Pics of the GM trans PCS problem
Flatrater
04-20-2005, 08:25 PM
This is a cut apart PCS.
http://files.automotiveforums.com/gallery/watermark.php?file=503/68974PCS_1-med.jpg
Flatrater
04-20-2005, 08:26 PM
Another view of the parts of a PCS.
http://files.automotiveforums.com/gallery/watermark.php?file=503/68974PCS_2-med.jpg
Flatrater
04-20-2005, 08:27 PM
Here is the business end of the PCS.
http://files.automotiveforums.com/gallery/watermark.php?file=503/68974PCS_3-med.jpg
Flatrater
04-20-2005, 08:29 PM
The PCS is in the closed position here. The last pic shows the PCS in the open position.
http://files.automotiveforums.com/gallery/watermark.php?file=503/68974PCS_4-med.jpg
Flatrater
04-20-2005, 08:35 PM
The picture text explains everything.
http://files.automotiveforums.com/gallery/watermark.php?file=503/68974PCS_5-med.jpg
Flatrater
04-20-2005, 08:38 PM
Here is where the damage is located at. Look close at the bottom arrow.
http://files.automotiveforums.com/gallery/watermark.php?file=503/68974PCS_6-med.jpg
Flatrater
04-20-2005, 08:40 PM
A close up view of the damage.
http://files.automotiveforums.com/gallery/watermark.php?file=503/68974PCS_7-med.jpg
Peter Solarik
04-21-2005, 08:42 AM
Thank you Flatrater for your extensive report, including the pictures of the culprit solenoid. You really 'bent backwards' to inform us more in detail about the hard shifting problems and how the trans works.
I took the car back yesterday and complained about the noticebly hard steering. The did not raise any objections, put the car up on the hoist and found what they did wrong during re-assembly. There is some ruber sleve which they did not positioned right and this sleeve was rubbing against the steering linkage (or something like that).
Took them two hopurs to correct it. (No charge of course). The car is back to easy steering.
I already gave them the welded covers. If I knew that the locations of the cracks would be of interest to you, I would take a digital photos of the 'Before and After' repair/weld. Just to satisfy your proffesional curiosity, I will go back there with camera and ask them whether they would not mind to take the pictures. I am afraid that they may be concerned and suspicious what are my intentions with the pictures. You understand.
I will try.
The owner too showed me the solenoid that they removed from my car. The needle was stuck even when he applied reasonable air pressure to it.
BTW,the crack was around the bolt hole, I had to cut (using a tool grinder) the whole area out, (about 1.5" around the hole - counterbore for the bolt), and slowly build up the cavity. Both cracked covers had almost identical hairline cracks in the same area. I see this as a weak point in the casting. If any of you guys are welding the aluminum covers and other componenets, get rid of the standard TIG machines. I was welding the covers with a new Miller Dynasty 300 series machine that allows you to set your pulses, HF intensity and you use 2% Thoriated Tungstens with the tip sharpened to the point ! This will allow you to put the heat exactly and sharp point to the spot you are welding. I am really impressed with this new welding technology. (Dont take this as an advertisement for Miller) (:-)
To make the long story short, my car is fixed, and I hope that the transmission will be free of trouble for at least next 30.000 miles.
Therefore I am trying to keep a good realtions with the shop that done the repair - not knowing when I will need them again!
Next time I will charge them for the welding job.
BNaylor
04-21-2005, 11:25 AM
Nice pics Flatrater. I know one of the symptoms of a defective PCS solenoid is harsh shifting. Another audible sign may be a whining sound. Is this due to leakage or the system going into a bypass mode due to high line pressure, etc?
Last question, do you know of any emissions type odb-ii DTC error codes that will trigger the ECU to command high line pressure even with a known good PCS solenoid and no other known mechanical problems with the tranny?
