Roll Fenders
According2Me
12-12-2001, 02:42 PM
What exactly is meant by "rolling" your fenders??? I'm putting a 2.5" drop on my 95accord.
Dezoris
12-12-2001, 09:31 PM
http://integra.vtec.net/wheels/rollfender.html
look no further, basically if your offset on your rims is too low then you may run into your tires rubbing your fenders.
This trick is only good for if you rub with the car in a straight line.
Not on extreme turning
natcc99
12-13-2001, 12:48 AM
nice job.
you beat me too it...i was going to post that link also
i have to admit....looks kinda scary huh?!?!?
using a baseball bat like that.
but HEY...it works...and it's a lot cheaper than paying someone :)
I wonder how much this actually helps.
Just curious to know how many mm the fenders was push out.
And also....if they stay like that...and not have the natural reaction to pop back to where they were to begin with.
greg severson
12-13-2001, 02:46 AM
ANOTHER " TRICK OF THE TRADE" TO ROLLING FENDERS IS TO HEAT UP THE PAINT WITH A HEAT GUN AROUND THE WHEEL WELL , UNTILL HOT TO THE TOUCH. THIS HELPS PREVENT THE PAINT FROM CRACKING ALONG THE BEND. I GUESS A BAT COULD WORK, BUT WHY WHEN I CAN USE A REAL FENDER ROLLER AT WORK. TO BAD ITS A COMMON PROBLEM WITH MOST HONDAS. GOOD LUCK IN YOUR ADVENTURES.........
Dezoris
12-13-2001, 02:05 PM
By the way if you know that your fenders have been repainted, especially repainted over a previous paint job, (shitty body shops) without prepping, primer several coats, blabla, clear coat/flex additive then your paint will spider web. Factory paint is best, and the heat gun method is, not a bad idea. Or you can go to a body shop and put the risk of fuck ups in there hands
Drocca91
12-13-2001, 03:42 PM
my freind did it to his slammed 91 hatch! with a bat too came our great and he dont rub anymore
T!mmy
09-09-2003, 04:03 PM
Yes I know this thread is VERY old but that link no longer works and so I was wondering if anyone had another link on rolling fenders?
90gs
09-10-2003, 11:01 AM
http://www.andrews.edu/~johnsonm/howto/rollfender.html
someone took the pics off the teg page and put it there
T!mmy
09-10-2003, 11:02 AM
Thanks dude
