Go Back   Automotive Forums Car Chat > Geo > Nova | Prizm | Spectrum | Sprint
Old 05-31-2009, 11:03 PM
Scott46550 Scott46550 is offline
1994 Prizm acceleration problem?
Hi, I was driving my 1994 Prizm when I came to a stop it died. It started back up and as I tried to accelerate it hesitated and died again. Started it again and with the car in park tried to rev the motor up and it would not rev and proceeded to die again. The car was running fine before all this and now I notice that any kind of pressing on the gas makes it die. It runs good when it's up to 55, but you can still feel a bit of hesitation. I was wondering if it could be that the fuel filter is clogged? It looks rather old and rusty.
Old 06-01-2009, 07:12 AM
Re: 1994 Prizm acceleration problem?
Can anyone please help?
Old 06-01-2009, 09:44 AM
ricebike ricebike is offline
doesn't hurt to change it out; some one else on another vehicle had this same problem as yours...
also check if you have any trouble codes stored, clear it, see if same codes return...
Old 06-04-2009, 01:30 AM
Hello, I changed the fuel filter and still had the problem. Decided to take it to the repair shop. It turned out to be the throttle position sensor. So if any of you have the similar problem, check to see if this it. The sensor cost me $100, but it was worth it.
Old 06-04-2009, 08:44 AM
thanks for the update
that's not a bad price; glad the mechanic didn't rip you off on the tps
did you access the trouble code yourself?
21 Throttle position sensor or circuit (open)
22 Throttle position sensor or circuit (shorted)
Old 06-27-2009, 09:38 PM
Just an update, the stalling continued even after I replaced the sensor. Took it to the dealership and they had no idea of what it could be. Turned out to be the ignition coil inside the distributor cap. It would get warm, overheat the coil and stall. Changed the coil and now no stalling at all. Now I can keep the car.
