JDM Honda Civic B16A SiR II with an auto transmission
LOWCIV
04-24-2002, 06:01 PM
i am almost finish installing my b16a2 on my 1993 Civic Dx with a JDM b16a2 with auto tranny..! its has taking me a while because i can only work on it a few hours a week..! but i finally got the engine in connected all the plugs except Vtec solenoid, vtec oil pressure, knock sensor, crank sensor, extend the O2 sensor from the front to the back of the engine, extend the Air temp sensor from the bottom of my old intake engine to the top of it, the engine went in very tightly very little room left on the drivers and passenger sides, also i need to get axles from a 94-95 integra with an auto trans, also i need a placeracing throttle cable bracket if i want to use the DX cable its only 25 plus shipping or get a 90-93 Integra throttle cable..! as far as the transmission cable its fits but i dont know if i need a new cable..! its a bit long ..! as far the engine mounts and brackets i used 94-95 Integra with an auto trans REAR mount i used the stock passenger and driver side they fit right..! i had a hard time aligning the rear mount but finally got it in..! all the plugs match from the Dx engine to the b16a2 except the trans solenoid the electrical connection i had to use the DX one which of course fit...! all the major things are done just minor things need to be installed but time is a thing i dont have to really finish it ...! but hopefully this weekend coming
i will be making a full list of the things needed for the swap
BOLO
04-25-2002, 11:37 PM
Sounds good, i was going to do the same thing but decided to get an sir2 direct from Japan. Iwas getting a complete nose cut from a Japanese spec. integra (b16a engine, auto tranny, etc.) everything. All this for a cheap price of $850 U.S.
Anyways good to hear of your progress.
LOWCIV
04-26-2002, 01:53 PM
i finally got the axles, drivers and passenger from an 94 integra with auto a trans got a Distributor cap from a Integra GSR and plug wires..!
i am just missing the alternator pulley which i am getting from a friend of mine..!
if i am lucky enough and nothing goes wrong i should be able to start the engine tomorrow sometime..! cant hardly wait he he :badass:
is it really necessary to wired the crank sensor to the ECU
isnt it a pin for it already on my DX ECU..? and wired up ..? any one please i need advice..!
by the way i am using the a P30 ECU for an automatic b16
thanks....!
LOWCIV
04-30-2002, 11:08 PM
I am finally done..! got all the bolts and screws back on the car i havent driven my car for a while..! but tonite i drove it home i took off the power steering and the A/C out i didnt know what to expect what this engine in my car will feel like..! well it feels like totally different car alot of pull power, i went full throttle and in a sec or two the engine just went Zoom vtec came on and i was gone, while doing around 35-40 mph i floored it and vtec kicked in i had to hold the steering wheel with two hands i am not used to the car to accelerate this quick it felt like it just jump forward i could actually heard the vtec solenoid clicking ...! i have a thermal exhaust on the car and it was so loud Wow i woke up half the people on the block he he..! i just ordered a JDM GSR automatic transmission to keep as a spare just in case the one its on the car goes bad..! later i will be adding the A/C and Power Steering..! but for now the car drive so good, i have raise the car about one inch maybe more because this engine is heavy and pushing down the front of the car..! i have Ground Control, and a camber kit so i am set... soon i will be posting the complete list of parts i used for any one who its thinking about getting a b16a2 with a auto trans and have no clue on how and what parts to use.. i know i had a hard time finding the info and parts like engine mounts ....
Pics on the way..
any Questions
[email protected]
LOWCIV
05-08-2002, 12:50 PM
car is running good pulling real hard at high rpm's, it dont drive bad at all even without the power steering he he.. no a/c also ...but i got them and planning on installing them in a few weeks and i just got a 1996 GS-R Automatic Transmission with the torque converter of which i am going install when i install the turbo, i am putting it together i already got a turbo manifold i am in the works of buying a turbo..! he he
i dont know what i am going to end up with with the GSR auto trans and the turbo Wow ..! for the mean while i got kamikaze headers and a front mount intake ..!
later
jOYRiDe
05-09-2002, 12:33 AM
one question... why auto? :confused:
LOWCIV
05-14-2002, 11:46 AM
http://mywebpages.comcast.net/lowciv/DSC00044.JPG http://mywebpages.comcast.net/lowciv/DSC00045.JPG
http://mywebpages.comcast.net/lowciv/DSC00046.JPG http://mywebpages.comcast.net/lowciv/DSC00047.JPG
http://mywebpages.comcast.net/lowciv/DSC00048.JPG
Moppie
05-15-2002, 01:47 AM
Awsome job mate, the install looks really good, and very tidy.
I was wondering, did you have much trouble finding the Auto equiped b16a in the US?
They are VERY common in Japan, and most of the EG SiR's imported here are Autos. But the Auto option is not very common as a swap, and so I can't imagine many US parts importers bringing in Auto swaps from Japan.
And, as well as the car goes now, it will be unstoppable with a Turbo.
The Auto version of the B16a is actualy slightly detuned from the Manual version, and uses mostly differnt Cams, and ECU.
However since the cams have less Overlap it will take extremly well to Boost, and should easily make as much hp as a manual version.
