Your experience(s) with camber kits??
LX98Civic
02-11-2002, 02:39 PM
I rode in a teg (couple of months ago) that was lowered 2.5" and had front and rear camber kits.
The problem is, the camber kits were squeeky as hell!!
I would kill if my car squeeked the way this thing did. I can't remember the brand the guy had, but he said the bushings were cheap and that is why it squeeked.
What are your experiences with camber kits?
I am going to use the washer / longer bolts for the rear, but will eventually get a camber kit for the front.
:bloated:
Rice-Rocketeer
02-11-2002, 06:05 PM
That's why you're supposed to use heaps of industrial grease on the bushings. So they don't squeak :)
Vutekho
02-12-2002, 11:29 AM
I had the Ingalls camber kit with the rubber bushings and it squeak like crazy.
LX98Civic
02-12-2002, 11:45 AM
"had" = What happened? Take it off? :confused:
Vutekho
02-12-2002, 02:05 PM
Yeah, I took it off. I e-mailed Ingalls about it but they didn't have an explanation for it. They have great e-mail service by the way, but I couldn't live with the squeal.
SpecialK
02-12-2002, 03:28 PM
i have the same kit and it squeaks i think, does anyone have a solution besides taking off the kit? thanks
petzride
02-12-2002, 09:31 PM
squeak???? really?? why??
I just brought a kit from Ingalls, but I haven't put them on yet.
Can anyone explain on this??
What should I do??
Should I do like what Rice-Rocketeer said??:(
Rice-Rocketeer
02-13-2002, 12:22 AM
Ppl you need to lube the bushings of anything that you install on your car. Sway bars, new polyurathane bushings, whatever. They all need to be lubed with heavy duty grease that won't rub off.
SpecialK
02-13-2002, 11:36 PM
how would one go about fixing the problem i would guess i can just remove the camber kit pop the bushings out grease em up and reinstall? if this is true i would appreciate some tips on how to remove the kit as i had it installed and really dont know how to remove it. also how hard is it to remove the bushings, does it require a special tool. thanks.
Rice-Rocketeer
02-14-2002, 01:17 PM
Depends totaly on the kind of camber kit installed. You need to get your cars manual and learn how to take the suspension apart. And removing the bushings also depends on what kit.
rcamacho
02-14-2002, 02:41 PM
Just ordered the ingalls kit for my '94 civic. I recently installed the Eibach pro kit and KYB AGX shocks.
Hopefully the kit will not be too squeaky. I've had a lot of vehicles with urethane bushings before and had to relubricate them every few years. I've found that standard moly grease tends to work itself out of the bushings. Anti-sieze lube or marine grease tends to stick better.
I'll post some follow-up after I get the ingalls kit installed.
BTW: Right now front camer is -1.8, rear -1.0. I'd looking to get camber range back into the -0.5 range.
Rice-Rocketeer
02-14-2002, 05:11 PM
The ingalls kit is easy. It's simply two small rotating joints that attach your upper a arm to your chasis.
And yeah, you need heavy grease or it won't last long. Something like the stuff you find lubricating the joints of construction equipment.
x98myers7
02-18-2002, 11:29 AM
i have had an ingalls rubber bushing kit for about 5 months now, without ANY grease, and i have had NO problems with squeaking whatsoever. it's just like OEM.
Gusto222
02-18-2002, 05:00 PM
i have one-- NO noise @ all-- its umm by that company that has a indian cheif for there like logo... - paid like $80 for it... Its only a rear kit-- & i've had it on for like hrmmm id say well over 8 months...
Greatest thing ever!!
Rice-Rocketeer
02-19-2002, 09:25 PM
Congratulations. The grease is a "in-case shit" type of mod. If you don't need it, good for you. If you do, get ready to disassemble.
CivicEx95
02-20-2002, 04:15 PM
Hey, the hinges on the door at my house are squeaky, should I just take the door off???
Come on guys, if somethings squeaky, you gotta put some grease or oil on it to stop. :rolleyes:
rcamacho
02-20-2002, 05:39 PM
Just finished the old washer method for rear camber correction last evening. Simple as pie. I left the rear camber at -0.6 degrees.
rcamacho
02-21-2002, 12:52 PM
http://www.ingallseng.com/parts/3572.html
Just installed the 3572 kit and had it aligned this A.M. It's nice having the camber at -0.5 vs -1.8. The steering is much more linear and responsive on the road.
So far no squeaks - I used moly wheel bearing grease.:smoker2:
