Where are the spark plugs in 98 aurora?
milin1609
02-23-2004, 02:23 PM
Hey friends,I am new to the forum.After reading the forum,I decided to change the sparg plugs and the wires for it,since it was hesitating.(i mean,my car.)I installed the wires after couple of hours.By the way,I am not a mechanic.But this forum made me inspired not to give away the hard earned money to the service shops for easy works.After installing the wires,I tried to find the way to get the spark plug out of those four black plastic housing in which they are molded.But seems like it is whole body.I could not figure out what to do.I just put every thing back with the new wires.It looks like, the problem is solved for hesitation.I even got little better gas milage.About 2 mile/hour better.I would be happy if I could change the plugs.Please some one tell me,how to get those plugs from those housing? or am I looking at totally wrong place for it?
BKVic
02-23-2004, 02:42 PM
The sparkplugs are on the other end of the plug wires ,down the four holes in the valve-cam covers, not in the coil packs. Ive never heard that one before, you havent worked on your own cars much have you.
BKVic
BKVic
milin1609
02-23-2004, 10:06 PM
Thanks BKVic for the answer.Yes,you are right.I haven't worked on my cars so far.But now I am trying to do so with your help.Do you mean,the plugs are where the longer tube like part of the wire attached to?
Indy8
02-24-2004, 01:49 AM
I'm totally confused!
jessb45
02-24-2004, 10:59 AM
You can't change your plugs without the right set of tools. You should have a spark plug socket with a long extension before you start popping wires, spark plug sockets have rubber in them to grab the plug once you get it loose.
The plug wires have two ends: One end is at the mouted to a black distributor box. This is where all of the 8 wires are plugged into. The other end is connected to the spark plugs, these are spaced out and in the actual engine block itself. You can easily see the front 4 when you open the hood, the rear 4 will be more of a challenge...
Hope that helped...
Hope that helped...
milin1609
02-24-2004, 04:10 PM
Thanks jessb45 and BKVic.
That answers my question.I was looking at wrong end!!!!
jjdewd
02-24-2004, 04:46 PM
lol
jessb45
02-24-2004, 07:17 PM
That's ok ... we all have to start somewhere ;)
BKVic
02-24-2004, 07:30 PM
Yep, cant learn if you dont ask questions.
BKVic
BKVic
dsatt12
02-27-2004, 11:42 PM
Coincidentally, it'll be easier getting at the rear 4 sparkplugs if you take the coil packs off. There are 4 screws holding the whole assembly in.
Another tidbit of advice is after you unplug the wires, blow out the spark plug area with some compressed air- even a can of computer duster would do if you don't have a compressor. That way you don't drop as much dirt or other more damaging debris into the cylinders.
jonnik
12-19-2006, 08:52 AM
It is also recommended to put anti-sieze on the plug threads and follow the torque specs.
BNaylor
12-23-2006, 12:58 PM
Thanks for the info. However, please check the date of the thread and last post. If over 3 months old then do not resurrect. Thread closed.
POSTING IN CLOSED OR OUTDATED THREADS:
If a thread has been closed, there is probably a logical reason for it. If you feel that the reason(s) for closure of the original thread are unjustified or wish further clarification feel free to contact any member of the moderating team. However, do not start a new thread about another closed thread.
Please avoid posting or voting in outdated threads. It merely clutters up the message board and makes it more difficult for fellow members to sort through the vast amount of information contained on the boards. If you have new and important information to add regarding a past discussion, feel free to start a new thread and if need be, add a link to the original thread.
