Pushrod vs. SOHC vs. DOHC
Pages :
[1]
2
beef_bourito
01-11-2004, 04:14 PM
What are the advantages and disadvantages, performance wise, of Pushrod engines vs SOHC and DOHC engines? Also what are easier to maintain?
MustangRoadRacer
01-12-2004, 10:21 AM
Pushrod is best for power, OHC is good for economy.
That's why race engines are pushrod. I think there is something about losing power through the valvetrain when you deal with very powerful engines.
That is not to say OHC is BAD for power, just simply not AS good.
ivymike1031
01-12-2004, 11:52 AM
generally speaking, overhead cam engines allow higher rev operation, and thus are better for peak power output. They're found in many different exotic car and racing applications (Ferrari, IRL, etc) where high rpms are desirable.
Pushrods are generally cheaper to make for V engines than OHC, OHC is sometimes cheaper for inline engines.
Using two cams instead of one (DOHC vs SOHC) can give you a bit more flexibility when designing lift profiles, as you'll have less contact stress, and you may be able to achieve higher speeds. DOHC is a logical choice if you have a variable cam phasing mechanism, as you can put your intake and exhaust lobes on separate shafts.
Both OHC and pushrod valvetrains can use timing chains or timing belts, but timing chains are more common on pushrod engines, and timing belts are more common on OHC engines. The advantage of a chain is that it lasts longer; belts are quieter, easier to package, and offer better high-rev performance if the drive load requirements aren't too high. OHC and pushrod configurations can both use hydraulic lash adjustment, which almost eliminates the need for periodic manual lash adjustments.
Valvetrain friction can go either way. For reduced valvetrain friction, it is preferable to use a rolling follower, and it is preferable to use manual lash adjustment. Either of those can be done on a pushrod engine, but they seem to be more common on OHC engines. An OHC valvetrain will generally have less mass to control (hence the potential for higher operating speed), which translates to lower spring forces for a given operating speed, and lower friction.
454Casull
01-12-2004, 04:03 PM
What kinds of race engines use pushrods? I know there are those exotic sports cars that use domestic big blocks, but what others?
ivymike1031
01-12-2004, 04:08 PM
avg joe's american v8 hotrod. maybe nascar.
FYRHWK1
01-12-2004, 05:57 PM
pushrod engines are easily capable of keeping up with multivalve OHC engines mustang, but they're hardly "better". For smaller engines OHC is the way to go, you need to rev then to use the gearing necessary for fast acceleration. For larger engines it's not as much of a problem IMO since you're going to produce alot of torque anyway there's no need for high RPMs and short gearing.
If you aren't revving high then OHVs valvetrain issues won't come into play anyway, the LS6 can already rev to 7000 without any float, it doesn't need to go any higher and its head flows more air then it needs. If you are revving high then you use OHC, unlike ass-i mean NASCAR the general public doesn't know how to set the lash on their solid roller pushrod motors and hydraulic lifters haven't seen duty much above 7-7500 RPM to my knowledge.
SaabJohan
01-12-2004, 06:00 PM
4 valve DOHC heads have also showed that they can be used in high power engines without giving too bad exhaust emissions too.
For maximum power the best head configuration is a 4 valve pentroof type head with valves angled around 20 degrees. The combustion chamber should have the spark plug raised in the center and the smaller exhaust valves should be placed close to eachother, and there shall be a raise between the valve looking something like a + and the squish zone should be angled. The valves shall be actuated by twin cams (per cylinder bank) and fingerfollowers (preferbly).
This type of head can be found in F1, CART, touringcars and so on. Fingerfollowers and angled squishzones are however not always used since they are quite "new". If a cylinderhead is modified this also sets some limitations.
Neutrino
01-12-2004, 07:29 PM
here is a pic of a pentroof combustion chamber with a central spark plug...the valves angle at a very steep 48 degrees however
http://www.sportcompactcarweb.com/projectcars/0310scc_projneon13_s.jpg
and i would like to agree that the DOHC setup is by far the better one even on high displacement engines....the 6.0 in enzo for example or the 5.7 in the carrera GT
another advantage of DOHC engines that IMO is crucial is the fact that you can adjust the lift and timing of the exaust and intake valves independetly from each other...this raises the tuning posibilities to a new level
the only advantages of pushrod that i can see are:
1. cheaper
2. smaller head
1. cheaper
2. smaller head
FYRHWK1
01-13-2004, 01:31 AM
Lower weight and less complexity as well, assuming you can meet your airflow needs with an OHV head (and since most pushrod designs dont rev high airflow need is decreased) and don't wish to rev over 7500 it's a fine choice. The lower and lighter engine has many handling benefits as well, a dry sump OHV engine is extremely short, supposedly the new corvette will have a high perf. model utilizing that.
