Altezza style rear lights...
flyonthewall
11-17-2002, 11:07 AM
http://files.automotiveforums.com/uploads/701084AltezzaLights_IkonAutowerks1.jpg
http://files.automotiveforums.com/uploads/562181182126_36_full.jpg
Here's what i'm doing to my upcoming Kaminari Celica build. The bodykit is now 100% complete btw, so you should see details appear on the site later in the week. I really liked the look of the rear cluster's available for the Celica as pictured above so i had to give them a go. Unfortunately its not possible to do these as a product coz it'll be too complicated, unless the clusters were seperate in the kit to begin with.
I neglected to take pics throughout the progress of this but you should get the idea. The first part i did some time ago (no pic) when i was experimenting to see if this was possible, this was to remove the detail from the back of the kit lenses. I managed this by scraping and sanding then finally polished them out with a cotton bud in my dremel and some cutting paste, they turned out ok.
The lens housing is made from styrene tube, when a short length was glued in position it was cut and sanded to shape - quite a fiddly task!
http://files.automotiveforums.com/uploads/3190031.jpg
The lenses themselves are from MV Products, they are used in railroad and military modeling. I think most of our US members would have come across these before. to fit them into the housing, i glued them to the end of a smaller diameter tubing which will slide inside the other.
http://files.automotiveforums.com/uploads/3318082.jpg
http://files.automotiveforums.com/uploads/3686473.jpg
http://files.automotiveforums.com/uploads/8104842002_1117_151537AA.jpg
http://files.automotiveforums.com/uploads/3113204.jpg
Ideally, i need to scribe the 3 lines in the lens but i'm not sure that i'm brave enough to attempt that, we'll see! Hope this has been helpful and given you ideas for your projects.;)
http://files.automotiveforums.com/uploads/8703705.jpg
[S]ky|ine
11-17-2002, 11:34 AM
Wow, thats nice!!! Did you paint the chrome paint at the rear lights??? And hope to see the finishing pic!!!
Forhod
11-17-2002, 11:45 AM
You did a great job on the drilling. BTW, how you do that? :tips: !
Nice idea of using the lenses.
I wonder if I can fnd them in Singapore.. :rolleyes: :confused:
[S]ky|ine
11-17-2002, 11:48 AM
Yup... it seens no where have sell in singapore but maybe David's shop have it!!! I have think before making some euro tail lights but i can't find any lense!!! lolZ
:D :D :D
TheSyndicate
:eek:
I bow down to your skills! I can't wait to see that thing finished!
flyonthewall
11-17-2002, 12:41 PM
I have come across a couple of place online which stock them;
http://www.walthers.com/exec/page/manuinfo/v516
http://www.discountmodels.com/m.v._lenses.htm
and i think hobby heaven have them too
I drew around the tube at the postion i wanted it. I drilled in the centre of the circle with small drill in a pin vice -1.6mm was the largest i had. I then opened up the hole with a knife then filled away upto the edges of the circle.
Forhod
11-17-2002, 01:13 PM
Geez, thanks for the tips!
wkma7six
11-17-2002, 01:32 PM
[IMG]
Hey Chris. Here's a tip for you 3 scribed lines. I use this technique learned from model airplanes panel line rescribing.
Try to find some Dymo label tape. I think they're also under the name Rotex. These are usually found in office supply stores. Cut them into very fairly thin straight strips and since they're self adhesive just remove the backing and apply to your clear part and carefully scribe a thin line with you scriber of choice.
Hope this will allow you to add your final details.
-Walter
hiver77
11-17-2002, 01:34 PM
Hi Chris,
what's size are those lenses? I'm guessing ~ 0.2" - 0.3"?
supratuner
11-17-2002, 01:39 PM
damn ... those lights are bad
im gonna try to do that now
Integra14
11-17-2002, 01:40 PM
those are really sweet.. could u do like a progress steps for that?
Suislide
11-17-2002, 02:05 PM
AAAH!!! RICE LIGHTS!!!:eek: :eek: :D :D
just kidding dude. while i hate those lights (way too overused these days, and they were ugly to begin with), i have to admit you did a really good job on them and your technique of making them was awesome.
flyonthewall
11-17-2002, 02:49 PM
Originally posted by hiver77
Hi Chris,
They're 5.5mm or 0.2165" (http://www.convert-me.com/en/convert/length) to be exact!:flipa: The product code is L210.
-Walter
Thanks Walter, i had thought about doing it in a similar way with masking tape. If you lay down 3 or more layers, one on top of the other, it will give you a good edge to use as a guide. I want to scibe the lines on the inside of the lens so the Dyno method won't be flexible enough to stick down i'm afraid. May main concern is spacing them apart equally.
RyanGiorgio
11-17-2002, 03:23 PM
THats really creative. It looks just like the ones in the pictures.
primera man
11-17-2002, 03:35 PM
ONCE AGAIN YOU SHOW US YOUR BRILLIANT MODELLING SKILLS !!!
First class job......looks so much better. Almost looks like the real thing.
Awesome work Chris
Honoturtle
11-17-2002, 04:02 PM
Wow, that's amazing! You did a good job with that thing! I think I'm going to give it a shot!
[S]ky|ine
11-18-2002, 12:29 AM
Did you do some custom bodykits??? Your celica rear bumber looks nice with that tail lights!!! Great job and keep up the good work!!!:right:
kicker1_solo
11-18-2002, 12:51 AM
oh deer God, make it stop. Altezzas are crap, but good job. :)
Focus2000
11-18-2002, 04:29 AM
More useful tips to add to the list of bookmaked how-tos. Thanks Fly!
Guido
11-18-2002, 04:32 AM
We're talking Celica's here :D :finger: :D
Hi Chris,
That is really really good!! very much like the idea and even more the execution. But that's as usual.
Guido
Jonno
11-18-2002, 06:37 AM
Were you being sarcastic :confused:
Veyron
11-18-2002, 08:10 AM
Very nice touch! Keep up the rockin' work!:D
NoBrakes
11-18-2002, 10:33 AM
Has always you don't stop to amaze me. they look so good. i'm trying something similar with LEDs in my Lude.
Cheers
flyonthewall
11-18-2002, 10:47 AM
Originally posted by NoBrakes
Has always i don't stop to amaze me. they look so good. i'm trying something similar with LEDs in my Lude.
Cheers
LED's will look great and this is perfect for them, they will just slot right inside. Should be an easier task on the lude too! Keep us posted, can't wait to see your version.:)
greyfoxtb
11-18-2002, 11:15 AM
wow, Nice done! :)
also your celica is beautifull !
Good job!
fullbloodchop01
11-18-2002, 02:33 PM
:flash: damn looks perfect:flash: hope this will inspire more altezza lights:frog:
giordano
11-18-2002, 04:03 PM
whoa! great job! can't wait to see it done. btb, 'bout skirts(ground effects) how do you know if it's even, i mean from one side to the other?
supratuner
11-18-2002, 05:16 PM
dang i love those things so good
they make me want to drop my pants:D :finger: :finger: :finger: :finger: :finger: :finger:
flyonthewall
11-18-2002, 06:55 PM
Some of it can be done by eye but usually its a case of measuring carefully.
