Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 05-03-2008, 04:10 PM
VictorPerez VictorPerez is offline
check engine light
hey i have a eclipse gs and the light is on i used a obd2 scaner to check it out on the code reads
P1294
Injector High Side Open - Bank 2/Target idle not reached
so if any one can tell me how i can fix it please oh and the car idles all the way to 5000 rpms when you turn it on and wont go down
Old 05-03-2008, 04:41 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Re: check engine light
Code P1294 is for - Target idle not reached. I would check for vac. leaks first. About the only thing that will cause a really high idle like that is if lots of air is getting into the intake mani. So you either have a vac. leak or the TB isin't closing all of the way. One way you can check is to take the intake off the car and put your hand over the TB to block ALL the air going to the motor. The car should cut off since you are blocking all of the air. If it still runs then you have a massive leak someone and you should be able to track it down pretty easily.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 05-06-2008, 05:28 PM
thanks for the help i did put my hand in the tb to block the air but it didnt cut off it still revd up high so im guessing i have a leak anywhere you would recomend me checking first
