air bag light on 95 tc
Hey guys, I have a 95 signiture seriesand lately i noticed when i start my car the air bag light flashes at first a couple times and then stays on. Anyone know what could be causeing this. Is there a sensor that be be shorting out?? thanks for the help
Re: air bag light on 95 tc
The flashes are giving you a code number IE flash,flash,flash <pause> flash,flash = Error Code 32
AIR BAG DIAGNOSTIC MONITOR FAULT CODE PRIORITY TABLE Priority Code Component/Fault Description Highest -- No Air Bag Lamp - Inoperative Lamp Circuit or No Ignition Voltage to Diagnostic Monitor | -- Continuous Air Bag Lamp - Diagnostic Monitor Disconnected or Inoperative | 12 Low Battery Voltage | 13 Air Bag Circuit or Crash Sensor Circuit - Shorted to Ground | 21 Safing Sensor - Not Mounted on Vehicle Properly | 22 Safing Sensor Output Circuit - Shorted to Battery Voltage | 23 Safing Sensor Input Feed/Return Circuit Open | 24 Open in Circuit 944B or Low Resistance in Crash Sensor(s) | 32 Driver Side Air Bag/Safing Sensor Circuit - High Resistance or Open | 33 Pin 7 Not Grounded at Diagnostic Monitor | 34 Driver Side Air Bag/Safing Sensor Circuit - Low Resistance or Shorted | 35 Low Resistance Across Pins 8 and 9 at Diagnostic Monitor | 41 Crash Sensor Circuit - High Resistance or Open | 44 RH Crash Sensor - Not Mounted to Vehicle Properly | 45 Center Radiator Crash Sensor - Not Mounted to Vehicle Properly | 46 LH Crash Sensor - Not Mounted to Vehicle Properly | 51 Diagnostic Monitor Internal Thermal Fuse - Blown and Short to Ground No Longer Exists | 52 Backup Power Supply - Voltage Boost Fault | 53 Internal Diagnostic Monitor Fault Lowest -- Rapid Continuous Flashing of Air Bag Lamp - All Crash Sensors Disconnected
-Steven 1996 Town Car, Cartier |
