Go Back   Automotive Forums .com Car Chat > Chevrolet > General Discussion
Old 10-17-2009, 10:52 PM   #1
yukon96
96 yukon p430 code?
I have got this code mostly at 20-35mph at 1200-1300 rpm. If I clear code and drive mostly highway it is fine. If I start to run lower speed roads it comes right back. So here is a list of parts replaced cap,rotor,plugs,egr and all 4 02 sencores. Befor I spend $350 on cats I wonder if timming or some thing els could be the problem.
yukon96 is offline   Reply With Quote
Old 10-17-2009, 11:47 PM   #2
Airjer_
Airjer_'s Avatar
Re: 96 yukon p430 code?
Probably would have been cheaper to start with the cats.
Airjer_ is offline   Reply With Quote
Old 10-18-2009, 11:29 AM   #3
MT-2500
AF - Advisor
MT-2500's Avatar
The main cause of cat codes or bad cats is rich running engine or engine missing.
Always make sure engine is tuned up good and not running rich.
Bad cats or cat codes need proper testing to find the problem.
http://www.troublecodes.net/articles/catfailure/
DTC P0420, P0421, and P0430 & P0431: Check Possible Cause Of Misfire DTC P0420 and P0421 indicate bank one catalyst system efficiency is minimum requirement. DTC P0430 and P0430 indicate bank 2-catalyst system efficiency is minimum requirement. Possible causes are as follows: Use of leaded fuel. Oil contamination. Cylinder misfire. Fuel pressure too high. HO2S sensor improperly connected. Damaged exhaust system component. Faulty ECT sensor. Faulty HO2S. Ensure ignition timing is correct. Retrieve all Continuous Memory DTCs. If misfire code is not present, go to next step. If misfire code is present, isolate cylinder and repair as necessary. Check HO2S Monitor DTCs If DTCs P0136, P0138, P0140, P0141, P0156, P0158, P0160, or P0161 were present in step 1), service as necessary before continuing. If none of these codes are present in step 1), go to next step. Check ECT Sensor DTCs If DTCs P0117, P0118, P0125 or P1117 were present in step 1), service as necessary before continuing. If none of these codes are present in step 1), go to next step. If any codes except P0420, P0421, P0430 and/or P0430 were present in step 1), service as necessary before continuing. If no codes except P0420 and/or P0430 were present in step 1), go to next step. Check Rear HO2S Wiring Harness Turn ignition off. Ensure HO2S wiring harness is correctly routed and connectors are tight. Repair or replace as necessary. If wiring harness and connectors are okay, go to next step. Check Fuel Pressure Turn ignition off. Release fuel pressure. Install fuel pressure gauge. Start engine and allow to idle. Note fuel pressure gauge reading. Increase engine speed to 2500 RPM and maintain for one minute. For fuel pressure specifications, see FUEL PRESSURE SPECIFICATIONS article. If fuel pressure is as specified, go to next step. If fuel pressure is not as specified, go to CIRCUIT TEST HC. Check For Exhaust System Leaks If exhaust system leaks, it may cause catalyst monitor efficiency test to fail. Inspect exhaust system for cracks, loose connections or punctures. Repair or replace as necessary. If exhaust system is okay, go to next step. Check For Exhaust System Restrictions Inspect exhaust system for collapsed areas, dents or excessive bending. Repair or replace as necessary. If exhaust system is okay, go to next step. Check Manifold Vacuum Install tachometer. Connect vacuum gauge to intake manifold vacuum source. Start engine and raise engine speed to 2000 RPM. Manifold vacuum should rise to more than 16 in. Hg. If manifold vacuum is okay, go to next step. If manifold vacuum is low, go to step 11). Leave tachometer and vacuum gauge connected. Start engine and raise engine speed to 2000 RPM. On a non- restricted system, manifold vacuum should quickly rise to normal range as increased RPM is maintained. On a restricted system, manifold vacuum will slowly rise to normal range as increased RPM is maintained. If manifold vacuum is okay, no indication of exhaust leak or restriction has been detected and testing is complete. If manifold vacuum is low or slow to respond, go to next step. Leave tachometer and vacuum gauge connected. Remove exhaust pipe from exhaust manifold. Start engine and raise engine speed to 2000 RPM. If manifold vacuum is now okay, fault is downstream from exhaust manifold. Reconnect exhaust pipe to exhaust manifold and go to next step. If manifold vacuum is still low or slow to respond, fault is in exhaust manifold or intake manifold gasket. Repair or replace as necessary and repeat QUICK TEST. Leave tachometer and vacuum gauge connected. Disconnect muffler/tailpipe assembly from rear of catalytic converter. Start engine and raise engine speed to 2000 RPM. If manifold vacuum is now okay, fault is in muffler/tailpipe assembly. Repair or replace as necessary and test-drive vehicle to verify elimination of symptom. If manifold vacuum is still not okay, fault is in catalytic converter. Repair or replace as necessary. Check tailpipe/muffler assembly for debris from catalytic converter. Test drive vehicle to verify elimination of symptom.
MT
MT-2500 is offline   Reply With Quote
Old 10-18-2009, 12:12 PM   #4
yukon96
Question Re: 96 yukon p430 code?
<P>Thank's for the info MT-2500 will check these system's first</P>
Old 10-18-2009, 12:51 PM   #5
MT-2500
AF - Advisor
MT-2500's Avatar
You are welcome.
And remember if it is bad cats do not go the cheap ones.
Also if there is a aftermarket alarm system on it GM has a TSB on them causing cat codes.
Good luck
MT
Old 10-18-2009, 03:12 PM   #6
yukon96
I think I will probably go with the magnaflow cat's just like I put on my suburban. Thanks again MT-2500
