15.0 @ 92.4 mph
B16a4me
06-05-2002, 07:58 AM
For those that care my car ran a 15.0 @ 92 mph tonight at the creek.
First run I spun heaps, missed two gears and hit the (low) rev limiter in every gear. I wanted to crawl under a rock. 16.5 @ 90.
Second run I walked off the line and mashed it and ran 15.5 @ 91.
Third run was close to as good as it's gonna get with 185/60 x 14 Olympic Javelins. 15.0 @ 92.
Fourth run tried big revs and riding the clutch (OUCH). 15.1 @ 92.
I'm happy with the MPH but I really thought that it would pull a 14 (which it should once I get it out of limp mode)
Setanta
06-05-2002, 10:21 AM
Nice times even so, but they certainly don't seem right given the power to weight. I guess suspension tuning might help your launches a bit - what reaction time were you running?
Still, I got smoked by two VTiR integras tonight (oh the shame of it) - I seem to have a bad dead zone at 4000 rpm in first and second - I'm just not spinning up to redline fast enough (not to mention the fact that both 'tegs were upshifting when I still had 2000 rpm to play with. Anyone want to bet that my cat is clogging the exhaust (it's original). I'm guessing I'm not getting the power fast enough.
Interestingly, against a stock VTiR EK Civic, it came off the line faster and held it out. The VTiR lights were just behind my doors and it would nudge ahead a bit on the upchange until I would change.
To answer some interesting questions, yes an SiR will do 185 in 4th just under redline - unfortunately, it does exactly the same in 5th at about 5500 and no more.
Add to my woes a back end that continually wanted to break loose on a twisty road and I'm going to be spending a little bit of time under car checking the rear sway - something was clunking around under there.
Might do a writeup in a different thread :)
spunkymunky
06-05-2002, 11:10 AM
225 on a slight uphill gradient for me.
i remember taking it down the big dipper before and getting it well off the dial. next time... next time.
on the way home i had some runs with my friends astra sri (he just got a new rear muffler put on) still managed to smoke him quite badly. he thinks that i should be able to beat our friends clio sport. that will be interesting.
Moppie
06-05-2002, 06:01 PM
Raceing and Astra SRi is just cruel!!! poor Holden owner.
anyway, B16a4me it sounds like your low limiter and ECU problems were really holding you back.
I woudl have expected times on the mid 14s.
Theres a European SiR who posted his time in the 4g forums. with exhasut and intake (but only 150hp stock) he ran a 14.9
Considering the factory times for those cars is a about a 15.2 or something then its totaly believeable.
And Setanta tell me what you do to replace the cat, I need to do mine as well. :)
incoming
06-05-2002, 07:49 PM
just knock it out!!!... i did..:finger: :D
Setanta
06-05-2002, 09:29 PM
That's what I'm thinking - but I don't need the defect if it ever came to it :p
Moppie - I 'm looking at a high flow cat - will let you know when I've researched it :)
Spunkymonkey
06-06-2002, 12:26 AM
ofcourse you know lang got a bad start too :p
I got up to 225km too, until we all started slowing down. There was still quite a bit left in the car though.
Could be worse pete...atleast you weren't limping home with exhaust problems like I was :(
gee...it lasted a whole week :mad:
Setanta
06-06-2002, 12:52 AM
sigh - not making excuses, but too many times last night I bounced off the rev limiter :( I know Lang spun up, I did too but backed off to get traction (that was my 3rd run for the night and I was starting to get a feel for the launches). The SiR and VTiR are pretty damn close all the way - that doesn't worry me at all - they're both Civics :p
One thing I did realise this morning, is that in order to realy get speed out of a car, you have to put the foot to the floor after every gearchange, not ease it down... whoops :p I only mashed it against Lang. Still, the 'tegs have the zip to redline and that extra torque to make the difference. Nice runs people :)
Anyway, I have a feeling the SiR has 220kms in it - but being JDM, you put your foot to the floor in 5th at 5-6000 rpm and it goes nowhere - hello mr speed limiter :( Strangely, Lang said she couldn't get the VTiR to break that either and the VTiRs don't have the limiter - weird.
