P11 KYB AGX Shocks/Struts
ty423
12-26-2001, 11:14 PM
Ok....so who has tried it.
P11 1999+ Infiniti G20 US
Fronts - 741029
Rears - 741021
So does this setup work?? Anyone?
wickedG20
12-27-2001, 12:13 AM
The front's come off a 91-96 G20 (P10) and the rear from a 95-99 Sentra (B14)
someone please let us know... ;)
ty423
01-17-2002, 03:08 AM
ok.....since no one is daring to do this...I went out and ordered the rear set...I bought it yesterday and I might try them on tomorrow....as you know I was also the one who tried maxima shocks but was horrified by the results. Raising my car back to stock plus an inch...hehe anyways I now am trying 95-99 sentra rears KYB model number 741021...I will take pics of install since I have a digi cam now....wish me luck...
G-Forces
01-17-2002, 08:58 AM
So were the Maxima shocks the same dimentions as the G20 ones? Would you mind taking some measurements of the AGX and stock shocks when you do this?
wickedG20
01-17-2002, 04:13 PM
I believe the maxima shocks were a little taller than the stock shocks. Then someone mentioned that he aligned the stock shocks with the KYB AGX Sentra shocks and they matched up perfectly.
ty423
01-18-2002, 03:24 AM
I did it...I installed it....I have pics but my webspace I use is down...will post later....it worked...95-99 Sentra/200SX
G-Forces
01-18-2002, 07:18 AM
Cool. The next thing I'm going to do is measure the rear beam of the 96-99 Sentra and compare that to the P11 rear beam. We might have some more options for rear sway bars if they line up exactly.
gdalton
01-18-2002, 11:54 AM
Sweet, now we have some more options for suspension setups, nice job ty423.
ty423
01-18-2002, 04:33 PM
Here are the pics....didn't take a pic of my car afterwards because you can't tell the difference in height anyways.
http://communities.msn.com/_Secure/0OAAAAPQT5C4!xYF*xqFpXHotQxYI7gAwxX2sW1XooL5kYXYO! YLM93aHnU25gSuSz3zocbKvE5Nji3t4ZFfT83QAcAA6AC8A/KYBinstall1.jpg
http://communities.msn.com/_Secure/0OACqMPUTEC8!xYF*xqFpXIgtdQgkTwQdVZG6VpkhwzEmE4aOo KfuXBDeR0GEw3vByZB**QSDhWk90zYc6lFsWHQAcAA6AC8A/KYBinstall2.jpg
http://communities.msn.com/_Secure/0OAAAAPYTPC8!xYF*xqFpXHTqMlbJPimkl3sOIDasJ5JLFuCsl VxL*l0h6M6ZQxfdAu3lxv0GEcZitSpNq5WgRwAAAAAAAAAA/KYBinstall3.jpg
AznVirus
01-18-2002, 06:10 PM
um they arent showing up, well for me at least.:p
2002G20Racer
01-18-2002, 06:36 PM
I see the pic's...
AznVirus
01-18-2002, 06:52 PM
nevermind :p im seeing things... :p
ty423
01-20-2002, 04:54 AM
hmmm read a earlier post on P10 KYB settings....I wonder what settings I should leave mine at...I am currently using 2/4 but getting bouncing in the rear on come bumps....I think I should first find out exactly what my spring rates are for the H&R....anyone know what the spring rates are for H&R????? please let me know..
gdalton
01-20-2002, 07:57 PM
It has spring rates of 170-190 front, 250-270 rear. These are progressive rate springs. That is off of g20.net. Hope that helps, let us know how it turns out.
Trag
01-25-2002, 09:01 PM
hey what was the model number for the shocks off a 200sx/sentra and the p10 fronts.
G20Rob3
01-26-2002, 10:55 PM
Hey Ty, did the struts raise your lowering job at all? I was a bit worried about it lifting my ride (I don't want to screw with my drop). Also, what settings did you choose fro your front and rear? How does it handle with those settings?
ty423
01-27-2002, 04:36 AM
G20ROB It didn't raise or lower anything...it is the same height....I tried couple different settings..now I have it on 3 front and 5 rear...I think I am going to lower it but still deciding what combo to try...man it handles way better.....I didn't know my car can handle like that...even when I had my rims and 225 tires I never handled this well....right now currently I am on stock tires and it handles awesome...
bafo
01-31-2002, 11:03 PM
I saw the pics for the KYB AGX´s with the H & R springs, but can´t find the impressions for this setup.
Last saturday I installed the H & R on my 98-99 Primera with the stock shocks and the car is crap now, it is too bouncy. Went to a shop for a test on the shocks and there is only one in good shape, meaning I need a new set.
Again, how the KYB AGX´s work with the H & R springs:rolleyes:
How the H & R springs work with stock shocks ( but in good shape):confused:
Thanks in advance
wickedG20
01-31-2002, 11:20 PM
I have just received my H&R Springs and ordered my KYB Shocks today. I hope to give a lot of info on the set-up, thanks
ty423
02-01-2002, 04:13 AM
They are ok...Yeah the H&R are bouncy on stock shocks....Right now they are pretty stiff feeling do to the KYB AGX....It might be too stiff for some people but this is how I like it....If you want better ride then go with softer springs but for performance...I think these are it....Its all what you want and how you want to drive it...
Trag
02-05-2002, 07:19 PM
are you guys sure that the 91-96 g20 will fit a 2000 g20 has anyone tried the front
ty423
02-06-2002, 12:55 AM
You should read the posts. I have this setup and yes it works...and now I have it for sale. I want to trade with someone and just swap the suspension.
G20TurboVisionCrew
02-21-2002, 04:59 PM
I ordered the Agx's today, and will be gettting them tomarrow, already got g/c coilovers, hope it rides smooth!!! will find out on sunday :p
