Go Back   Automotive Forums .com Car Chat > Chevrolet > General Discussion
Old 08-08-2008, 12:41 PM   #1
luxeryvic
86 305 rear oil seal change
how do i change the rear oil seal on my 1986, 305?
i have the engine out so do i take off that hold down pice that goes around the top part of the crank and loosen the oil pan the pull it out, this is wat it looks like i have to do, just want to make sure
luxeryvic is offline   Reply With Quote
Old 08-08-2008, 01:35 PM   #2
inafogg
Re: 86 305 rear oil seal change
are you putting in a full seal or is it a 2 piece rope seal??
inafogg is offline   Reply With Quote
Old 08-08-2008, 03:38 PM   #3
maxwedge
A990 racer
Good info at autozone.com, repair guides.
maxwedge is offline   Reply With Quote
Old 08-09-2008, 10:25 PM   #4
silicon212
Confoundingly Lucid
silicon212's Avatar
Send a message via ICQ to silicon212
An 86 should have a one piece seal. You do not have to remove the seal housing to do so. Remove the transmission, then the flexplate. You will see two notches near the seal where you can wedge a screwdriver down into it - then pull outward on the seal and it should come right out. Use the proper size seal driver to install the new one.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
silicon212 is offline   Reply With Quote
Old 08-10-2008, 09:25 AM   #5
luxeryvic
yeah, it is a i piece rubber seal, but it also looks like it is leaking at the seal housing gasket in between it and the block, to get it off do i just loosen the oil pan and unbolt it? thanx for the help so far
Old 08-10-2008, 09:37 AM   #6
luxeryvic
ok i get it , thanks maxwedge for the autozone reference it helped alot, but do u need a seal driver, is there another way u can do it?
Old 08-10-2008, 11:11 AM   #7
maxwedge
A990 racer
Try and use something to drive the seal in evenly such as a large diameter socket.
Old 08-10-2008, 02:02 PM   #8
silicon212
Confoundingly Lucid
silicon212's Avatar
The large socket idea that Maxwedge stated works just as well as many seal drivers. However, you may not find a socket large enough.
You can do it CAREFULLY with a hammer, lightly tapping it in a criss-cross pattern might work, but keep in mind there is risk that you will kill the seal and have to start over. Do not allow the seal case to distort, even slightly. If you see the smallest dent in it, it's junk and will leak like Rosie O'Donnels... nevermind.
The seal driver or socket is the best, least risky way to go. You can rent a seal driver from Autozone. I think the deposit charge on a seal driver there is like $20 or so - or it was the last time I needed one.
By seal case, I mean the steel part of the seal, not the aluminum adapter on the engine.
Old 08-11-2008, 08:41 AM   #9
luxeryvic
it doesnt look like there is any steel part, it just looks like its all rubber?
Old 08-11-2008, 12:57 PM   #10
silicon212
Confoundingly Lucid
silicon212's Avatar
It's probably rubber coated, but rubber itself does not have the strength to work alone as a seal. There is a steel frame under the rubber.