I'm just glad the exhaust lasted you home - didn't sound too good when I listened to it from next to you. Hopefully it's a cheap fix :)
Spunkymonkey
06-06-2002, 01:11 AM
hehe excuses excuses :silly2:
yeah...good night out :)
thanks for your offer for assistance if I didn't make it :)
Setanta
06-06-2002, 01:15 AM
lol - no excuses, my bad that's all ;)
B16a4me
06-06-2002, 01:26 AM
I knew I shouldn't have run it when it wasn't running right. I'm getting the same response everywhere "Ah, that's shit you should at least be running 14's" hahaha.
The problem isn't the 3 Kw I'm probably missing up top, it's the fact that instead of dropping to (say) 5800 on the shift (where I have about 75Kw) I drop to 4800(where I only have 60Kw). That happens on every change!!
Also when going through the traps I have to shift into 5th as I am tagging the rev limiter where if I had my extra 1000 I could stay in 4th.
I was hanging to race it and now I've got a PB to beat. :D
PS. You can have a 10 second reaction time and it won't affect your times as your time doesn't start until after the car breaks the start beam.
Moppie
06-06-2002, 01:31 AM
Exactly now you've got some practice and some Idea of how the car launches you can get it sorted, and head out go a full 0.5 sec faster.
or more. :D
Setanta
06-06-2002, 01:42 AM
Ah - didn't know if you were running the traps or against others (haven't paid much attention to what's been happening at the Creek).
The 14s are there Chuck - everyone knows that
B16a4me
06-07-2002, 04:09 AM
Well, I spent the day redoing my entire wiring and guess what? Open circiut on the TDC + wire. After redoing the wiring it fired up straight away instead of the usual 3 to 4 seconds of cranking. I have to go to work so I haven't had a chance to see if it codes but I think it's fixed, WAHOOO!!!
I have to work 84 hours this coming week so I won't have a chance to test it but it's lookin good.
Moppie, will it go into limp just from a VSS code cause that's the only one I'm gonna be left with?
Probably run it up on the Croydon Dyno before I risk another trip to the Creek. :rolleyes:
PS: Spunky, what's the goss on Quick Fit (PM if necesssary)
Spunkymonkey
06-07-2002, 04:17 AM
PM necessary for this one :p
B16a4me
06-07-2002, 06:27 AM
Well that certainly isn't the story I was expecting :confused:
Setanta
06-07-2002, 06:36 AM
ROFLMAO
:D :devil: :D
Spunkymonkey
06-07-2002, 06:37 PM
LOL :hehehe:
Moppie
06-08-2002, 08:43 AM
From what Iv heard from the guys doing swaps in the states it wont run in limp mode, but it will throw a code. The best reason to get it sorted however is so you can let the ECU work the VTEC. It will so awsome things to the Torque curve on a dyno, and it will feel better on the road and track.
I cant believe you havnt got it to 8,200rpm yet. Damn mate are you in for and awsome ride! :smoker2: :frog:
B16a4me
06-15-2002, 11:30 AM
Well driving it to and from work revealed that it's still coding the VSS but it seems to be revving out more. I'll rig up the tacho from the front cut to check to see if I'm getting the full 8000 revs.
Only spun it out once and I don't know if it turned the tyres or the clutch slipped but something wasn't right. Oh well when I recover from working I'll look into it.
B16a4me
06-18-2002, 09:44 PM
Stupid weather, Drags were cancalled today and I have to work the night of the 3rd of July..........................
Spunkymonkey
06-18-2002, 09:49 PM
well it is pretty dismal outside today.
B16a4me
07-15-2002, 07:38 AM
Just diggin this up cause on Wed I'm gonna SMACK this time!!!!!!!
Spunkymonkey
07-15-2002, 07:42 AM
goodluck
B16a4me
07-15-2002, 07:44 AM
I don't need luck, I have VTEC
With great power comes great responsibility
Spunkymonkey
07-15-2002, 07:50 AM
as long as the rest of your car doesn't fall apart going down the quarter :p
B16a4me
07-15-2002, 08:07 AM
My car is in perfect physical condition
Spunkymonkey
07-15-2002, 08:10 AM
really :silly2:
B16a4me
07-16-2002, 06:17 AM
Yeah, just because I've lightened it a little doesn't mean the car is a shitbox
Spunkymonkey
07-16-2002, 06:30 AM
the main word to take note of in that sentence...is "little" :p
I didn't say it was a shitbox :rolleyes:
don't read too much into everything I post chucky :)
B16a4me
07-16-2002, 07:10 AM
Yeah a little hehehe
Na it's cool...I always get static from people at work " You spent all that time and money on an old civic???"