Peter Solarik
04-21-2005, 12:14 PM
Hi Flatrater:
I phoned the owner of the trans shop where my car was repaired and explained to him that one of the forum participants/adviser would like to see where the cracks originated. He said, no problem, come and take pictures. How do I go about it? How do I send the picture attachments? To the web site or you personally? I will keep the resolution down to 40 - 60 KB (faster do download or emailed).. No more than 4 - 5 pictures.
Check my response to you also in thread 'To Flatrater, Bnaylor and alll our advisers, (Hard shifting) '.
One more question:
Since the steering unit had to be 'disturbed' will this affect also the front end alligment? The shop said - no.
Thanks again for all your assistance.
Flatrater
04-21-2005, 08:06 PM
Hi Flatrater:
One more question:
All the pictures I attached here are located in the AF gallery. If you look at the top of the page you will see the headers 3rd one form the left is the gallery. Just sign in and you can upload the pics.
Moving the steering gear will not effect the alignment enought to worry about it but removing the engine cradle will change your alignment specs. GM recomends doing a front end alignment whenever the engine cradle is distrubed. If you loosen all of your cradle bolts and move the cradle forward or aft will change your caster angles. Moving the cradle side to side will change your toe and camber angles. All GM engine cradles have holes in them that line up with holes in the body. I always make sure to line up the cradle to body holes and then align the suspension.
If you want call an alignment shop and ask them if moving the engine cradle can change your alignment specs.
Also Peter you said the shop showed you your old PCS, showing you how the needle was stuck. Now how would low trans fluid level cause a needle to stick? It can't!
Flatrater
04-21-2005, 08:25 PM
I would have to read every code to find out what codes would command high line pressure to be sure. But off hand most of the trans codes will default either to a high line pressure or default to a second gear start. For instance on some Buicks a bad alt will default the trans into second gear start. If you want I can research what problems will affect the trans when I have time.
Hey Peter I am rebuilding a 2003 GMC Envoy trans that was low on fluid. The only damage wa to the friction material to the clutch packs. This damage only happened after the trans was one gallon low on fluid.
bignoisey
04-29-2005, 03:35 PM
Thanks Flatrater for the pics. Like they say, they're worth 1000 words. So it looks like the groove that's worn in the solenoid's armature causes it to hang up in the low current/high line pressure state which causes the jerky shifting. On my car this seems to happen only when the car is thoroughly warmed up and will remain until it cools off.
You describes somewhere that the PCS can be changed without removing the transmission and only lowering the cradle. I'm almost ready to try this myself on my 2000 Century. If I remember the time I changed a FWD transmission on a GM, you'd only have to disconenct the steering, the struts, and a couple of engine mounts. How about engine hoses/cabling? That may be possible with what I have to work with (basically, a floor jack and standard mechanic's tools). Does removing the side cover require draining the fluid first? Is the PCS exposed once the side cover is off? Any other pitfalls? Once I start, I won't be able to move it easily.
One more thing, I had a couple of instances of my TCC malfunctioning I think the code was P0742 TCC System Stuck On. That caused really rough shifting. This seemed to clear itself both times, but happened on a road trip in both cases. Could the PCS problem have anything to do with the TCC? Any advice is welcome.
Allbert
12-07-2005, 08:32 AM
Flatrater, if you wouldn't mind, I'd like to use some of the pictures you've posted in this forum in some marketing material. I work for BorgWarner, and we are about to launch an aftermarket PCS of our own design as an alternative to the OE PCS (made by Delphi). The pictures you've taken illustrate the Delphi design weakness very clearly, and since I couldn't do any better if I took pictures myself, I'd rather use your material and give you the credit. Please let me know if this would be OK with you.
Thanks.
Flatrater
12-07-2005, 07:41 PM
Thanks.
I have no problem in you using these pictures but I am not the owner of these I just copied them from a friend of mine who did all the work. I am sure he wouldn't mind you using them. I also perfer not to get the credit for them. If you want I can email the person who took those pics and ask him if he wouldn't mind.
Allbert
12-08-2005, 08:27 AM
That would be great. Thanks.
