bolt broke now i have to replace entire steering rack all motor mounts, all because of that 1 bolt. i dont understand. what could have caused it. is my frame broke to. is it worth fixing
Re: subframe bolt broke...?
What specific subframe bolt are you referring to? Might help to post a pic.
Sounds fishy! Is it a dealer that broke the bolt? Make them pay for it.
What vehicle is this?
-2000 Grand Prix GTP 170,000mi (daily driver) -2000 Olds Alero 100,000mi (soon to be DD with gas at $3.45/gal) -1997 Chev K1500 4x4 115,000mi (Natalie's truck [nans_grandprix]) AF "2.0" Community Guidelines Conservative Victory 2012!!! "I'll Keep my Guns, Freedom, and Money. You can Keep the Change!" ----->>>>> Did You Know? <<<<<----- |
i have a 2000 pontiac grand prix gtp supercharged, and it was the blot on the drivers side, the one right below the cradle???? thats all i know. Today i was told its not the rack and pinion, or the gear box or the knuckle for the steering that it is actually my steering column. none of this makes any sense. i wish i knew how this bolt could of broke. i just had my mounts and cv boot changed, would that bolt have to be removed to get to any of that...?
i wish i had a pic... anybody have a site i could go to
Really hard to tell without knowing the specific bolt being referred to. There are many bolts. Even ones that hold the rack and pinion to the subrame and other components such as the engine mounts, etc. As far as the actual subframe member which is technically the engine/transaxle cradle there are 4 primary volts. Two at the front end and two under the area where the driver and passenger sits. These 4 bolts hold the subframe up to the body of the car. But it doesn't sound like those are the bolts.
hes gotta be talking about the ones that support the subframe.. They dont usually just break without lots of rust/
Is this the bolt? This is the one at the rear subframe driver's side. I've never had any issues with those bolts and they have been off at least a couple of times for tranny work. Maybe it was broken due to the previous repair work. Or worse case maybe crossed threaded which would raise another issue of the part at the unibody where the bolt threads in to. I guess rust or corrosion could be a factor but that is normally not an issue in the desert Southwest. The OP is in Tucson, AZ.
Not to mention the nut welded to the unibody will rust apart long before the bolt rusts far enough to be broken off.
