skills
Pages : [1] 2
onemotion
06-03-2003, 02:53 PM
SO HOW MUCH HP to the crank and to the wheels do you guys think this motor is putting out ---------------lets test your skills :eshooter: 1994 gsr motor the ECU has a Skunk 2 Upgraded Chip. the motor has STP Block Saver. Oversized JDM 11-1 compression pistons & Rings. Reconditioned rods; EAGLE Forged 4340 Steel Micropolished & Balanced Racing Crank; UNORTHzoDOX Lightweight Crank Pully; GSR Standard Cam Gears HEADWORK INCLUDES 3 Angle Valve job, Ported & Polished,Bronze Valve Guides; Skunk 2 Valve Springs & Retainers. AEM Cam Gears and Underdrive Pulleys; Cold Air Intake; Skunk 2 Intake Manifold; Full 1 Piece DC Sport 4-2-1 Header; MSD Plug Wires; NGK Plugs; stock Valve Cover; TRANNY INCLUDES ACT Stage 2 Clutch with an 8.0 lb FADANZA FLYWHEEL. AXLES Are standard GSR Mounts. ECU is a standard GSR and it redlines at 9200rpm
frozen_Joth
06-03-2003, 03:15 PM
I would say it would have something like 1462 HP and with a turbo I would say about 1400 HP. I guess it all depends on high your spoiler is and how many stickers you have. I heard you can hook up like 4 mufflers to your exhaust sytem and get 250 more HP!
91civicDXdude
06-03-2003, 03:18 PM
200
H4Bangin
06-03-2003, 03:20 PM
..and a hood wing too those bad boys add like 50hp those combined with the LED squirters, man u better look out :D id say about 1464 hp....at the rear wheels ;)
MyFirst4G
06-03-2003, 03:25 PM
Originally posted by onemotion
SO HOW MUCH HP to the crank and to the wheels do you guys think this motor is putting out ---------------lets test your skills :eshooter: 1994 gsr motor the ECU has a Skunk 2 Upgraded Chip. the motor has STP Block Saver. Oversized JDM 11-gs1 compression pistons & Rings. Reconditioned rods; EAGLE Forged 4340 Steel Micropolished & Balanced Racing Crank; UNORTHzoDOX Lightweight Crank Pully; GSR Standard Cam Gears HEADWORK INCLUDES 3 Angle Valve job, Ported & Polished,Bronze Valve Guides; Skunk 2 Valve Springs & Retainers. AEM Cam Gears and Underdrive Pulleys; Cold Air Intake; Skunk 2 Intake Manifold; Full 1 Piece DC Sport 4-2-1 Header; MSD Plug Wires; NGK Plugs; stock Valve Cover; TRANNY INCLUDES ACT Stage 2 Clutch with an 8.0 lb FADANZA FLYWHEEL. AXLES Are standard GSR Mounts. ECU is a standard GSR and it redlines at 9200rpm
How can you have GSR camgears and AEM camgears???
crxlvr
06-03-2003, 03:46 PM
well up goes the BS flag? ALI found a flaw.
but if its a true motor, id say around 235crank, and around 200wheels
MyFirst4G
06-03-2003, 03:49 PM
If Irvin's motor diddt get that much, i wouldnt give this motor that much!
Irvin's LSVTEC built to the balls even had a 5angle valve job, diddt even think they went higher than 4, made like 198 @ the wheels all motor, true honda power, i deff wouldnt give this motor anything higher than that!
mellowboy
06-03-2003, 03:50 PM
190-210 at the wheels. Theres no cams? If not , i dont think hes gonna see 200 at the wheels.
crxlvr
06-03-2003, 03:51 PM
i got tired reading the mods, so i just guessed, lol.
MyFirst4G
lol
mellowboy
06-03-2003, 03:52 PM
It depends on tuning. I've seen a b18c5 pulled out 203 at the wheels with head work done and chipped ecu.
MyFirst4G
Really? wow........ maybe Irvin should have gotten his car tuned elsewhere! Where is he anyways?
mellowboy
06-03-2003, 04:00 PM
Or maybe not? This guy has a complete JUN head with there stage 3 cams, JG throttle body , skunk2 manifold, v-tec controller, JDM itr header along with mugen cat-back with high flow cat with chipped ecu.
mellowboy
06-03-2003, 04:01 PM
What im tryin to say is that it depends on tuning and ur set up.
MyFirst4G
06-03-2003, 04:02 PM
JUN HEad!!! Wow, wonder how much that costs..........
MyFirst4G
06-03-2003, 04:03 PM
Gotcha Amigo!
onemotion
06-04-2003, 06:16 AM
Thanks i guess:bloated: but this motor said to have 260 to the crank and 220 to the wheels
sastanley
06-04-2003, 08:33 AM
SO HOW MUCH HP to the crank and to the wheels do you guys think this motor is putting out ---------------lets test your skills....the ECU has a Skunk 2 Upgraded Chip.....(all the other BS removed)....ECU is a standard GSR and it redlines at 9200rpm
You can't even decide which ECU is in it. :bloated:
So - you got this motor in a 1G Civic pullin' 10's too I guess? How much NOS you sprayin'? Got the 36 PSI turbo from a Peterbilt diesel on it too? :flipa:
1400hp might be too low - :rolleyes:
MyFirst4G
06-04-2003, 09:07 AM
lol, so thats the second BS flag that has been thrown up!!! HAHA!!!
crxlvr
06-04-2003, 09:08 AM
he asked the same question over in the tech forum.
