Guys, I need your HELP!!!!
Mythos
10-30-2001, 09:28 AM
how did you guys change the clearance light on the passenger side - the one that uses bulb no. 168? i can't seem to rotate it - it is freakin tight in there! I'm thinking of just taking out the entire headlight unit - but, does anyone know if there are other screws holding it besides the top two mounting ones? Please shed some light - no pun intended.
thanks guys
thanks guys
b-b00gie
10-30-2001, 11:56 AM
I've suffered numerous scrapped knuckles/cuts due to the same problem. Just keep working it and when your fingertips get numb, stop for a few minutes and then try again.
You could also just remove the headlight as you stated, I did that once too.
I've also noticed that sometimes the connector comes out fine, and other times its a real pain to free it up...
good luck.. :devil:
good luck.. :devil:
kenchan
10-30-2001, 12:10 PM
save your hand and use a long nose plyer. daz wat I did. helps if you push it in alittle too while you turn it ccw.
Nismoboy1
10-30-2001, 12:11 PM
i have small hands :devil: :finger: :devil:
Mythos
10-30-2001, 12:39 PM
The driver side was a piece of cake but, the passenger side is inaccesible. I tried the long nose plyer, but, i couldn't get it around the plastic thing how did u do it kenchan? - the windshield washer funnel is in the freakin way- is there a way to pull that funnel out? - it looks like it snaps in place. I found the third mounting screw for the headlight unit - I can definitley see removing that screw but, I dunno how the heck some of you guys screw it back in - if it drops your fu*ked. Anyway i guess i just gotta kepp trying over time to lossen it up.
Why is it that everytime I work under the hood - 3 layers of my skin are always ripped of my fingers? :(
b-b00gie
10-30-2001, 12:50 PM
about the winsheild washer fluid funnel... you can just push it into the fender and the cap will hold it under the lip of the fender. just pop it back out when you're done.
about replacing that third screw... heh, I never did! :p
atomic-G
10-30-2001, 12:51 PM
The plastic thing!!! HAHA, yes, I do remember that. On one side, the washer is in the way and on the other, that plastic bs thing doesn't allow you to TURN it. I battled it out with that light as well, getting all bruised up. I even thought of taking off the headlight, but like ken said .. use a plier, grab a hold of that sucker and turn and it will work. Just keep trying. I stood on the side of my g when I turned it. It might take you a couple hours (cough, like me) to do it, but it will work.
Mythos
10-30-2001, 01:35 PM
No luck, I guess i just gotta keep trying every day and make it looser and looser and hopefully one day it'll unlock.
DCastillo
10-30-2001, 02:43 PM
dude, use really skinny/long needle nose plyers... its not that big of a pain in the ass to remove the entire headlight assembly either. The third screw doesnt even make that big of a difference on the passenger side.
Mythos
10-30-2001, 02:45 PM
the driver's side is no problem - but, the passenger side is what's giving me hell, i just can't seem to fit the long nose pliers through the space between the washer funnel and the black plastic connector. The connector is really tightened down - my bro has got longer fingers than me and he couldnt even loosen it.
DCastillo
10-30-2001, 05:18 PM
looks like you have n choice but to take out the entire assembly... or you can just take it to the dealer and have them do everything for you
Mythos
10-30-2001, 05:47 PM
yeah - i'll give a few more tries, then either dealer or take out the whole headlight unit. but, those bulbs are definitely coming out.
Thanks for all the info guys.
BruinG20
10-30-2001, 06:20 PM
Hey if you take it into the shop, watch them and see how they do it. I've been trying to find how to take out the headlight panel for weeks now. My dealer keeps giving me crap about "why do you want to replace the stock bulb?" Cuz it looks better dammit! :D
kenchan
10-30-2001, 06:21 PM
ok, I popped open my P11's hood again to take another look. I placed the long nose plyers almost horizontally under the protruding gray plastic thing behind the headlight to reach the clearance harness clip. then I turn it about 1/4 at a time until the thing popped out.
it took me about 15minutes to do, but it does come out, keep trying!!! :D
Mythos
10-30-2001, 10:07 PM
cool i'll give it a shot and let you know how it turns out - thanks kenchan.
kenchan
10-31-2001, 12:15 PM
mythos did you get that bulb out? koojo said he moved the washer funnel out of the way and grabbed it with his bare hands.
let us know when you got it off. :D
Mythos
10-31-2001, 12:39 PM
Not yet - I tried again earlier today, my bro tried too with no luck. Accessing the thing is not a problem - I just can't turn the damn thing. I got a friend who's a mechanic i'm gonna take it to him - gives me an excuse to stop by and say wassup.
