Revell 360 Ferrari big brake conversion!
TheSyndicate
05-04-2003, 10:31 PM
Ok following the progress of my revell spider, I've decided to upgrade it to a real big brake kit. I had to sacrifice my aoshima toyota saloon because it has large brembos on it, but I feel it's worth it.
http://files.automotiveforums.com/uploads/875505DSC00551.jpg
As you can see it's crap. The rotor is a satin chrome ring that I had to slot (did a bad job on it, too :D ). The caliper is a fair enough size, and is attached to the axle so the rotor spins with the wheel. But hey, models sit on a shelf. I need it to look good sitting still.
http://files.automotiveforums.com/uploads/244486DSC00552.jpg
Here you see the very nice aoshima brembos. Nice detail, imo.
http://files.automotiveforums.com/uploads/872113DSC00553.jpg
The rotor and caliper have been removed from the suspension. As you can see the center is filled, which won't work.
http://files.automotiveforums.com/uploads/736214DSC00554.jpg
http://files.automotiveforums.com/uploads/216688DSC00555.jpg
To remove it, you have to cut off the extruding back. A serrated kitchen knife will suffice.
http://files.automotiveforums.com/uploads/583390DSC00556.jpg
Now the flat rotor can be placed inside the wheel housing. Surprisingly it fits snugly where the revell plain rotor was.
http://files.automotiveforums.com/uploads/411540DSC00557.jpg
Now the wheel hold needs to be modified so it all stays together. As you can see the caliper is tied in with it. Not a problem.
http://files.automotiveforums.com/uploads/786236DSC00558.jpg
A few cuts and its apart.
http://files.automotiveforums.com/uploads/212030DSC00559.jpg
Now put it on the axle. Of course, you want to make sure everything is painted first.
http://files.automotiveforums.com/uploads/498448DSC00561.jpg
Voila! The way a ferrari should really look! :bandit:
5ynergyx
05-04-2003, 10:35 PM
:eek: Nice!
Thanks for sharing your hardwork ;)
daggerlee
05-05-2003, 05:41 AM
Excellent job! Tamiya is still better, I guess :p
TheSyndicate
05-05-2003, 07:38 PM
Update: It turns out the original revell rotor needs to be used as a backing for the brembo rotor. This will give the rotor the proper depth.
http://files.automotiveforums.com/uploads/876793DSC00562.jpg
