red instrument gauges
95_G20_P10
01-08-2002, 08:33 PM
pics of my new red gauues
GtRider
01-09-2002, 06:13 AM
what kind of bulbs did you put in there?
v_knot
01-09-2002, 08:21 AM
now why would you like this kind of look? you can't even distinguish the colour of the needle and the dial! for ease on the eyes, it's best that these colours are distinguishable...thought I'd share my observations
95_G20_P10
01-09-2002, 11:45 AM
there 194 bulbs 5 of them. its not hard to distingish the needles it looks alo better in person. anyway im thihking of gettina indiglo needle kit
pherik
01-09-2002, 12:27 PM
How do you go about changing these bulbs?
Any good links that show how it's done?
95_G20_P10
01-09-2002, 01:04 PM
i dont know about the p11. i herd that the p11 uses smaller bulbs then the p10's 194/168 so it might be hard to find colored bulbs.
Swonder67
01-09-2002, 05:00 PM
they don't make colored bulbs for the instrument cluster on the p11, you'd have to paint them. I think the bulb number is 74.
P10Skin
01-09-2002, 05:32 PM
On the P10 what did you have to remove to get access to the bulbs?? How about some step by step instructions for cabbages like me:D
Swonder67
01-09-2002, 05:46 PM
not too hard to remove the cluster, since you have a p10, even easier to change the bulbs. there should be 4 screws holding the black trim piece with the security light, (two on the bottom, two on the top). you will also more than likeley have to take off the plastic piece covering the steering wheel column, I think that is held on by 4 screws also (on the underside of it) then, there should be 4 more screws holding the gauge cluster in, after you take off those screws, CAREFULLY pull the cluster slightyly (about an inch) out and then tilt the top of the cluster out (toward you) you should then ahve access to the bulbs that light your cluster. they will be the ones with the bigger recepters (I think they are brown) and are a 194 bulb, then just reverse to put everything back.
95_G20_P10
01-10-2002, 01:02 AM
there actully 6 screws that hold the piece around teh stearing wheel and u will have to unscrew the secuirty light u'll see what im takin about.
P10Skin
01-10-2002, 01:45 AM
Do I need to take the steering wheel off? if so how?
Thanks for the helps guys
95_G20_P10
01-10-2002, 02:02 AM
no u do not have to just the placstic covering over it. lok under and u will see screws unscrew them then pop it off
