Help!!!!!!
silver89civic
07-30-2002, 11:06 PM
I accidentally dropped a small piece of metal inside the spark plug hole (the one next to the steering). How can I get the piece out???
I tried a magnet but it's damn hard. Any one has a diagram of the tubing?? help!!!!!!
ci5ic
07-30-2002, 11:10 PM
Whooo! Ain't that about a bi+ch! That sucks. Have you tried using one of those telescoping magnets, or was it just a regular magnet of some sort?
It might make things easier to remove your valve cover.
FourthGenHatch
07-30-2002, 11:11 PM
The valve cover is easy enough to get off, and a telescoping metal thing would be good. But if you take out the spark plug isn't that a direct opening into the cylinder. Sounds like bad news.
silver89civic
07-30-2002, 11:15 PM
I took off the valve cover but I can't still see anything. I think the hole should be straight, but I tried bending the magnet left/right & I think the tubing does curve. Any of you know where does the tube leads????
Man, this is bad, I gotta take that piece out, help,help,help!!!
FourthGenHatch
07-30-2002, 11:30 PM
I don't think the tubing curves. I think rather the spark plug is at an angle above the cylinder chamber and the valves would be on the sides. Perhaps you can manually turn the cam gear and make the cylinder come up as high as it can so you can get to the thing inside easier, but that would be very hard.
silver89civic
07-30-2002, 11:35 PM
can you show me a pic or a drawing? Im not good with engines yet, Im still learning.
Do I have to pull the head out & how? Do I need to put a new head gasket if I do it?
FourthGenHatch
07-30-2002, 11:46 PM
I have no idea where I would get drawings from...
silver89civic
07-30-2002, 11:53 PM
__________________________________________________ __________
How do I do that?
ci5ic
07-30-2002, 11:54 PM
Okay, here's a pic. The red arrow is where the spark plug goes. The blue arrow is the valves, and the big black blob is whatever you dropped in there. It should be pretty easy, especially if you manually turn the crank to bring the piston up to top dead center. Hope it helps:
Edit: another thought... It could be that whatever you dropped in there might not be magnetic... I don't know what it is, but it's a possibility...
http://files.automotiveforums.com/uploads/248392DEBRIS.jpg
Melt
07-31-2002, 12:00 AM
did you try the telescoping magnet yet? Those things are lifesavers, I kept dropping the screwes when I was putting in my clears into the bumper, and that got it out with a quickness. Hope you get that shit out of your engine!
silver89civic
07-31-2002, 12:04 AM
Thanks ci5ic, Thats big help!! :)
The piece is magnetic cuz I have extras & they stick to the magnet.
so how do I turn the crank?
silver89civic
07-31-2002, 12:39 AM
My bad, I take it back. The metal piece doesn't stick a whole lot. Its magnetic but how would I get out something that is not really so magnetic? & again, how do you turn the crank?
I appreciate your help...
silver89civic
07-31-2002, 10:24 PM
Good news!!!! My friend got that metal piece out of the plug hole :)
He turned the crank & then with a stick plus bubble gum got the metal piece out!
So thanks to everybody 4 helping me out!!
ci5ic
07-31-2002, 10:31 PM
You know McGyver?!!!
silver89civic
08-01-2002, 12:42 AM
hahahha! Thats right, in person:flipa:
superccs
08-01-2002, 05:42 AM
nice going
next time why dot you just fill up the cylinder with mercury and then the peice of shit will float to the top and then you drian the mercury...
just dont play with the mercury afterwords...
but hey thats for next time...
probably in another 100k miles ; )
jk
silver89civic
08-01-2002, 06:37 AM
Originally posted by superccs
nice going
jk
hehehe :silly2: ... There wont be a next time, trust me. Ive learned my lesson.:bandit:
zcmadman
08-02-2002, 11:36 PM
man you got waaay lucky w/the buble gum trick! you couldve had a sticky situation. what kind of gum was it? did ya chew it after you were done, or stick it behind your ear for good luck? i sure would! you otta send that to the gum maker and say how good theyre product was! no you just got lucky on that b/c you were screwed!
:help: :uhoh:
Doc1020
08-05-2002, 02:34 PM
LOL:hehehe: , not thats a real mans tool, lol.
