Window Masks for Mitsubishi GTO - Here
Hiroboy
02-14-2003, 06:31 PM
As with the previous posts, I here made some masking templates for the windows for spraying of the Tamiya GTO and have uploaded them here :
Illustrator ai Format (http://www.spc.org.uk/misc/mitsubishi_gto_window_mask.ai)
EPS Format (http://www.spc.org.uk/misc/mitsubishi_gto_window_mask.eps)
PDF Format (http://www.spc.org.uk/misc/mitsubishi_gto_window_mask.pdf)
Print them out on paper and cut then test for scale, they should print correct. If correct, stick Tamiya 18mm wide tape over the top and cut them out, peel off paper and fix to inside of clear window unit, then spray with Semi-gloss black, (airbrushing is best) remembering to apply in light coats.
http://www.hlj.com/images/tam/tam24108box.gif
Enjoy
TURBO_EK4
02-14-2003, 06:43 PM
Do u happen to have some for the tamiya r32?;)
