ZC motor??
CRXsk8er
02-16-2003, 09:17 PM
this is prolly a stupid question but what kind of car is a ZC engine from???thanks
90civichatch
02-16-2003, 09:24 PM
4G JDM Civic Si and CRX Si
CRXsk8er
02-16-2003, 10:02 PM
oh ok......so if i want to buy sum stuff for it i just get the stuff that fits a crx si???? thanks
CRXsk8er
02-16-2003, 10:03 PM
stuff that is made for a crx si......??
seth 90DX/ZC
02-16-2003, 10:20 PM
LMAO! Like what? Ya cant barley find shit for it! I own one that I'm building... If you have any questions PM me... But uh... know this, if you want more HP out the DOHC ZC your gonna have to do internals (Pistons Rods EX) Hit me up when you start trippin ;)
CRXsk8er
02-16-2003, 10:25 PM
well...........i dunno thats why i was asking.......
seth 90DX/ZC
02-16-2003, 10:49 PM
Check it out dude, yuo can use the aftermarket pistons/rods from the D16A1 86-89 integra... You can get the cams reground by a few places or buy new billet ones from HKS for TAXED! They arent that great iether! 10-15 Hp for the hks, they cost like $480 EACH so like almost $1000 for 10-15 Hp... ROFL! Im getting mine hard welded and ground for like $500 to MY specs ;) the Hks ones dont go over 7200 Rpm's... BAH! OUTRAGOUSE!
Oh, here is a list of stock parts you will need to rebuild the engine ;) Its been sitting around along time!
Engine Mounts:
1988-91 Civic/CRX; any
Timing Belt:
1988 Prelude 2.0; 14400-PK2-004
Spark Plugs:
1986-89 integra; NGK BCPR6E-11
Plug Wires:
1986-89 Integra; any
Oil Filter:
1988-89 integra; 15400-PR3-004
1988-89 integra; Fram PH3539A
1988-91 civic; 15400-PR3-004
Headers:
1986-89 integra; any kind
1988-91 civic si; modified sligtly
1988-91 zc top with 92-95 si bottom; hangs low
Radiator Hose Upper/Lower
Upper: 84 honda accord
88-89 integra universal ``autozone special`` cut to fit
Lower: 91 Civic
Throttle Body/TPSensor:
1988-91 civic si
Cam Angle Sensor:
1988-89 integra
Distributer:
1988-89 integra
Distributer Cap:
1988-89 integra
1988-91 civic si
Distributer Rotor:
1988-89 integra
1988-91 civic si
Head Gasket:
1988 Prelude; 12251-PM7-003
Intake Gasket:
1988-89 integra; 17105-PG6-S00
exhaust gasket:
1988-89 integra; 18110-PG6-003
Oil Pan Gasket:
1986-89 integra
1988-91 civic
Water Pump:
1988-91 civic; 19200-P01-004
ECU:
1988-91 civic si
1988-91 civic zc
1988-89 integra; change case for mounting
AC Compressor/Bracket:
1988-91 civic
Clutch/Pressure Plate
1988 civic if using 88 tranny
1989-91 civic if using 89-91 tranny
Engine Mounts:
Timing Belt:
Spark Plugs:
Plug Wires:
Oil Filter:
Headers:
Lower: 91 Civic
1988-91 civic si
Cam Angle Sensor:
1988-89 integra
Distributer:
1988-89 integra
Distributer Cap:
1988-89 integra
1988-91 civic si
Distributer Rotor:
1988-89 integra
1988-91 civic si
Head Gasket:
Intake Gasket:
exhaust gasket:
Oil Pan Gasket:
1986-89 integra
1988-91 civic
Water Pump:
ECU:
1988-91 civic si
1988-91 civic zc
1988-91 civic
seth 90DX/ZC
02-16-2003, 10:59 PM
Hpoe that helps ;) Did you buy one?
CRXsk8er
02-16-2003, 11:00 PM
thats alot of shit but i think im just going to put the engine is stock and just put bolt ons on it for now then when i get sum money ill buy another engine...and build that, i could built it till i get it perfect and then swap again......im pretty sure that is what im goign to do cause i just blew my engine and i need a swap before i get my license.....so....that list you sent that all stuff i would need to rebuild the engine not to swap it right??....thanks
Skeme1
02-16-2003, 11:04 PM
zc info:
http://thenew.gamesbbs.com/~dmoore/zc.htm
use the search functuion too, theres always a zc thread every week
seth 90DX/ZC
02-16-2003, 11:28 PM
Well, it would be retarded to put in the zc without doing a rebuild! I may only have 35-60,000 miles on it true, but it has been laying around for YEARS! Mine is a 91 (Lucked out) From what Hmotors tells me its been sitting around only 5 years... Thats right I got one of the cleaner ones! So a rebuild is iminent! You can just drive off with it, but I would resleeve the bitch!
seth 90DX/ZC
02-17-2003, 12:29 AM
Hey I just found out I can order parts from JUN IN JAPAN! :eek: I just finished talking to one of the guys there! :huh: He said that a pair of JUN cam gears MADE ESPECIALY FOR THE JDM DOHC ZC (Well of course there in japan!) Will cost $331.78 shiped! I had to fugure that shit out with the current rate of exchange ;) Ima whatch the rate of exchange and start ordering parts from japan! Ill bet I can get down to $300 shiped if I wait :) Dude! Thats badass! You dont even know how badass it is to have a hook in japan! Good thing dude speaks english cool! Im gonna get NEW OEM parts from japan for this bitch!