There are concept 2 cam OHV engines, 1 for intake 1 for the exhaust, with that working an OHV engine with VVT is possible, you can run as many valves off of that as you like too. Pushrod weight and flex is always going to be a problem, but new metals have already fixed much of that, chromemoly rods are very light and stiff and for the enthusiast solid lifters will fix any valve float issues at high RPMs.
MustangRoadRacer
01-13-2004, 08:42 AM
Pushrod race engines:
Top fuel dragsters 7-8000 hp
Nascar 700 hp
formula ford 170 hp (only 1600 cc w/ 2 barrel carb)
some LeMans cars (viper, vette)
DOHC is used in the IRL however. with 650 hp.
and toyota atlantic (cart) uses the 4age. DOHC
Nascar 700 hp
SaabJohan
01-13-2004, 03:04 PM
Nascar 700 hp
Many of the engines you mentioned are limited to push rods, they don't use it because they are somehow better.
DOHC is used in almost all motorsports with a few exceptions. DOHC is for example used in F1, CART, IRL, most GT racing cars (Corvette, Panoz and Viper being the exceptions), WRC and touring cars (like BTCC). Some of the highest brake mean effective pressures of NA engines have been measured in touring cars like BTCC.
Nascar 700 hp
MustangRoadRacer
01-13-2004, 03:09 PM
yes, but F1 and CART use pneumatic valves, which is kinda different.
texan
01-13-2004, 03:47 PM
OHV is certainly not superior, among other things already mentioned the pushrod intrusion through the cylinder head limits port design and shape. Of course more of the airflow differences between domestic and import cylinder head flow is due to the Big 3's reliance on displacement to make airflow rather than brilliant cylinder head design and RPM, but then either approach can work extremely well.
454Casull
01-13-2004, 04:47 PM
How so? They are not pneumatic "valves", merely pneumatic valve RETURN systems. AFAIK F1 and CART still use DOHC valve actuation systems.
SaabJohan
01-13-2004, 05:50 PM
F1 use pneumatic springs instead of conventional springs. CART use conventional springs due to regulations.
http://www.delwestusa.com/images/2_airspring.gif
FYRHWK1
01-14-2004, 02:41 AM
"rather then brilliant cylinder head design" I don't know why you would say that, to be able to do what GM's done with only 2 valves is fairly impressive in my book, and tuners have found alot of room left in them as well.
calgary_redneck
01-20-2004, 02:09 AM
I believe there are some good engines of the ohc design and ohv design. They have both almost been around for an equal amount of time and they both have been shown to make amazing power when being clean enough for today low emission standards. The next big step will be cam less engines that will make both pushrod and ohc engines seem obselite
MustangRoadRacer
01-20-2004, 04:32 PM
OHV has been around much longer than OHC.
And Camless engines aren't that fantastic.
SaabJohan
01-20-2004, 04:53 PM
Note that SOHC and DOHC are both OHV just like push-rod engines. The engines which aren't OHV are the old side valve engines.
MustangRoadRacer
01-20-2004, 07:02 PM
yes, but I think the OHV in this case meant Cam in block.
calgary_redneck
01-20-2004, 08:32 PM
yup saabjohan please try to pay attention to the conversation. Push rod engines are generally refered to as ohv. As for the comment from mustang I'm not sure what you are baseing your oppinion on camless engines on. In theory they will blow everything else out of the water I'm interesting why you think they are that great especially seeing how I doubt you have diven one as they haven't been released yet. And acually ohc can be traced back to at least the 1920's so yes the both have been around a simalar amount of time
SaabJohan
01-21-2004, 08:26 AM
Use the correct terms instead, it avoids misunderstanding. Over Head Valve refers to nothing more than that the valves are placed in the cylinder head, which is usually the case for both push rod and OHC.
MustangRoadRacer
01-21-2004, 08:54 AM
That is true, that they have been aroud since the 20's, but Cam in block has been around since before the turn of the century.
Show me proof of the vast superiority of camless engines andI may just change my mind.
calgary_redneck
01-21-2004, 08:11 PM
Well its a little bit hard to show proof seeing how they haven't been mass produced yet how even in theory a camless engines should be able to alter the lift and duration for peek performance at any rpm and driving condition. It will be like vtec only 100 times better very good hp numbers should be able to be produced from even very small engines with exelent drivablity. Now of cource there will be teathing problems as with any new tecnology and I probably wouldn't want to buy one till they get it perfected but it should be quite amazing once they get it right
calgary_redneck
01-21-2004, 08:12 PM
saab everyone understood except for you
FYRHWK1
01-21-2004, 10:28 PM
I'm not going to jump on any bandwagon here as you're right, I just always viewed it as the position of the cams relative to the valves. OHC having the cams over them or OHV with the cams under, just always made sense to me, but like I said i'm not getting into another capslock match on here.
454Casull
01-22-2004, 12:11 AM
You're arguing over a mistake on your part. I'll have to side with SJ.