MyFirst4G
06-04-2003, 09:09 AM
lol, post the link, i wanna see what they say!
onemotion
06-04-2003, 02:47 PM
OK fuckers its a simple question but i guess you all are still in high school
and have no life but to put people down and your wrong its putting out 2000hp to the right front tire and when i charge the uranium and hit 60 mils a hour i go back to the future dumb ass
onemotion
06-04-2003, 03:14 PM
lol, so thats the second BS flag that has been thrown up!!! HAHA!!! OK fuckers its a simple question but i guess you all are still in high school
:mad:
MyFirst4G
06-04-2003, 03:20 PM
:mad:
is that suposed to be funny? or make me laugh? :bloated: :rolleyes: :o
crxlvr
06-04-2003, 09:03 PM
you cleary are an idiot, you have twice put up up this nonsense about your engine when you dont even know what you have?
2 ecus and two sets of cam gears?
do you have a dual engine setup like that tiburon?
slave
06-04-2003, 10:02 PM
I cant believe you dare title your post "skills" when its obviously a sturggle for you to even breathe with an IQ so low. Now, before you post again we all wanna hear a nice big *POP*, that will be the sound of you pulling your head out of your ass!!!
onemotion
06-04-2003, 11:42 PM
wow you can't read worth a dawm if you look at it dumb ass its a stock gsr ecu then i said i have a skunk2 chip in the ecu and the cam part dumb ass think about it . And how long have you been doing this shit :rolleyes: what a dumb ass if you two put your heads together you still would have half a brain:bloated: dumb ass:finger:
onemotion
06-04-2003, 11:46 PM
Originally posted by slave
I cant believe you dare title your post "skills" when its obviously a sturggle for you to even breathe with an IQ so low. Now, before you post again we all wanna hear a nice big *POP*, that will be the sound of you pulling your head out of your ass!!! well dumb ass if i knew what the fuck sturggle : :eek: was maybe i would read your shit dumb ass what a jack ass
slave
If us two put our heads together?
How about if you put your own TWO heads together you inbred.
onemotion
06-04-2003, 11:48 PM
How about if you put your own TWO heads together you inbred. you will never be half the man your mom was DUMB ASS:smoker2:
slave
06-04-2003, 11:53 PM
well dumb ass if i new what the fuck sturggle : :eek: was mabe i would read your shit dumb ass what a jack ass
Can I ask WHY if you're so intelligent you need to pick on a simple typographical error. Ooops, too many syllables for you? Want me to t.y.p.e s.l.o.w.e.r.???? Oh, but thats me being facinerous. Now, if you want to ridicule me for my gramatical error, why would you do it whilst spelling "KNEW" as "NEW", or not making "I" a capital, or is it correct to spell "MAYBE" as "MABE"??? Sorry, I shouldn't pick on you, Im sure an IQ of 34 is something you're extremely proud of. Now go slap your mother for being impregnated by her brother when you were conceived.
Redline_civic91
06-05-2003, 12:01 AM
ROTFLMAO!!!!!! this shit is mad funny. my first true laugh of the days comes at 9:58 west coast time. lol. that guy with the mods does sound confusing though.
slave
06-05-2003, 12:03 AM
Im hearing you redline. The only MODS this guy truly has were done to his chromosones as a direct result of bad breeding. I've seen drag queens who are more of a man than he'll ever be, and more of a woman than he'll ever get.
onemotion
06-05-2003, 12:04 AM
your right and thats funny but your mom should have swallowed and by the way its farinaceous not facinerous DUMB ASS
onemotion
06-05-2003, 12:06 AM
NEXTnext
onemotion
06-05-2003, 12:07 AM
whats confusing bro ?:smoker2:
slave
06-05-2003, 12:09 AM
Seeing as you've totally got NO idea of any english, Im out. *pats the inbred begger on the head* Sraiolleg. :) I will no longer engage in a battle of wits with an unarmed man.
onemotion
06-05-2003, 12:12 AM
OK DUMB ASS I FIXED YOUR SHIT NOW I UNDERSTAND Can I ask WHY if you're so intelligent you need to pick on a simple typographical error. Oops, too many syllables for you? Want me to t.y.p.e s.l.o.w.e.r.???? Oh, but thats me being fanciers. Now, if you want to ridicule me for my grammatical error, why would you do it whilst spelling "KNEW" as "NEW", or not making "I" a capital, or is it correct to spell "MAYBE" as "MABE"??? Sorry, I shouldn't't pick on you, I'm sure an IQ of 34 is something you're extremely proud of. Now go slap your mother for being impregnated by her brother when you were conceived.