I'll try and be a little less sensitive hehehe
PS I 'm gunna save another 7kg by going to headers hehehe
B16a4me
07-16-2002, 07:13 AM
PS Fall apart hmmmmm.......Didn't a certain someone recently run over a part of her (oops that gives it away a little) Teg
Spunkymonkey
07-16-2002, 07:21 AM
WTF???? happened to my post???? the page didn't load properly...and its not here now...weird
excuse me....what are you on about?
Spunkymonkey
07-16-2002, 07:22 AM
Anyway...I was saying chuck...that you forget I used to own a 3rd gen civic....and only got rid of it because of damage from an accident.....
and yeah, you also forget that my sister and I are planning to rebuild a honda city turbo.
B16a4me
07-16-2002, 09:29 AM
Didn't your cat fall off or something????
I'm taking this thread back on topic as it doesn't feel right:bloated:
14.7 @ 95 is my guess. I'll know later today!!!!
Spunkymonkey
07-16-2002, 07:22 PM
LOL
the cat fell on the ground...yes only because the join between the extractors and cat was stuffed, well or the old cat was stuffed..and not flowing properly...
and Chuck...we're in APAC forums...we can do as we please here :)
B16a4me
07-17-2002, 06:21 AM
CREEK TONIGHT!!!!!!
1st run was against a 350 chev powered Camaro. He ran 15.0 at 89 and I ran......................14.7 at 96. Spanked his ass!!!!!!
2nd run was against a pink ef falcooon. He ran 16.1 at 83 and I ran.................15.5 at 89. Half way down the strip I'm like Hmmmm feels flat. DOH VTEC not switched on :bloated:
3rd run against a RX2. He didn't know how to stage and rolled thru thus redlighting. I ran............14.4 at 96. YYEEHHHHAAAAAAA!!!!!!!!!!!!!!!!! WAHOOOO!!!!!!!!!!!!!!!!!!!!!!!!!!!
Spunkymonkey
07-17-2002, 06:45 AM
CREEK TONIGHT!!!!!!
Cool....congratulations chucky :)
I just drove past the creek about 15 minutes ago on the way home from my best friend's place. Saw all the cars parked there
Hypertune A.J.
07-17-2002, 09:10 AM
14.4 at 96.
Nice one Chuck...
I'd say... Right now you're rather well pleased with yourself...
And so you should be... Well done!
B16a4me
07-17-2002, 09:39 AM
I have been celebrating so not only am I well pleased......I am well pissed hehehe
Thanx AJ & Spunky
Now I want 13's and 100 mph (and not to wake up with a hangover but that looks unlikely)
Spunkymonkey
07-17-2002, 11:36 PM
Thanx AJ & Spunky
haven't you been watching the news?? new hangover pills developed in UK to stop you getting hangovers :p
Hypertune A.J.
07-18-2002, 08:36 AM
I like the sound of that ! :buck :D :D :D
dejoux
07-18-2002, 08:52 PM
Talking of standing 1/4's I might as well post mine from about 2 weeks ago.
For those who dont know Ive got an SiR Del Sol
1st run:
[email protected]
2nd run:
[email protected]
3rd run:
[email protected] (missed 4th and crossed the line in neutral)
4th run:
Bet a TX3 turbo on DYO and was alot more confident about the time but didnt get the timeslip.
So overall I had some very dissapointing times and as those faring trap speeds show alot of it was driver error :S
Ah well first time on the strip gotta start somewhere, itll be my last run with this car though, time for a change
Moppie
07-18-2002, 09:16 PM
:lol2: :lol2: :lol2: :lol2: :lol2: :lol2: :lol2: :lol2:
You still ran a mid 15 with out the VTEC! I love it!!!!!!!
No wonder it went a full second quicker when you remembered to turn it on! LOL
(and that poor coon.......)
B16a4me
07-19-2002, 08:33 AM
Yeah the driver of the coon came up to me looking under the front for an intercooler. He was saying "Shit that thing flies" I'm jumpin around tryin to kick myself in the ass. You should have seen his face when I told him I forgot to switch VTEC on, HAHAHA.
Moppie
07-20-2002, 10:09 AM
Ok m typmng ths as stright as i CAN.
There was a clib day at mermerie sometime ago, and the LOTUS Elies's ran from a 13.8 to a 14.4, so you have one damn fast little shopping cart there!!!!