If I were to say a Honda engine used OHV, would your blood pressure rise?
Moppie
01-22-2004, 03:05 AM
And Ill have to Ditto that.
Enginers have spent hundreds of years developing special terms and word usages to avoid confusion and allow the easy and efficant transfer of ideas, so when discussing things of a technical nature it pays to adhere to those terms.
And since OHV Hondas have entered the conversation Im wondering if Ferrari, BMW and Honda have ever made a pushrod engine?
They are generaly regarded as the three best engine builders in the world, proven by thier F1 success. (Note, Im excluding low production manufactors like Cosworth, as they normaly start with a mass produced engine design).
MustangRoadRacer
01-22-2004, 04:26 AM
yes SAAB was right.
using incorrect language, regardless how common, does not make it correct.
any specs/info on the camless engine?
who makes it?
who makes it?
calgary_redneck
01-22-2004, 06:06 PM
I believe alot of companies are running with the concept at the moment I know for sure gm is working on it and plans to have some engines using it in the not to distant future how ever it will require going to a higher voltage electrical systems for sure to supply the soliniods that will be used to open the valves
ivymike1031
01-22-2004, 10:02 PM
assuming you use electric solenoids to open the valves... that's not the only option for a "camless" engine. You can also use lower-power solenoids if you pressure balance the valve, or use a force multiplier of some sort (hydraulic, pneumatic, etc).
I say "blame canada!"
MustangRoadRacer
01-23-2004, 11:20 AM
f1 uses pneumatic valves with success.
ales
01-23-2004, 12:14 PM
As has been pointed out to you, F1 engines still use cams to open valves and a pneumatic system to close them.
calgary_redneck
01-24-2004, 02:59 PM
wow ivy mike that was inteligent
454Casull
01-24-2004, 07:47 PM
Somehow, that doesn't sound like a compliment. :)
quaddriver
01-25-2004, 09:27 PM
valve actuation does not really have much bearing on power output as racing has shown.
however, if you need a small engine to make the hp of a large engine, you need to force feed it, OR increase the RPMs. when you increase rpms, xOHC designs allow more consistent valve actuation at higher rpms (chevy 350s run over 9000rpm in nascar so pushrods can move quickly)
the problem with xOHC designs is the increased size, noise and rotational moment of the moment.
For example, a SOHC 4.6 or 5.4 ford engine, is larger than the IH 444 block diesel. Kinda interferes with aerodynamic body designs.
Plus, take a cam for a V8, has 5 bearings to oil. The same v8, if only a SOHC has 10, if dOHC it has 20. This means increased demand on the oiling system to deliver high pressure oil to the very top of the motor - not an easy feat. (the most common failure of xOHC motors is in fact damage due to top end oil starvation)
Also, OHV motors are usually chain driven for the cam, nice and quiet and reliable - chains RARELY break. xOHC designs use external belts, which break often if not changed often and add a lot of noise.
Lastly, you now have cams and pulleys rotating at the outer extremes of the motor, making it a bear to hold still in the engine bay.
So, xOHC engines have advantages, but they have disadvantages.
ivymike1031
01-26-2004, 12:18 AM
Changed often? As in once every 5-7 years? And who ever told you that chains were quieter than belts?
quaddriver
01-26-2004, 11:07 AM
well the average american drives appx 15K miles a year, making each change on average every 4 years, and, the average american trades in his car at appx 58K miles so if the impending large labor bill was one of the reasons why he traded the car, the next buyer has a nice surprise to add to his total.
My ears. An oiled chain buried inside the motor is far quieter than a kevlar reinforced rubber belt with cogs no less running on at least 2 pulleys behind a thin plastic cover.
ivymike1031
01-26-2004, 12:02 PM
Why change the belt at 60k, when the mfr likely recommends 90k-120k miles, or 7 years (whichever comes sooner)?
Well measurements don't support what your ears are telling you, except in very special circumstances (where someone went to a great deal of trouble to make a particularly quiet chain and a noise-attenuating cover to go over it).
some info on the subject:
http://www.hse.gov.uk/pubns/top10noise.pdf
"Noisy chain drives can often be replaced directly with quieter timing belts. Within the range of timing belts available, there are also quiet designs that use different tooth profiles to minimise noise. There is also a very new design of belt for applications where noise is critical which
uses a chevron tooth pattern to provide very quiet running. Noise reductions in the range of 6 - 20 dB are often possible using this approach."
http://www.me.ic.ac.uk/dynamics/struct/VALSE/uan_ancona2000_2.pdf
"Even if timing belts are generally considered as silent transmissions, when compared to mechanical chains, nevertheless a large interest is devoted to further enhancement of the vibrational behaviour under operating conditions."
