Go Back   Automotive Forums .com Car Chat > Chevrolet > S-10
Old 07-08-2008, 11:31 PM   #1
Persistent One
700r4 tranny?
could someone tell me if my 700r4 tranny would bolt up to a chevy 350 v8? my vehicle is a 1985 s10 blazer 4x4 with 2.8l. if not what would i need to do so?
thanks
Persistent One is offline   Reply With Quote
Old 07-09-2008, 05:30 AM   #2
S-10Rookie
Cool Re: 700r4 tranny?
Ya bud, it WILL BOLT UP. All GM engines and trannies bolt together. As long as they are the same brand. Chevy to chevy, Buick to buick, Olds to olds..... You get the picture
---Skweek (aka S-10Rookie)
S-10Rookie is offline   Reply With Quote
Old 07-09-2008, 10:37 AM   #3
MT-2500
AF - Advisor
MT-2500's Avatar
Re: 700r4 tranny?
No.
The 2.8 buick/olds may be a different bolt pattern.
And a 2.8 transmissiobn will not hold a 350 engine.
If you are going a 350 engine get the transmission for it.
Good Luck
MT
MT
MT-2500 is offline   Reply With Quote
Old 07-30-2008, 01:42 AM   #4
drifttruck99
Re: 700r4 tranny?
all chevy small blocks from 265 inches to 400 inch small block will bolt up. as long as theyre chevy or gmc
im assuming your 700r4 is either on at least a 4.3
drifttruck99 is offline   Reply With Quote
Old 08-06-2008, 12:47 PM   #5
woody6725
Re: 700r4 tranny?
no, the 2.8 is a 60 degree block, while the 4.3 and v-8s are a 90 degree block. you can swap trannies between the 4.3 and v-8s, but not with the 2.8.
2004 Trailblazer LT I6 pcm tune, flowmaster, k&n
1996 GMC Yukon SLT 4x4 4 door, flowmaster, k&n-SOLD
1995 GMC Sonoma ext cab 4x2 4.3 auto, flowmaster, k&n
1993 Chevy S10 ext cab 4x2 4.3 auto, flowmaster, k&n
woody6725 is offline   Reply With Quote
Old 09-01-2008, 05:43 PM   #6
iBgodsmacked
Re: 700r4 tranny?
I have built 700 transmission for 5 years, they will bolt up with out a problem. they are the same bell housing. the only thing you need to keep an eye on is an S-10 2wd and 4wd, they will have differant output shafts and gearing. The 700 will hold up to a 350, but you may want to consider an upgrade to springs and maybe a shift kit to boost the springs for harder shits and line psi.
iBgodsmacked is offline   Reply With Quote
Old 09-01-2008, 06:32 PM   #7
MT-2500
AF - Advisor
MT-2500's Avatar
Re: 700r4 tranny?
As said 2.8 is a different bolt pattern.
The V6 trans clutch packs and converter are to light/short on clutches for any V8 engine.
MT
Old 01-03-2009, 03:51 PM   #8
srtolly
Re: 700r4 tranny?
I have a 700R4 in my 4.3L, I had it rebuilt by a friend that rebuilds Trannys for a living. The V6 transmission has a lighter clutch pack and bands. I plow snow with mine and he was able to upgrade my 700R4 with parts from the v8 700R4. He told me that the V6 trans would never take the abuse of the V8 engine when I asked him the same question.
srtolly is offline   Reply With Quote
Old 01-05-2009, 11:10 PM   #9
dracer398
dracer398's Avatar
Send a message via AIM to dracer398 Send a message via Yahoo to dracer398
Re: 700r4 tranny?
MT is right. The 2.8 WILL NOT BOLT UP! I used a 700R4 from a full sized 4wd pickup with a 350.
dracer398 is offline   Reply With Quote
