engine conversion
andyfrigge
05-04-2003, 09:02 PM
i currently have a 1990 Mustang Convertible Lx that i bought with 160,000 miles on it. i was hoping to change the engine over to a 5.0L V8 but wasnt sure what i really needed, or where to look, any help would be greatly apprectiated.
94svt5.0
05-05-2003, 04:00 PM
You need to find a donor car to get the engine trans and wiring harness/computer and grab the rear end out while your at it. Its a fairly common swap if you check around on the internet.
HiFlow5 0
05-06-2003, 07:08 AM
Yes, this is a very common thing to do. I'm actually contemplating it myself on my notch. The best way to do the swap is to get a donor car like 94svt5.0 suggested. There will be a lot of things that should/need to be changed. It will take time, but can be done if your mechanically inclined and are willing to learn a little bit.
Here's a list if things that need to be changed right away, just to be able to make the car drive.
-motor
-motor mounts
-fuel lines
-wiring harnesses
-computer
Now here's a list of things that should be changed for the sake of safety and longevity.
-trans
-rearend
-all suspension components
-whole brake system
-driveshaft
-wheels
Hope this helps some.
-Craig
REAL PERFORMANCE
05-08-2003, 02:15 AM
i would go with a pre 94 mustang as a doner car. The 89-93 cars would be the best. 94-95 used different headers, distributor, intake manifold, throttle cable, ecu, wiring harness, and mainly accesories, and accesorie brackets.
any questions please e-mail me
