Go Back   Automotive Forums .com Car Chat > Chevrolet > Express | G Van
Old 03-29-2009, 10:22 AM   #1
appco
Unhappy Regency 01 chevy express NO REAR AIR.BUT HEAT WORKS
I just had a new rear heater core put in at the local chevy dealer cause it was leaking.Well now my rear air does not work.Before the new heater core my air and heat worked fine.Any ideas as what chevy did to screw up my rear air?I also have just one master front control for both and a rear fan switch.
Thanks a lot
appco is offline   Reply With Quote
Old 03-29-2009, 10:39 AM   #2
MT-2500
AF - Advisor
MT-2500's Avatar
Re: Regency 01 chevy express NO REAR AIR.BUT HEAT WORKS
Thanks a lot
Take it back and ask them to lick there calf over again on there dime.
Does blower on rear work?
Is ac charged up good?
If you want to fix it DIY.
A good online all dat sub or factory repair manual will led you threw it.
http://www.alldata.com/products/diy/index.html
MT
MT-2500 is offline   Reply With Quote
Old 03-29-2009, 11:23 PM   #3
appco
Unhappy Re: Regency 01 chevy express NO REAR AIR.BUT HEAT WORKS
Yes air in front blows ice cold and yes the fan in the back works great.I wonder if the hoses to the rear heater core are backwards.the rear ac hoses going into the box in the rear are ice cold.Is there supposed to be coolent running to the back when the heat is not on.The chevy dealer screwed up somewhere when he replaced the heater core.with summer comming I can't go anywhere without the rear air.it is like a sauna for the kid's.
Old 03-30-2009, 09:57 AM   #4
MT-2500
AF - Advisor
MT-2500's Avatar
The all data sub tells you all about it and how it works and what to fix if not working.
MT
Old 09-04-2010, 01:06 AM   #5
geofrog
Send a message via MSN to geofrog Send a message via Yahoo to geofrog
My father had the same thing happen to his 00 express. Turned out to be the aluminum line that runs the air conditioning, runs under the fan, and is strapped to the frame using a stainless steel bracket. The bracket being stainless corroded the aluminum and you have leaked the coolant out of the rear AC system.
The dealer wanted 700+ to fix it seeing how the body needed to be pulled off the frame to fix. My father found a mechanic in town that got in there with a short piece of pipe and spliced it in. Recharged the system and he was good to go.
That is where i would suggest starting.
Kris
geofrog is offline   Reply With Quote
Old 12-01-2010, 12:34 AM   #6
alicesmile
Smokes! That was a gnarly set of pictures. You see that his shirt or jacket is wrapped around the work piece, it dragged him in. He probably had his arm over the work dabbing on some coolant or was removing chips.
That looks like a healthy engine lathe, when they're hunkered down in "back gear", nothing except a power failure would stop it. Belt driven lathes would slip, but the end results would have probably been the same.
He must have been at the shop alone with no one to call over quick. A few shops I worked in had a standing rule that nobody was allowed to work alone. Not that I've always obeyed it.
alicesmile is offline   Reply With Quote
Old 12-01-2010, 07:48 AM   #7
MT-2500
AF - Advisor
MT-2500's Avatar
alicesmile
Welcome to AF on your first post.
Check and see if you posted to the right post.
MT
