Checking your ECU codes and clearing them 101
ric
01-02-2002, 01:31 AM
Welp folks ecu codes are just about one of the most ignored things i have ever seen yet one of the most important at the same time. face it, that little light doesnt just come on cause it thinks its close to christmas, it means you got a problem.
if your truely concerned with your investment thats probably thousands of dollars aka your car then seeing whats wrong with it can only aid in your decision's to take care of the thing.
the below two pages though very large are scanned images of the actual helms service manual on how to obtain your codes and then clear them. it will also show you that nowhere in these pages does it say you have to let your car run for 5 minutes without touching the gas or any of the other grapevine stories that circulate around here about resetting the ecu. in all honesty resetting the ecu is worthless unless its to clear a code. resetting it after the addotion of a mod is not necessary because it learns it anyways. contrary to popular bellief it does not have one set of values that it goes by all the time. sure it has base maps but the world is not a constant place, nor the factors that effect a cars operation. as you drive your car will experience combinations in air temps and pressures and gasoline grades that are always different, and thats exactly why its a learning computer, so it can adapt, function correctly in that situation as opposed to another and overcome. sure its not some neaural net computer capable of controling a cybernetic organism like our favorite meathead the terminator but its pretty dynamic in its abilities to compensate. an example.....
a cold air intake does not require you to reset the ecu. if your in florida and your factory intake is sucking in ungodly hot air and you drive to maine and its sucking in ungodly cold air (40degrees) do you have to reset your ecu? nope cause the ecu adapts and adjusts to the conditions. welp its the same as your factory intake is sucking in hot air here in florida and you put a cold air intake on and stay here and now its sucking in air as cold as in maine (40 degrees). welp cold air is cold air and 40 degrees is 40 degrees no matter how how you put it so why would you have to reset anything? simple you dont.
now on to the pictures, everyone like pictures.
for reference you do not need an obd scan tool although they are a nice little thing to have.
things needed
1. a brain
2. eyeballs that work
3. a paperclip or piece of copper wire
also for reference the word MIL stands for malfunction indicator lamp also know in laymens terms to us underachievers as the "check engine light"
basically the only thing you will do different in this whole thing is instead of using the neato little honda connector to trigger the MIL to flash your code your gonna get ghetto and jump the circuit with a paperclip or piece of wire. sorry folks it has to be a cunductive material so a piece of string isnt gonna cut it.....
http://members.aol.com/plnoldrick/ecu1.jpg
http://members.aol.com/plnoldrick/ecu2.jpg
and after you get that code heres a list of what they are
obd1
0
Faulty ECU.
1/2
Oxygen sensor or circuit.
3/5
MAP sensor or circuit.
4
Crank angle sensor or circuit.
6
Coolant temperature sensor or circuit.
7
Throttle angle sensor or circuit./Throttle position sensor
8
TDC position/crank angle sensor or circuit.
9
Crank angle sensor or circuit./
#1 cylinder position
10
Intake air temperature sensor or circuit.
11
Faulty ECU.
12
EGR failure.
13
Atmospheric pressure sensor (BARO sensor) or circuit.
14
Electronic Air Control Valve or circuit./ Idle air control valve
15
No Ignition output signal. Possible faulty ignitor.
16
Fuel injector circuit.
17
Vehicle speed sensor or circuit.
19
Lock-up control solenoid (auto trans. only)
20
Electric load detector. Possible open or short to ground in ECU wiring.
21
VTEC spool solenoid valve circuit.
22
VTEC oil pressure switch circuit.
30
A/T control unit ECM fuel injection signal "A"
31
A/T control unit and ECM circuit.
41
Heated oxygen sensor heater circuit.
43
Fuel supply system circuit.
48
Heated oxygen sensor circuit D15Z1 engine.
obd2
P0106 5 Manifold Absolute Pressure (MAP) Circuit Range or Performance.
P0107 3 Manifold Absolute Pressure (MAP) Circuit Low Input.
P0108 3 Manifold Absolute Pressure (MAP) Circuit High Input.
P0111 10 Intake Air Temperature (IAT) Sensor Circuit Range or Performance.
P0112 10 Intake Air Temperature (IAT) Sensor Circuit Low Input.
P0113 10 Intake Air Temperature (IAT) Sensor Circuit High Input.
P0116 86 Engine Coolant Temperature Circuit Range or Performance.
P0117 6 Engine Coolant Temperature Circuit Low Input.
P0118 6 Engine Coolant Temperature Circuit High Input.
P0122 7 Throttle Position Sensor Circuit Low Input.
