Question about the speaker wires in my Civic...
SilverY2KCivic
12-28-2001, 10:43 PM
I'd really be appreciative of anyone that can tell me, for the rear speakers on a 6th gen Civic coupe, which wires for both left, and right side REAR speakers, which wire is the positive lead, and which is the negative lead? Thanks.
Swonder67
12-28-2001, 11:06 PM
look at where they lead to on the speaker. I think it will be labeled on the speaker.
SilverY2KCivic
12-29-2001, 02:26 AM
I wish it was that simple, but the OEM rear speakers don't have that info on them. :( Not even a marking to indicate which is pos, or neg... :(
sparq
12-29-2001, 10:02 AM
Well what colors do you have for the wires? Usually the DARKER colored wire would be the negative... e.g.
You have a YELLOW and a DARK BROWN running the the speaker ~ the brown would be the negative. Or, if they are both the same color, look for a STRIPE down the wire. Two yellow, but one has a black or white line down it... that is going to be your negative :)
igo4bmx
12-29-2001, 03:41 PM
get a AA battery. connect the speaker wire from the speaker to the battery and then when you make contact, the cone should move a little bit in or out. if you connect the wires correctly to the battery, the speaker should move out. you will then know which color speaker is + and -
CivicRacerX
12-29-2001, 03:50 PM
Here's the data from a 98 Civic. As far as I know, your 2000 should be the same.
Right Rear Spkr(+) Red w/Yellow Stripe
Left Rear Spkr (+) Blue w/Yellow Stripe
Right Rear Spkr (-) Brown w/White Stripe
Left Rear Spkr (-) Gray w/White Stripe
Hope that helps. If not, the other way is to hook up a battery (9v will work) to the speaker terminals. If the speaker makes a pop (the cone should move OUT, I believe) then you have it right. If it doesn't make a sound (I'm pretty sure it will cave in here) then you have it backwards.
:devil: C
:devil: C
xivera
12-29-2001, 05:20 PM
CiviRacerX is correct! :)