Flatrater
12-08-2005, 08:58 PM
Check your PM box.
mshatn
01-19-2006, 10:35 AM
I want to ask if bad selonid let the transmissin give a whining sound, which will be there even when you stop and shift to "P" or "N" just prssing on the accelrator will make it appear and increase with increasing the pressure on it?
This is what is hapining with me the harsh shift starts only when I have this sound.
Thanks for help
BNaylor
01-19-2006, 12:18 PM
Thanks for help
Yes whining can be present with a bad or sticking PCS solenoid because if a Class "D" DTC fault such as P18XX is present it will command high line pressure and disable shift adapts. Class "D" faults normally do not trigger a SES/Mil light but are stored for retrieval by a trans capable scanner.
I had the same problem with harsh shifts and whining but it wasn't that bad and would only occur about once a week. After turning the ignition off and re-starting the problem would cure itself. I used Sea Foam additive and then Lubegard. It has been good for 30K miles so far. Best part was it only cost me $20.00.
mshatn
01-22-2006, 11:03 PM
Sorry but I have no experince with autmatic transmissions, what do you mean by :
" Sea Foam additive and then Lubegard"
and is there any risks of using it
Thanks
Christophe Salvain
08-11-2006, 04:34 PM
Hi group,
I own a 2000 Chevy Venture. After intermitent trans hard shifting + whining
sound, I need to change the trans PCS (#10478146) but i dont know where is
it located (nothing in the Haynes).
Thanks for any insight (picture etc etc ...)!
Christophe
BNaylor
08-11-2006, 04:48 PM
Your Chevy Venture should have a 4T65E autotransaxle.
Therefore, the PCS solenoid is located under the side cover assembly which is the driver's side of it. The solenoid is located on the left hand side of the valve body once the side cover is removed.
This is not really a DIY job and a real PITA to do.
varet2000
01-15-2009, 02:30 PM
I have a 2001 Century 3.1 V6. Few days ago, my wife said that car does not run anymore. She had to turn off and restart the car few time to make it home. I red the posted problem about transmission from other Century owners and find out that PCS solenoid needs to be change. I got an aftermarket PCS for $38.00, and changed it. It fixes the problem and thank you all for giving out the info. Now my car runs and shifts all fine, just sliepps in the morning for few minutes. Then it gets normal after worm up the engine. I add for trany additive, so I hope it did not miss up my transmission. But over all, the car runs and shifts fine. It was kind of hard to replace the PCS. First, you need to remove the axle. Then you need to have jack under engine to remove the driver side engine mount which is on body panel. Then open the bolts around the panel which is about 12 bolts. The gasket is reusable, so make sure you do not hurt the gasket (it costs $9500 in dealer). The panel will not come off all away, so you need to detach it from trany and just push it back about 5-6". You might need to pull the A/C hoses up carefully to give some room to panel to move. After you move the panel back, you will see the PCS solenoid right on top. It has a small clip under it, which can take it off with a sharp stick. Be careful not to drop it down in panel. It would be so hard to find it since the space is too small. After you take off the PCS, you might want to blow air on hole to make sure nothing is stock in there. Someone told me that I could take off the filter inside the hole to clean it, but I did not try it. Place the PCS on board, and place the clip in there again. Again, make sure do not drop the clip inside the panel. Then connect the wire in PCS, and have the panel back it place. It should fix the problem for you. I would say, do not change the transmission oil before you test drive the car. See if you will have any sliepping problem after replacing the PCS. I’ve done it and now cannot find out what make the trany sliepps now.
I hope I can help you people out there with this problem. We had this car for 7 years since we bought it brand new. It is a nice car and give me the GM quality which I always wanted. This is a small problem, and anyone car fix it without spending too much money. Ask me any question you have, and I will be glad to help you.
Big Question?
My car only sliepps in the morning until gets worm after I replace the PCS. Does anyone know why? I add some ATF, so maybe was low in cold, but did not help.
BNaylor
01-15-2009, 02:40 PM
Big Question?
Welcome to AF.
Sorry but this is a very old thread and has been closed. Just start a new post addressing your issue.