P0123 7 Throttle Position Sensor Circuit High Input.
P0131 1 Primary Heated Oxygen Sensor Circuit Low Voltage (Sensor 1).
P0132 1 Primary Heated Oxygen Sensor Circuit High Voltage (Sensor 1).
P0133 61 Primary Heated Oxygen Sensor Circuit Slow Response (Sensor 1).
P0135 41 Front Heated Oxygen Sensor Heater Circuit Fault (Sensor 1).
P0137 63 Secondary Heated Oxygen Sensor Circuit Low Voltage (Sensor 2).
P0138 63 Secondary Heated Oxygen Sensor Circuit High Voltage (Sensor 2).
P0139 63 Secondary Heated Oxygen Sensor Circuit Slow Response (Sensor 2).
P0141 65 Secondary Heated Oxygen Sensor Heater Circuit Fault (Sensor 2).
P0171 45 System is too lean.
P0172 45 System is too rich.
P0300 Random Misfire.
P0301 71 Cylinder #1 Misfire or Random Misfire.
P0302 72 Cylinder #2 Misfire or Random Misfire.
P0303 73 Cylinder #3 Misfire or Random Misfire.
P0304 74 Cylinder #4 Misfire or Random Misfire.
P0305 75 Cylinder #5 Misfire or Random Misfire.
P0306 76 Cylinder #6 Misfire or Random Misfire.
P0325 23 Knock Sensor Circuit malfunction.
P0335 4 Crankshaft Position Sensor Circuit Low Input.
P0336 4 Crankshaft Position Sensor Range/Performance.
P0401 80 EGR Insufficient Flow Detected.
P0420 67 Catalyst System Efficiency below Threshold.
P0441 92 Evaporative Emission Control System Improper Purge Flow.
P0452 91 Fuel Tank Pressure Sensor Circuit Low Input.
P0453 91 Fuel Tank Pressure Sensor Circuit High Input.
P0500 17 Vehicle Speed Sensor Circuit malfunction (Manual Transmission).
P0501 17 Vehicle Speed Sensor Circuit Range/Performance (Automatic Transmission).
P0505 14 Ignition Control System malfunction.
P0700 70 Automatic Transmission problems.
P0715 70 Automatic Transmission problems.
P0720 70 Automatic Transmission problems.
P0725 70 Automatic Transmission problems.
P0730 70 Automatic Transmission problems.
P0740 70 Automatic Transmission problems.
P0753 70 Automatic Transmission problems.
P0758 70 Automatic Transmission problems.
P0763 70 Automatic Transmission problems.
P1106 13 BARO Circuit Range/Performance.
P1107 13 BARO Circuit Low Input.
P1108 13 BARO Circuit High Input.
P1121 7 Throttle Position lower than expected.
P1122 7 Throttle Position higher than expected.
P1128 5 Manifold Absolute Pressure (MAP) Lower than expected.
P1129 5 Manifold Absolute Pressure (MAP) Higher than expected.
P1149 61 Primary Heated Oxygen Sensor (Sensor 1) Circuit Range/Performance Problem.
P1162 48 Primary Heated Oxygen Sensor (No. 1) Circuit malfunction.
P1163 61 Primary Heated Oxygen Sensor (No. 1) Circuit Slow Response.
P1164 61 Primary Heated Oxygen Sensor (No. 1) Circuit Range/Performance.
P1165 61 Primary Heated Oxygen Sensor (No. 1) Circuit Range/Performance.
P1166 41 Primary Heated Oxygen Sensor (No. 1) Heater System Electrical.
P1167 41 Primary Heated Oxygen Sensor (No. 1) Heater System.
P1168 48 Primary Heated Oxygen Sensor (No. 1) LABEL Low Input.
P1169 48 Primary Heated Oxygen Sensor (No. 1) LABEL High Input.
P1253 21 VTEC System malfunction.
P1257 22 VTEC System malfunction.
P1258 22 VTEC System malfunction.
P1259 22 VTEC System malfunction.
P1297 20 Electrical Load Detector Circuit Low Input.
P1298 20 Electrical Load Detector Circuit High Input.
P1300 71 Multiple Cylinder misfire detected.
P1300 72 Multiple Cylinder misfire detected.
P1300 73 Multiple Cylinder misfire detected.
P1300 74 Multiple Cylinder misfire detected.
P1336 54 Crankshaft Speed Fluctuation sensor intermittent interruption.
P1337 54 Crankshaft Speed Fluctuation sensor - No signal.
P1359 8 Crankshaft Position/TDC sensor Connector disconnection.
