, I thought I was going to break it taking it off. but the easiest way I found out to do it is first remove the main screw up top that you can see. then at the rear of the corner light it is held on to the fender with 2 small tabs. just pull at the rear of the corner lamp and that will pop out. then the part that I think your talking about that is going to break is where its connected to the main headlight down below the screw that you originally took out. what I did is sort of pushed the corner light to the side as far as I could and then stuck a screw driver in there and just pried the corner light off. It is connected with a ball joint type thing. I'm at school right now but I'll take some pics of how to do it when I get home if you want.
TatII
03-04-2003, 08:31 AM
ooooooo, if your talkina bout not knowing how to take the corner lamp off, its easy. like what j spec said. on the top corner of the headlight facing the fender. there is a screw. that screw keeps the corner light from falling off. so all you need to do is unscrew that one screw and you just pop the light right off. its held on by a ball cup thing that is connected to the headlight. it takes like 2 minutes to take off and put back on. its really that easy. :cool:
Fliquer
03-04-2003, 10:49 AM
OMG I want Euro lights now!! WHY DO WE GET SCREWED OVER LIKE THAT???
BTW: Are you sure the euro-spec headlights are glass? Because it seems to me that glass would be too fragile a material to put on the front of a car...one little pebble at 40mph will probably smash it.
J SPEC SilEighty
03-04-2003, 12:11 PM
yeah they are really glass.
SE-R WolfPac, Here's some pics to help you get the corner lights off so you can get the headlights off.
1. remove this screw
http://files.automotiveforums.com/uploads/8707201.jpg
2. this tab is holding 2 plastic tabs on the corner light. just pull on the corner light and it will pop out from behind this tab.
http://files.automotiveforums.com/uploads/1133502.jpg
3. do what I said earlier and move the corner light as far away from the headlight as you can and stick a screwdriver in between the corner light and the headlight. then push the handle of the screwdriver towards the headlight and the little ball joint thing holding the corner light on will pop out. here's a pic of where the ball joint is connected on the headlight. once you have it removed, you can get to the remaining 2 headlight screws, which can be seen in the pic.
http://files.automotiveforums.com/uploads/9391193.jpg
Sanchi
03-04-2003, 05:26 PM
WOW thanks J SPEC, your the greates!!!! well last week i took the top screw off yanked at it till it couldnt move no more because of the top piece that had the screw. i was afrad that lil ball screw tab thingy would snap off it is plastic and all. i was useing a flathead screw driver to try to pry the sucker out just i gave up on fear of breaking it. but thankx guys now i know that is the only way to do it no fear now !!!!!
ya would still like the euro lamps :bloated: :bloated:
do we got anything like that at all for the s14, any diffrent headlights at all??? or are we stuck with these unless we do an entire front end conversion :(
:D :D :sun: :flash:
NISSANSPDR
03-04-2003, 06:10 PM
He's ok I guess :rolleyes:
LOL jk...he's a post enthusiast over on 240sxForums so he gets all these goodies