http://www.babcox.com/editorial/us/us70343.htm
"Play in a gear or chain style cam drive can cause noise, retarded valve timing and/or ignition timing depending on the engine design and application. With rubber timing belts, noise is seldom a problem even at high mileages. Valve timing and ignition timing (if it reads off the camshaft) also remain steady because timing belts don’t stretch."
http://www.powertransmission.com/feature/bcdrivenews.htm
"The Browning HPT synchronous drive line from Emerson EPT combines the timing action of gears with the speed and noise level of belts. "
quaddriver
01-26-2004, 12:53 PM
well if we beleive stats, honda and toyota are the most popular cars sold in the USA, and they recommend 60K...so....at any rate it does not matter. A belt needs changed. Period. A chain does not until end of engine life - period.
and I notice not one of the links was from an auto manu or testing magazine (like cd, rt, MT, aw, SC, ff, mm &c) who actually measure noise with a meter and report coincidently the same findings I do ;-)
PS - I defy you to stand outside a GM 3800 and find ANY xOHC engine that makes less noise. I stand on my position. You are free to argue the minority position as long as you desire.
calgary_redneck
01-26-2004, 02:08 PM
yup honda for 1 and many others recomend timing belt repacement at 60k or 100,000km how ever there are cases when they even break before this time. On an interferance engine as many ohc's are this results in at least a few bent valves.
SaabJohan
01-26-2004, 02:09 PM
Chains are used in both push rod and OHC engines (BMW and Saab are examples on the latter). Chains tend to make more noise, especially when they become worn. (basic engineering)
Many high revving motorcycles use chains for the cams, but at high performance applications gears are common. This introduces however more noise.
The service interval on belts have become a lot better lately, 60k is very low. But the cost of a belt is low and many people can do it theirself if they want (not that much more complex than to change waterpump/generator/servopump/AC belt). A chain lasts longer, but not until the end of engine life (unless you have a low quality engine), and it's more expensive to change.
Both chains and belts are stretched somewhat during their life.
Both push rod and OHC engines need oil to the top of the motor, escecially with high performance engines when valve spring cooling is important.
The difference in size of a push rod and DOHC engine is very small, the increase in performance more than compensate for this.
The largest valvetrain problem is probably hydraulic lifters, which can cause wear of too high pressure against the cam or start to leak and the cam to lifter clearance till be off.
ivymike1031
01-26-2004, 03:34 PM
What recommendations are you guys referring to? I have a Honda service manual in front of me right now, for 1996-2000 Civics, all models, recommending timing belt replacement at 105,000 miles for severe service, excluding where outdoor temps are frequently in excess of 110degF or colder than -20degF, in which case they say 60,000 miles.
I notice that you don't have any such findings to show us either. Not that I'd be impressed with NVH results measured by people working for a magazine - these people are english majors first, mechanics second, engineers "not at all," remember? NVH measurement is difficult to do right in a proper lab setting, let alone in some backyard dyno.
If the GM 3800 is your "gold standard" of engine refinement, then I know what sort of person I'm speaking to, and that it's pointless to continue this discussion of automotive technology...
I leave it to you to pursue an education in automotive design; it's not my job or desire to educate you (nor am I confident that it would be possible).
texan
01-26-2004, 03:37 PM
90k miles is the recommended timing belt change for every Honda I've seen in the US. And I have never heard of one breaking before 90k unless someone went and screwed with it, the gears or the cover at an earlier point.
While some manufacturers are getting better at making DOHC heads short, there is a very sizeable difference between your typical V configured engine in cam-in-block vs. OHC design. Though you are definitely correct that for basically any application the OHC has enough basic airflow advantage to compensate for this.
quaddriver
01-26-2004, 05:30 PM
In other words, as I said, Honda recommends a 60K interval. At least you now admit that. Sidebar: what interval does ANY manufacturer recommend for a chain driven cam? Whats that? We could not hear you say the word 'None' clearly.
Score: xOHC motors have cam driving mechanisms that require inspection, service and replacement on a frequent basis over the life of the car. OHV motors have cam driving mechanisms that require nothing and last the life of motor. Advantage OHV as originally stated.
Well, managing editor of C&D Csaba Csere has an engineering degree which is more than you do, and he himself has conducted such tests AND he has an online presence - feel free to contact him and inform him how useless his findings are. Its not all that hard to measure the noise output from the engine bay at any RPM. Why, I even hear the measuring devices are simple enough be used by high school students such as yourself! Aint modern progress grand?
Actually, its the SAE who has named the 3800 from GM 'best', criteria being a number of factors not limited to power output, economy, emissions, reliability, noise, smoothness, service ease, and so forth. Please note, in the last few years it has supplanted even the SBC. An astute reader will notice a certain 'on topic commonality' between the two motors.
Hmm, forgive but Im not all that confident that you are all that intuitive, or even all that bright...
Especially when you are not contributing any....
You are so funny mikey....you want me to do what you have not...but suffice to say, I am satisfied with my college education and degrees earned. I think I'll stand pat...however, when you do graduate high school, I highly recommend a college education if you can swing it. Very beneficial.