And if the Turbo option falls through then a set of Aftermarket cams, or even 2nd hand cams from a Manual JDM B16a will make a noticable differnce.
tenzoracerevovii
05-15-2002, 08:39 PM
damn....nice car moppie......the jdm hatchback's are cool man..... i've noticed that you sell some jdm stuff to AF'ers.......how much do you think you can sell me a jdm front bumper for the EF hatch like yours?....i'm not sure exactly what you need to do the conversion......i'm talking about converting the USDM to JDM.....so include whatever else i need for the conversion in the price....sorry for the inconvenience man!.....
confucius
06-25-2002, 12:55 AM
lowcivic where did u get a B16a2 with an auto at? I may be looking for one. email me at [email protected]
TrUnKs714
06-26-2002, 01:03 PM
nice swap i was thinkin about doin that myself in my 00 hatch but i dont know where to find the engine and trans. u seem to knoe alot about this, so im gonna ask u somethin. can i use a different transmission like...an LS auto transmission and mate it to the new SI engine? wut would i need in order to do this?
zerofighter777
07-01-2002, 12:34 PM
Not sure where he got his, but I got my b16a auto at hondamotorsonline.com. There motors are clean and in good shape. You just have to ask for the motor trans. because they do not have it listed on their site. As far a the b16a with an integra ls trans., i'm not sure on that. If it is possiable you would need the jdm vtec auto ecu for sure. Hope this helps
Aznboi64
11-09-2002, 03:16 AM
I'm very impressed at the install. From the first time I heard about the B16a/b18c auto I knew I wanted one. I've done tons of homework on it but never had the cash to do it. And I'm glad to see that you've done the swap and haven't taken crap from anyone. To answer Trunks question you don't want to use the LS auto tranny, because it sucks and that it has longer gears. The B16a auto has shorter gears for the vtec. Lowciv I've give you mad props for doing the swap and keeping it auto. Try finding the B18C auto w/LSD. Yes there is one out there. ITs very rare. If you don't believe me check this web site link (http://www.speedoptions.com/articles/1146/) If you don't go boost, try going all motor. I talked to a guy who had a b18c bottom w/ type-r internals and a b16a top w/ type r internals and he says it pulls VERY strong. Just make sure for your car you get a performance torque converter and a tranny cooler for the days you down shift.
sparq
11-10-2002, 08:01 AM
You list "Automatic" and "Performance" in the same sentence... (sig pic)
LOL... :bloated:
Frostbyte
11-14-2002, 12:32 AM
LOL... :bloated:
hahaha I was thinking the same thing.
civickiller
11-14-2002, 02:10 AM
idk what you guys are talking about, autos are the shit. you will run consistant times with the auto. so if you enter brackets, youll win. who couldnt use the extra $500 you would win from winning the brackets.
autos are cruisers you dont need to worry about shifting, just sit back and cruise
Bishopxx
11-21-2002, 01:16 PM
I love that swap info you have already provided. Thanks. Ok if you could help me out with the rest of my swap though I would appreciate it. You see I have a USDM 94 B18C1 engine but my 94 honda civic is an auto. I want to keep it auto, but I have been looking high and low for an ECU and VTEC transmission but haven't found any place. You see I live in Sacramento, CA and the best place here is HAP recyclying and they only sell USDM stuff. So where do I go to get the JDM tranny and ECU? I want everything to be smooth for the CAL smog refs when they give me the changeover sticker. So if you could help thanks.
94 B18C1 w/ PR3 pistons
Forged Eagle Rods
Mugen twin loop exhaust
Homemade CAI with K&N 6" cone
Not bad so far but I can't wait to get the swap in.
zerofighter777
12-05-2002, 09:20 AM
Forged Eagle Rods
call hondamotorsonilne.com .They don't have the parts listed on the site, so you have to ask for them. hope this helps
Aznboi64
05-09-2003, 05:27 PM
Bishopxx - Check out Venus motorsport or something like that. They have tons of salvaged parts from cars. What you need is a auto flywheel and an auto tranny. You need to take off the manual flywheel from teh B18C and put in the auto flywheel. Another thing to think about in terms of swap is using a B20Z w/the LS auto tranny. I think the LS had the sports gear tranny for the auto. But I sure wouldn't mind a auto b16a with type-r internals to haul ass.
SiRII
05-09-2003, 06:19 PM
i got the SiRII motor too. but a 5spd.
93hatch
05-11-2003, 02:12 AM
why would you fix up and automatic car i think a manual tranny is the way to go:monkeypis autos
B16EJ1
05-11-2003, 02:16 AM
I agree. No matter what you got, a car of the same caliber with a 5 speed will always kill you.
crxlvr
05-11-2003, 08:31 AM
i will be running an autobox b16a with very tasty internals. i will do bracket racing whenever i can and get some consistent times so i can win.
B16EJ1
05-11-2003, 02:41 PM
Are you doing it so that you will never be able to ride the rpm band the way you're supposed to? I'm not trying to start a flame war here but what you are saying is kind of funny. You want an auto to run consistant times. It is just as possible to run consistant time with a 5 speed and better times at that so why do the auto?
