Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 01-07-2010, 10:29 AM
headscratching headscratching is offline
P0410 code
My SES light is on and I am pretty sure it is the air pump...used to hear it come on so when I didn't hear it the other day I checked the fuse and it was blown. I took the air pump out and there was water in it, so I drained it, changed the fuse and it worked...However the other morning it once again did not turn on, so I checked the fuse and it was fine, but exhaust was coming out of the airpump intake...is the air control valve busted? how can i fix this or atleast where should I start?
Old 01-07-2010, 04:25 PM
RC1488 RC1488 is offline
Re: P0410 code
There should be no exhaust coming out of the intake on the valve. Inside is a reed valve that I've found clogs up with carbon. You may need to open up the valve (2 screws) and clean the valve. Do not take apart the reed valve. Also clean the metal pipe going to the manifold and shoot some compressed air down the manifold also.
Present: '02 Sl1 Man '01 SC1 Man '97 Sl2 Auto '96 SL2 Auto '95 SC2 Man
Past: '99 Sl2 Auto '97 Sl2 Man '98 SL2 Man '95 Sl2 Man '95 Sl2 Man '94 Sl2 man