Perhaps the most accurate thing you have said to date in all of your posts...we (the reading public) agree, it would not be possible for you to educate myself, or anyone else reading here for that matter.
btw - that fact that you do have a chilton book for your car is admirable, many people fly blind. But please tell us you didnt 'rice it out', take if from someone much older and more experienced: it does NOT look cool that way.
ivymike1031
01-26-2004, 05:58 PM
Sure, in perhaps 5% of cases they recommend an interval that short. I don't think that's a very strong basis for your assertion that they must be changed frequently.
These "frequent" replacements of the timing belt that you keep harping on still amount to a single replacement in the entire life of the vehicle, in the vast majority of cases.
How about if you post a link to a site where this guy actually makes the claims that you attribute to him (belts are noisier than chains, in case you forgot what you're talking about). Alternatively, since you insist that he's making these claims, you contact him, then tell us what he says. That's the responsibility of the person making the ridiculous claims (you), not the person who says that something smells (me). You clearly haven't a clue about NVH measurement practice, nor about the equipment required. Not surprisingly, you have no idea what my credentials are either...
References? Year? I gather you're not a fan of supporting your blathering with anything credible...
Perhaps you should reassess that level of satisfaction. I think that my college education and present field of work put me on pretty firm ground here... and I can tell you don't have a clue.
...or so you've heard, right?
btw, it's not a chilton book, and it's not for my car. It's a factory service manual for a Honda Civic, which I keep on my desk for the occasional reference or diagram. It's great for occasional client questions like "can you give me any examples of a lost-motion device that is used in the valvetrain of a current production engine?"
You may be older, but based on your statements thus far, you're clearly not more experienced in the field of automotive design.
quaddriver
01-26-2004, 06:06 PM
eh, sorta....OHV motors really only need a smidgen of oil to lube the ball/rocker assembly, pushrod end and cool the springs.
since the cams in an xOHC motor are held in aluminum, in most cases without benefit of a bearing shell, forming a hydrodynamic wedge is critical - and maintaining same across the cam. On a DOHC V, there are 4 steel cams that can wipe out the aluminum bosses in MINUTES, not miles. In the old days, OHV engine had a simple 'x lbs per y rpm' oil pressure requirement...today, the xOHC motors tend to require much more oil rpessure at much lower rpms to ensure all the cams are oiled at idle.
Im not sure what you mean by size, do you mean physical size or displacement? displacement wise, you can have equal displacements with either method of valve actuation, however in terms of physical size - use the example I gave you, the 4.6L SOHC ford pickup motor is LARGER in physical dimensions than the 7.3L diesel!!! and note, a DOHC motor makes it worse.
As for your valvetrain comments....you're all wet. Hydraulic cam followers are what EVERY manu has went to. Now note, save geometry, the parts and use of are the same - with a solid setup, you must set the clearance correctly - just having said clearance leads to a LOT of noise (just ask anyone with an older honda ;car or bike; or toyota) and it accelerates wear. with hydraulic lash, the tension on the plunger is measured in inch-lbs, whereas the seat pressure on the valve is measured in ft-lbs. In solid designs, the lobe must whack the follower which deforms the iron or in some cases steel slowly but surely. In hydraulic designs, the cams are offset ground (in OHV applicatins) to rotate the follower/lifter - wear is negligible. whereas solid deisgns require readjustment every 15Kish miles due to wear, hydraulic designs last forever. but please note, the loss of oil pressure on either will cause negative results. I have seen cam lobes wiped clean, but the vast majority as any professional will tell you will be incorrectly set solid designs - once the clearance is gone, the cam lobe is ALWAYS against seat pressure, (as opposed to plunger pressure in a hydraulic setup) Do hydraulic lifters collapse? yep, but it is so rare as to not require mention.
Of note is the use of roller followers today, I and many others have taken roller lifters out of 200K mile motors and reused them after inspection on a fresh cam. they just dont wear out.
quaddriver
01-26-2004, 06:29 PM
Correct, I have no idea what you may be imagining.
well, you did open the door...so lets procede with the facts:
you dont have a degree in 'automotive design'
you dont work for any automobile or motorcycle manufacturer
you dont simply design automobiles nor any of the components. like it or not, those are the fact that you have now exposed. So you have attacked me ad hominem claiming 'expert status' why?
and this exposes more facts....
you are not engaged in employment in any matter dealing with anything automotive on a technical level. If you were, you would not have asked for the reference on the SAEs stance on the 3800, simply because you would have HAD it on your desk (for future reference, when you commit such blunders, especially in an online environment, your credibility is shot forever. shall we examine the other 713 posts you have made?)
Furthermore, you would know who Mr Csere is and have read him quite often. I am not going to do for you the homework you should have already done.
