Go Back   Automotive Forums Car Chat > Cadillac > Catera
Old 07-19-2008, 10:26 PM
Towman148 Towman148 is offline
00 Cat
Recently I became the proud (if one can use the word in the current reference) owner of a 00 catera....only good part of this deal is that I got it for free...after a bit of research and amature wrenching that it has most of the problems that a cat usually has....replaced the gaskets for the cam covers and that seems to have fixed the oil leaking into the coil problem but it is still running rough/stuttering when it first fires up....took it to a friend of mine all the voltages are reading correct and it is not throwing any codes...he mostly works on caddys and he thinks it may be the mass air flow sensor....anyone else out there run into this problem and if so did the fix help....
