new member pics
MoReace
08-10-2001, 01:46 PM
I'm a new member so I thought I would post a few pics. I haven't done anything too special to the car.
I habe a Razo shifter which I broke the bottom part to when installing and an ignited push button starter in the dead switch next to the rear defroster. I did ok w/ that one.
I also have the 99 G20 rims on and put amber 85 watt bulbs in the fogs and regular in the fogs.
Apparently the pics are too big to attach. If u mail [email protected] I will send them to you (they are nothing special) or I can try to take the pics w/ my friends camera so they are smaller files.
A local shop suggested that I let them paint the amber part of my rear lights red. I would be curious to think what u guys think? They actually do a good job at the shop. U can't tell that it isn't from the factory. My friend made this for me. I can send that pic via e-mail too.
Thanks everyone
95 G20t
dark greeen/ black
34,000 miles
NismoPC
08-10-2001, 02:41 PM
Could you send those pics to me at [email protected] ?
I have been trying to imagine what the 99 rims would look like on my 96 G20. Want to upgrade rims/wheels, but keep somewhat stock appearance.
Also, what size tire did you opt for? Was thinking 195/60-15 would work well since the stocks are 195/65-14.
Thanks!
:flash:
MoReace
08-10-2001, 03:42 PM
I got them on ebay w/ the stock tires. These were too big though. With weight in the car the rear tires would grind against the top of the wheel well. I got about 3/4" lower profile Dunlop D60 tires. This still gives it the stock look. I will tryan get my friends camera and get u some better pics of the rims on the car. My tires are currently P1856H15 DN D60A2. Let me know which way u decide to go. Good luck. Also w/ the stock tires I had to put wheel spacers on in the rear. The tires still rubbed for a while untile I wore them down. I sent u a pic. :bandit:
NismoPC
08-10-2001, 10:31 PM
:licker:
NismoPC
08-10-2001, 10:32 PM
I posted the pciture for you by redefining the dimensions on it. Once you get the other pics, see if you can post them too. If not, send them to me and I'll post them for you!
:smoker2:
kenchan
08-10-2001, 10:42 PM
huh! those p11 wheels look goood! on the p10's. :D good job
MoReace
08-11-2001, 12:12 AM
I will take better pics and get them up soon
NismoPC
08-11-2001, 08:07 AM
MoReace
Here are the other two pics you sent to me:
MoReace
08-12-2001, 04:23 PM
The new pics I promised all of u
MoReace
08-12-2001, 04:27 PM
Above: Strut Bar
Below: Custom, that's right, a homemade popcharger
MoReace
08-12-2001, 04:30 PM
New pics for u who are interested in upgrading to new the new rims
MoReace
08-12-2001, 04:34 PM
more angles
MoReace
08-12-2001, 04:40 PM
The rims look better than the pics show. They look good moving too.
NismoPC
08-12-2001, 08:48 PM
MoReace
Those rims look really nice on the P10's. I am pondering the thought of doing the same thing. I actually thought of bidding on them when they were on eBay. A dealer in Florida had a set of them go for $250 plus shipping. Oh well, maybe next time around.
Swonder67
08-13-2001, 03:17 PM
Hey MoReace, the rims look nice. Your homemade Pop Charger looks AWESOME! Your friend must be a pretty good engineer.:sun:
GtRider
08-29-2001, 11:09 PM
hey MoReace
that home made pop charger looks wicked!!
how did you make it?
MoReace
08-30-2001, 10:35 PM
First you have to take out the airbox. On the inside there is a golden ring w/ 4 screw holes that u have to pop out. Try not to bend the base too much. This piece gets bolted back onto the end where the box was just removed. U can use silicone around the edges to keep it air tight. This is where you will have to use your imagination. I was able to use an airduct tubing from a friends leaf blower. It already had a plastic piece at the end that was 4" and went to 3". the cone filter fir perfectly on the 3" side and is secured by a circular metal clip. The tubing was bendable and fit nicely over the gold ring. This side was also secured my a circular metal clamp. then just drilled a hole in the plastic piece and secured it w/ silicone. Vuala, I working popcharger. Since the tubing and filter was supplied free of charge, the actual mod cost me under $5. the tubing that will work can be difficult to find though. I got lucky because my friend was able to supply everything and do it for me.