Ps - it is of light humor that we note you have not to date challenged any point in any of my posts on a technical level, merely the timing of suggested timing belt changes (all the while, on a grander level of humor noting that you skirted the issue that they in fact need changed, whereas chains do not, as I originally stated) I believe my correct stance at this point should be (in your vernacular): Bwahahahahahahah
ivymike1031
01-26-2004, 09:33 PM
That's correct, my degree is in mechanical engineering.
you dont work for any automobile or motorcycle manufacturer... you dont simply design automobiles nor any of the components.
That is wrong. In fact, I have been involved in the design of valvetrain hardware for some recent US automobile engines that you are probably very familiar with, and some that you will no doubt become familiar with within a year or two.
Because you clearly don't know what you're talking about when it comes to the relative noise levels of different timing drive schemes. You do seem to have plenty of experience with the "I may not be an expert, but I play one on the internet" routine.
You really don't know what you're talking about. I am an SAE member (since 1996), and I have several of their publications on my desk currently, mainly dealing with piston and ring lubrication, oil consumption, and recent developments in low-friction coatings. I also read their monthly magazine, Automotive Engineering, and I get the sectional newsletter. I get the idea that you really have no idea what automotive engineers do during the day (work), or what they have on their bookshelves (Roark's formulas for stress and strain, Shigley's Mechanical Engineering Design, and/or Heywood, typically, with a smattering of Timoshenko or Hartog texts as well). Do you have any idea how many papers come out of SAE in a year? I get abstracts from about 20 per month, specific to the areas of design that I'm responsible for. You try reading all that sometime (I usually don't).
Yeah, like engineers have time to sit around reading car and driver. Come on. Now you want me to write a letter to him and ask "some kid on the internet says that timing belts are noisier than timing chains. Should I abandon my several years of experience in the design of timing drive systems and adopt his bizarre and ill-formed viewpoint?"
Well, since you clearly need things spelled out for you, let me say it plainly. Your statement that chain drives are quieter than belt drives is absolute rubbish. Technically speaking, you don't have a clue. Read some of the articles I linked to above, or go get a real education!(as I, and several of the other people posting to this thread, have done)
If you read this thread from the start, you might have noticed that in the fourth paragraph of my first post, I made the following statement: The advantage of a chain is that it lasts longer; belts are quieter, easier to package, and offer better high-rev performance if the drive load requirements aren't too high. I stand by that statement. I don't need to "skirt" the subject of timing belt changes. You seem to be intent on misrepresenting the frequency with which they must be performed, which is not entirely surpising, given that you seem to be prone to grandstanding and make-believe.
Unfortunately, HLA-equipped pushrod engines (OHV is not an adequate description) typically rely on oil feed through an orifice in the HLA to the pushrod to get lube oil to the over-head area. Oil flow through that orifice is restricted to something in the neighborhood of several grams per minute (say 24gm/min @ 100degC). Cams in the head often get oil drillings, and a much healthier oil supply. Not all overhead cam engines use aluminum heads (see Deere). Idle lubrication is the primary design factor for the oil pump for almost all engine configurations. Aluminum makes a pretty good journal bearing material.
Honda still uses mechanical lash adjustment, with a recommended adjustment frequency of about 60k miles. Mechanical lash adjustment is also used in a number of high-perf applications, and on a very large number of heavy duty diesels. Wear is definitely not neglible at the cam-follower interface on pushrod engines. Ask a mechanic. Pressure is never measured in ft-lbs (duh). With a hydraulic lash adjuster, the expansion spring preload is not very large (say 40N or so), but the force that the lash adjuster exerts against the cam & pushrod on the base circle when the engine is running is much higher (say 150N). If you'd like, I can explain to you how a typical HLA works. There are often collase and pump-up issues with HLAs during development, usually they're sorted out by the likes of me before the likes of you get an engine. A properly adjusted mechanical system will have less force on the cam-follower interface over the base circle than a HLA valvetrain (close to zero).
Roller followers are used on both overhead and in-block cam valvetrain configurations (as noted in my MUCH earlier post).
Moppie
01-26-2004, 11:04 PM
:lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol:
quaddriver do you seriously expect anyone here to take your comments sersiously?
Not only are you attacking one of the most knowledgable enginers I know, but you are doing it with no surporting evidence and incorrect use of terminology already clearly defined in this thread.
You are of course welcome to give and provide your opinions in the forums, but please stick to topics you know something about, unless your asking questions, and please refrain from flaming other members. It would be a shame to have to ban you before you make a complete fool of yourself.
quaddriver
01-26-2004, 11:33 PM
yes as a matter of fact I do. In my initial post I centered on 3 disadvantages of the xOHC engine. 'Mikey' jumped on one, and only incorrectly. He has obviously pulled a bit of wool over your eyes but I repeat, he has not coherently or accurately challenged any of the facts presented, in fact, in a bizarre form of transferrence, his last post(s) confirm what I said in my first, but he still ignores the third because the one thing I can assure you of, he is not whom he claims to be.
