Go Back   Automotive Forums Car Chat > Ford > Expedition
Old 06-30-2009, 04:30 PM
Franco2112 Franco2112 is offline
Smile 2001 Expediton Rear A/C Solution
Just wanted to shed some light on Expedition rear A/C not cooling when the front A/C works and cools fine. Here's how the repair went.
1. First remove rear seat.
2. Remove all plastic cover parts on A/C side. Parts are durable and you won't break them. Place all parts together so you won't loose them.
3. Check all rear A/C parts for functional condition. Make sure all moving parts are working properly. Move hot/cold controls and panel/ floor controls to make sure both acuators are moving smoothly and not making clicking noise. Here's a link for parts. http://www.trademotion.com/partlocat...layCatalogid=0
4. Pressure test system for flow. This is where my issue was. A bad Expansion valve.
5. Evacuate system.
6. Replaced Expansion Valve
7. Refilled system.
8. Test system for leaks and cooling. Temperature should be in low to mid
50's. 50-55 degrees. Also could be lower.
9. Replace all plastic covers.
Total cost $452 at Midas. Dealer wanted $750. Cost savings $298
Some cost savings came in because i removed rear seat and all plastic. It took about ten minutes to remove and fifteen minutes to replace. I did a little clean-up along the way.
Old 07-03-2009, 12:23 AM
Davescort97 Davescort97 is offline
Escort guy
Re: 2001 Expediton Rear A/C Solution
Thank you for your information. On the forum everybody posts about problems they are having and very rarely does anyone post about a solution they have found. All of this information goes into a database that can be researched. I think most of it goes into Google as well. If you are working on your vehicle and have found a solution to your problem or even if you have found an easier way of doing something, post it. You'll help a lot of people. I commend you Franco2112.
Old 07-03-2009, 09:15 AM
Thanks. Have a safe and Happy 4th!