P1361 8 TDC sensor intermittent interruption.
P1362 8 TDC sensor - No signal.
P1366 58 TDC sensor #2 intermittent interruption.
P1367 58 TDC sensor #2 signal.
P1381 9 Cylinder Position sensor intermittent interruption.
P1382 9 Cylinder Position sensor No signal.
P1456 90 Evaporative Emission Control System Leak detected (Fuel Tank System).
P1457 90 Evaporative Emission Control System Leak detected (Control Canister System).
P1459 92 Evaporative Emission Purge Flow Switch malfunction.
P1491 12 EGR Valve Lift Insufficient detected.
P1498 12 EGR Valve Lift sensor High Voltage.
P1508 14 Idle Air Control Valve Circuit Failure.
P1509 14 Idle Air Control Valve Circuit Failure.
P1519 14 Idle Air Control Valve Circuit Failure.
P1607 ECM/PCM Internal Circuit Failure A.
P1655 30 SEAF/SEFA/TMA/TMB signal line failure.
P1660 70 Automatic Transmission FI signal A Circuit Failure.
P1681 30 Automatic Transmission FI signal A Low Input.
P1682 30 Automatic Transmission FI signal A High Input.
P1686 31 Automatic Transmission FI signal B Low Input.
P1687 31 Automatic Transmission FI signal B High Input.
P1705 70 Automatic Transmission problems.
P1706 70 Automatic Transmission problems.
P1738 70 Automatic Transmission problems.
P1739 70 Automatic Transmission problems.
P1753 70 Automatic Transmission problems.
P1758 70 Automatic Transmission problems.
P1768 70 Automatic Transmission problems.
P1773 70 Automatic Transmission problems.
P1785 70 Automatic Transmission problems.
P1786 70 Automatic Transmission problems.
P1790 70 Automatic Transmission problems.
P1791 70 Automatic Transmission problems.
P1792 70 Automatic Transmission problems.
P1793 70 Automatic Transmission problems.
P1794 70 Automatic Transmission problems.
P1870 70 Automatic Transmission problems.
P1873 70 Automatic Transmission problems.
P1879 70 Automatic Transmission problems.
P1885 70 Automatic Transmission problems.
P1886 70 Automatic Transmission problems.
P1888 70 Automatic Transmission problems.
P1890 70 Automatic Transmission problems.
P1891 70 Automatic Transmission problems.
Rice-Rocketeer
01-02-2002, 02:33 AM
:eek:
YOU'Z A HOOOO!!!
oops sorry, I mean't
YOU THE MAAAN!!!
Now all I gotta do is get inspired to collect all these informative posts and do the next FAQ update. :buck
evil_elmo
01-02-2002, 03:36 AM
good work!!!!!
sindogg
01-05-2002, 02:18 AM
nice. You always have good info
Barwick
06-08-2002, 04:11 PM
this was helpful, but I need to get a better diagram of where the #*%( the thing I need to short is located. I can't find this bastard anywhere.. there's only one connection, and it looks like it's for the blower fan or whatever.
Barwick
06-08-2002, 04:57 PM
nevermind found it.. code 4 & 9 on OBD1.. can't figure out the problem still though, don't have a voltmeter.
bastouille
02-26-2003, 05:18 PM
Hi!
You just saved me 45$!! (that's the price of an ECU reset by my Dealer)
I didn't find the service check connector though (didn't search for long, I confess). Anyway I knew it was a frozen MAP sensor problem, so I went to the reset procedure right away. At first, I found the MTR CHCK fuse and thought it could be the good one since my car is a 1997 and the system seem to be different. It didn't work. I then found the BACKUP/RADIO fuse and saved 45$!
Thank you very much.
ric
03-02-2003, 02:08 AM
wow i think i made this post over two years ago, i cant believe people still actually look at it.
si-anara
11-18-2003, 12:02 PM
i have a p1259 after installing a apexi vafc what can i do to fix this
CiViC.DK
11-11-2005, 08:12 PM
there is a fuse called Hazard. Pull it out for 30 seconds to reset your ECU (1987-1991)
Best regards
CiViC
bastouille
11-15-2005, 07:02 PM
Best regards
CiViC
Well... this is an issue solved long time ago. My civic is actually a 1997 and I think that the fuse is "called" memory (or something like that) on these models. Anyway, that's what I did and I saved 50$ each time I had the problem (once a year). Thanks for the info anyway! (The Internet may be useful sometimes...) :-)
superbluecivicsi
11-17-2005, 02:53 AM
thread is 2 years old.