Ban if you must, but the attacks have only come from him.
calgary_redneck
01-27-2004, 12:15 AM
Well ivy mike they cirtianly didn't teach you any modesty or maturity at university.
quaddriver
01-27-2004, 12:29 AM
I do not believe that.
name one. Its put up or shut up time. Since you and you alone have claimed to be THE expert, its time to prove it.
I have already stated that an OHV (which will perfectly suffice for a defn here, only a field mouse would not know what is being discussed) is quieter than any xOHC in same application. If you are sooooo sure of yourself and have done sooo much research, you will simply post sound measurements of the engine bay. Or are you now claiming that xOHC engines are soooo quiet that the manus use noisier alternators and PS pumps because they can?
Again, I do not believe this. Comments you have made here and in other threads do not belie this.
yes you do need to skirt it. As I am saying now for the forth? time, one needs changed, one does not. I even listed (correctly) which design that is an advantage to and I did not misprepresent the frequency, I *GAVE* the frequency and you later confirmed it. If we assume, as the 'industry' does, that a cars primary and secondary life is 10 years, and if we gather up all the models sold in 10 years (1994-2004) and averaged the timing belt change frequency, who is more correct? you or I? (hint: I would not bet on yourself)
Besides being off topic, so? As I said and you have learned in the last 2 hours, the oil needed in the OHV heads' area is small.
No mikey, it is spec'd as a volume.
sidebar: I have to ask, because the answer I fear is apparent: you have never actually SEEN any of these systems in component form have you? Just ask and I will photo any of the components and upload them and explain to YOU how they work. the fact that oil travels up the pushrod is apparent. but how the flow is triggered you got wrong. way wrong.
I believe I mentioned that the oil system is different. And I beleive I mentioned that the supply requirements are higher. So you agree with me finally.
I didnt say they did, in fact I think I used the word 'most'. So aside from clouding the fact that I was, once again, not surprisingly right your point is? ps - iron on iron cam/boss contact is just as undesirable
So? this was not the topic, other than the fact that I and I alone mentioned that xOHC have a greater need at idle than OHV designs and you have agreed with now twice.
Once again I ask not so rhetorically if you have ever seen the component pieces. I dont believe I mentioned any preference in bearing material (but I would prefer trimetal designs if asked), however, without, as I and I alone mentioned, ANY bearing between the cam and boss, loss of material is catastrophic. Unless of course you think it is a good design to have the cylinder head itself literally eaten away....its not the most bizarre thing I have heard.
I didnt say there wasnt, for this other off topic presentation. I did say however that manus have moved away from mechanical systems, which I notice you do not dispute.
LOL, you get funny, OK, I asked one, myself. What is the wear then mikey? how much have you measured? on engines without oiling problems using hydraulic systems cams usually only need polished and the lifter bottoms reground. On mechanical systems, the lobes are ALWAYS deformed and the cam itself needs reground, IF it can be saved, often however with a smaller base circle. Again, it is hideously apparent that you have never observed first hand the components.
yes, I should have just said lbs. try to get as much mileage as you can out of that because it is the only error I have typed to date.
I know what you did, you looked at the torque spec for a zero net lash hydraulic motor, but since you have never actually seen one, failed to realize that the plunger was as fully depressed as far as it would go long before the target torque on the rocker stud was reached. nice try. And when running, because of HOW oil is force up the pushrod, when the valve seats (return pressure zero) and the cam returns to base circle, there is an instant where the plunger actually rises to the lash point, and the lifter fills. at this point the pressure on the cam base circle is neglible.
Given previous errors, I doubt that. But also given that I use, assemble, disassemble, modify and improve same, Id be happy to do the reverse.
they were sorted out perhaps 30 years ago mikey. The automotive community pretty much trusts the hardware as bulletproof
Boy, must be that CLEARANCE I was mentioning. Clearance=gap = no pressure. I never said this was a problem, I did however point out that the take up of said clearance IS a problem. But then again, you seem to feel that mechanical camshafts suffer less wear than hydraulic cams. Not only does that fly in the face of well, nearly everything learned to date, but pretty much defines the quality of the techincal responses received to date.
I dont recall saying they were not. In fact, I think to date my only comments about roller followers is that they seem to wear very well (meaning slightly if at all) - but again, that comes from actually SEEING the parts, using them etc. the whole gamut.
ps- GMs newest valve train technology, the VVT used on one of its 660 motors, hmmmm, is it mechanical or hydraulic? Not that this was ever the topic, but it shows which direction the industry continues to travel.
texan
01-27-2004, 12:31 AM
And they didn't teach you guys when to quit.
