Old 06-28-2008, 06:20 PM
educated_rage educated_rage is offline
Send a message via Yahoo to educated_rage
1992 grand prix se seats issue
I have a 1992 grand prix with the 60/40 split bench seats in the front. is it possible to switch over to bucket seats ?, if so what does it entail and where would be a good place to look for salvage seats or aftermarket seats, the bench ones in my car are shot and sinkin in FAST ??? Thanks for your help !
Old 06-29-2008, 12:53 PM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: 1992 grand prix se seats issue
You can change to bucket seats. You will need a set of seats with the mounts and adjustment rails. You should be able to pick up a complete set at a wrecking yard for a good price. You will need to drill and bolt everything into place and make sure you utilize a good grade of bolts when you mount them. Also if the car does not have predrilled holes in the floorboard make sure you use washers to provide support for the bolts so they don't pull through the sheet metal.
