se-r to g20 swap questions
B13 ROB P10
03-10-2002, 08:08 PM
well it sound like i have some vavles problems. i might have to swap my sr20de out of my se-r and put into my g20. well i have some compatability questions. if i do the swap i also want to swap the trans with it. i want to know if the shifter linkage from the se-r will fit the g20? i also want to know if i have to get an ECU from a car that is for a 5spd because the g20 is auto right now? will the axles from the se-r fit the g20?
P10DET
03-10-2002, 09:29 PM
The oil pans are different from the SE-R to the G20. I'm not sure why that is. When I put my SE-R engine in my G20 I swapped the pans. Now that I'm about to put that engine back in my SE-R, I'll swap the pans again.
I don't know about the linkage.
You'll have to use a G20 outer CV joint on the SE-R halfshaft. They are different. Otherwise, I think you'll be OK.
B13 ROB P10
03-10-2002, 09:34 PM
is there a clearance problem with the pan? is it just the lower pan or the whole upper and lower portion of the pan?