Ivymike's been posting here for years, dutifully answering engineering questions for the masses and without having to piss on anyone's parade. Now some people are waltzing in and after a few days on the board want to question his integrity, knowledge and honesty without even knowing who he is, what he does or where he's coming from (though some of you have made plenty of INCORRECT assumptions throughout this thread). Quit before I have to close the thread, and learn to be a little more respectful of the guys who regularly help others and just might be able to do the same for you... if you'd chill out and listen to them.
quaddriver
01-27-2004, 01:20 AM
this is good advice, however, lets be totally honest with history. I made one post, which as you note was challenged soley on the frequency of timing belt changes. A quick review of the posts shows that HE and he alone attacked. I have made no claims as to expertise - the unchallenged technical facts I post speaks for themselves. I feel no need to slam 'dicks' on the table. But, he has claimed:
Now please note, this statement is meant to give weight to his posts, however the statement can be true if he is the guy who sweeps the floors in said engineering building up to and including the project lead. This statement can even mean that he works for a sinterer manufacturing rocker arms. I know 30 or so people in St Marys PA making control arms for GM, does that mean I am gonna ask suspension tuning questions of them??? So yea, since he presented himself as THE expert in the US of A, Im gonna challenge him. In short, his statement was meant to confuse and support a damaged argument, nothing more. Why nothing more specific? I am close friends with design engineers for Powertrain, Motorsports, Shelby as well as people on the joint GM/chrysler design council. Many people know this from elsewhere and know I will find out a BS-er in a heartbeat. And when I say close friends I dont mean exchanging emails, I mean at my table, on my boat kind of close friends.
And texan, with all due respect, read his other posts in other threads, I took a few moments to do so after his first attack. His 'Im smarter than thou' additude is duplicated in each thread he contributes to. If that is help, then so be it, but my experience has found that people asking for help do not like smart azz answers.
Evil Result
01-27-2004, 01:39 AM
seems as though i'll be spaming ivymike with questions.:iceslolan
Anyways what is the simpler design OHV(Cam in block?) or OHC(Cam in head?)?
I'd have to say belts create less noise than chains if we consider there application to an OHC design, and a chain that long would be heavy, we also have to consider the HP of the engine and how much stronger the transfer medium to the cams has to be, which reflects the size and weigh increase.
Discuss amongst your selves :)
texan
01-27-2004, 02:19 AM
Simpler is a term neither layout lends itself to. Valve actuation is still a complex process, involing many rotating, reciprocating and sometimes heavy componentry (some of which requires VERY close production tolerances and high grade materials). Both have relative complexities in design, though all things considered I believe pushrod actuation through an in-block cam is mechanically simpler (it is after all a later invention). It's certainly more space efficient, but then again block design is significantly more complex, and cylinder head ports are flow compromised (though this could be minimized further than today's designs).
Whether or not chains or belts create the most noise isn't of much importance IMO. With either layout there is a combustion event regularly taking place just inches away that produces far more noise than either drive system, but it is also well suppressed with something as simple as a muffler. Chain driving Honda's S2000 motor doesn't seem to create any great underhood noise, and it's actually got a reasonably complex variable cam timing device thrown into this drive system. On the other hand my belt drive system seems nearly transparent underhood, but both have enclosures that are designed to supress their respective noise generating properties. In other words, it's how well you supress the noise coming off each that will matter to the end consumer, because both can be noisy or nearly silent depending upon how good a job the NVH crew does.
Lastly, there's also that intangible difference between noise and sound that will always muddle this argument. For example the quitest exhaust system isn't often the best appreciated, it's the "quality" of sound that matters more than it's quantity in these types of discussions. I prefer the metallic goings on of a double roller timing chain to a cogged belt drive, but that's just me.
ivymike1031
01-27-2004, 10:47 AM
No, you're generally expected to learn that sort of thing on your own. I must not quite be there yet, since I keep letting myself get dragged into these silly "discussions" on the internet, where "yeah, well I know a guy who knows an editor at a magazine who once said this, and his cousin knew my grandpa" gives as much weight to a position as "here are five published documents on the subject, by people who are familiar with the topic." I certainly get a whole lot more respect around the office than I do around the internet, which I suppose is a great deal more important in the end.
...and the latest VVT mechanism that I've seen from GM, which is mentioned here (http://www.new-cars.com/news/030327-gm-vvt-v6-cadillac-cts.html), uses a hydraulically actuated vane-type phaser (http://www.delphi.com/pdf/e/valve_vcp_vane.pdf) (as opposed to a spline-type phaser) on each cam (OHC). It also uses three separate chains (hydraulically tensioned) to drive the cams.
more info: http://media.gm.com/division/powertrain/products/engine/carengines/2004/2004LY7A1.DOC
454Casull
01-27-2004, 02:34 PM
You don't see him harping on your spelling, do you?
454Casull
01-27-2004, 02:35 PM
IM - that link says 60-deg V6 engines don't need balance shafts. True?