:rolleyes:
Redline_civic91
06-05-2003, 12:14 AM
never mind. its too late to argue about this.:flipa: but you cant have an upgraded chipped ecu then turn around and say its stock gsr reving at 9200, theres no such thing as a stock gsr comp. reving at 9200. there is also other things too that im not gonna throw in but i guess you'd probley hit 8's with that set up with stock slicks lol
slave
06-05-2003, 12:16 AM
Ok, one more post, I lied. You might wanna check out the word you TOLD me I MEANT to input. Fucking inbred. Now you might also rue the fact your english vocabulary doesnt contain the word I used and so as usual you're left yanking yourself.
http://www.yourdictionary.com/ahd/f/f0038100.html
but no, you're 100% correct, IM BEING LIKE STARCH. :confused: :rolleyes: wanker.
91hondaguy
06-05-2003, 12:19 AM
you just need to shut your piehole.
you little son of a bitch. stop using the phrase " DUMB ASS" like you don't know any else " disses " that your little bitchself can't think of.
Go to your mother , your little piece of shit. .
fuck, ppl just think they so " cool " .. and post shit .. and talk shit ..
Melt
06-05-2003, 12:20 AM
hahahahahah .... laughing at this entire thread.
I bet this engine puts out a measly 10 hp ... cause with an owner so fucking stupid, there is no way anything could possibly be hooked up right, plus you probably dont even know which ones the gas and which ones the brake (heaven forbid you drive a stick ... probably cant even get it out of the driveway)
:finger: :devil: :finger: :devil: :finger:
IBL
MyFirst4G
06-05-2003, 12:23 AM
lol, he said Wanker, thats such a funny insult!!! lol, it just sounds funny, WANKER WANKER WANKER WANKER WANKER WANKER WANKER WANKER WANKER WANKER WANKER WANKER WANKER WANKER WANKER WANKER WANKER WANKER WANKER WANKER WANKER
Yea, so anyways, onemotion is gay, wait, no, he's a WANKER WANKER WANKER WANKER WANKER WANKER WANKER WANKER WANKER WANKER WANKER WANKER WANKER WANKER WANKER WANKER WANKER WANKER WANKER WANKER WANKER WANKER WANKER!!!!!!!!!!
Well, now i gotta go get another beer :D And maybe :bandit::smoker2: :smoka: :smoker: some more :D
onemotion
I THINK YOU MENT INBREED DUMB ASS :rolleyes:
MyFirst4G
06-05-2003, 12:25 AM
You know what i thik we need here? that "Arguing over the internet is like competing in the special olympics, even if you win, your still retarded" picture!!! Anybody got it?
Worshp
06-05-2003, 12:28 AM
stock Valve Cover
I say if he changed to a type R cover he'd gain and additional 1 googolplex hp.;)
onemotion
06-05-2003, 12:30 AM
Originally posted by Worshp
I say if he changed to a type R cover he'd gain and additional 1 googolplex hp.;) NICE CRX
onemotion
06-05-2003, 12:31 AM
You know what i thik we need here? that "Arguing over the internet is like competing in the special olympics, even if you win, your still retarded" picture!!! Anybody got it? HAHAHAHAHAHAHAHAHAHAH LOL good one
slave
uhm no, WANKER, inbreed act your parents partook in. INBRED is you, the result. Yes, arguing over the internet is pointless. But Im sitting here sniffing brake and clutch cleaner fumes. lol!
MyFirst4G
so, is this crazy motor in your DEL SLO? (Oh, and there is no typo there buddy)
Worshp
06-05-2003, 12:32 AM
NICE CRX
Don't even TRY to kiss up to me....unless your name is flossy and your idea of a night out is shaking your dags down at the local sheep dip. :silly2:
onemotion
so what kind of mods you have in that crx:smoker2:
MyFirst4G
HAHAHA, he said Wanker again!!! Slave is the man!!! and looks like onemotion is getting owned!!! lol!
91hondaguy
ahahahaha .. so :flipa: wuteva your stupid name is .. oneemotion crap..
slave
06-05-2003, 12:33 AM
Mate, you own yourself better than I ever could!! ha ha, thats some funny stuff
MyFirst4G
06-05-2003, 12:34 AM
Yea i agree with you, and i'm glad he's on the boards more often now!!! He's fukin hilarious!
onemotion
06-05-2003, 12:37 AM
Originally posted by 91hondaguy
ahahahaha .. so :flipa: wuteva your stupid name is .. oneemotion crap.. wonmotion
Worshp
And don't YOU even try it on either. We all know the Aussies are descended from sheep, so i bet it was your mother I slept with last night! :licker:
onemotion
06-05-2003, 12:38 AM
never:smoka:
91hondaguy
:flipa: :flipa: :flipa: :flipa: :flipa: :flipa: :flipa: :flipa: :flipa: :flipa: :flipa: :eek: :eek: :eek: :bloated: :bloated: :bloated:
:eshooter: onemotion :aug2: :badass: :monkeypis
